shared library !
wedyan
hey all
i write a program for my mini using Qt2.2
i need to link my program to shared librarys
when i compile the program i add my librarys to the make file and it
cmpiles with no error
but when i try to run the binary on my mini i get this error
cant link to shard library !
where should my librarys be ?
or how can i link my librarys staticly ? i try -static it didnt work !
thanx
Juergen Beisert
If you link your program dynamically, these libraries must also be present
at your target. What libraries are required can be checked with " readelf
-d <your program> | grep NEEDED" on your host.
And shared libraries must exist in directories where the dynamic linker
expect them: usually '/lib' or '/usr/lib'. Non common directories can be
added with the LD_LIBRARY_PATH environment variable.
To link your program statically the static libraries must be present. If
only '*.so' libraries exist the linker falls back to dynamic linking.
wedyan
it gives me the following error :
error while loading shared libraries: libqtopia2.so.2: cannot open shared
object file: No such file or directory
the libqtopia2.so.2 library is missing , i searched /lib and /usr/lib
it does not exist there
TungPham
try to search libqtopia2 in your board rootfs:
find . | grep libqtopia2 ( normally it is located at opt/qtopia/....)
Add it to LD_LIBRARY_PATH and RUN.
Or you need a qt app like this link:
http://equallybad.blogspot.com/2010/02/project-how-to-setup-default-dev-...
