Product: Mini2440 S3C2440 + 3.5" TFT Touch Screen LCD‏ (256 M) Target OS: Linux Attempted Image : zImage_T35 / zImage_N35 ( directly from the disc in the box ) Problem: When booted up, messed up Screen Positions.I had tried searching around, it turned out something related to ts_calibrated stuff. Problem is I have no idea entering U-boot environment. I will attach a screen shot tonight as a proof. Would you mind to give some pointers for those who faced this issue and has a solution onit.
Messed up resolution in Mini2440
First off, for this platform zImages are downloaded using DNW via Supervivi. If you are really using u-boot you normally download uImages. This situation might have changed are there have been comments about u-boot being modified to download zImages. Which instructions are you following?
Preparing linux image U-Boot does not support normal linux kernel images like zImage or Image (arch/arm/boot/), you have to create an uImage file with the mkimage tool which encapsulates kernel image with header information, CRC32 checksum, etc. from http://www.at91.com/linux4sam/bin/view/Linux4SAM/U-Boot also, Google <uboot zimage>
I followed below instructions:- 1. Launch DNW and click connect. 2. Power off the board then switch the board to NOR mode then power on back. 3. Format NAND and download SuperVivi-128M. It completed successfully 4. Download Linux Kernel ( attempted zImage_T35 and also attempted zImage_N35 directly from the DVD ). It completed successfully. 5. Download root_qtopia-128M and it completed sucessfully. 6. Power off the board and switch the board to NAND. 7. Power on the board to start Linux and the witnessed resolution messed up. I hope this information helps. Really no idea why the resolution messed up even i'm using the shipped DVD's images. Appreciate your help.
4. zImage_T35 and N35 are for specific touchscreens. You need to know which touchscreen you are using.
Hi Davef, Appreciate your prompt response. Considered i'm new in Embedded, this is the product I purchase ( exact model ):- http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=280533619533&... From here, can you tell what touchscreens is this? I'm pretty sure this is a 3.5 inches touch screen, and that's why i attempted both zImage_T35 and zImage_N35. Thanks for your help again.
From the downloads page Display NL2432HC22 3.5 inch Display N35 (NEC) TD035STED4 3.5 inch Display T35 (Toppoly) ACX502BMU 3.5 inch Display X35 (Sony) and also W35i - Sharp LQ035Q1DG06 Think the Sharp and Sony might be on the 1Gb machines. Look on the back of the display.
Hi Davef, Thanks for your response. I will go back and check today and let you know again. I will also check the DVD Linux Image again, see what other 3.5" available. Wait for my response. Thanks again.
Hi Davef, I just the display, it is labeled as "LCD- W35i". So can i know what zImage to use in this ?
The zImage for the W35i display. If it is not on the disc then you can download it here: http://www.friendlyarm.net/downloads
Hi Andreas Watterott, Wingz and Davef, I've downloaded it and thanks for the offer. The question is what zImage to use? 1. zImage_N35? 2. zImage_T35? 3. zImage_X35? or totally none of above? The Mini2440's LCD is labelled as "LCD-W35i"
If there is not a W35i zImage in here then report back. http://www.friendlyarm.net/dl.php?file=linux-zImage_20110421.zip
Hi Andreas Watterott, Wingz and Davef, Thanks for the response. I've downloaded http://www.friendlyarm.net/dl.php?file=linux-zImage_20110421.zip and unzip it. Below is the zImage from the zip file:- 1.zImage_A70 2.zImage_L80 3.zImage_N35 4.zImage_N43 5.zImage_T35 6.zImage_VGA1024X768 7.zImage_W35 8.zImage_X35 By seeing it, i'm eliminating the possibility of #1,#2,#4,#6. So, which zImage to use? is this zImage_W35? Thanks again. Hi Wingz, My email address is daniel_5191@hotmail.com You can email the zImage which you think can solve this problem. Very much appreciated.
Hi Andreas Watterott, Wingz and Davef, Just FYI, zImage_W35 works for my Mini2440. At least i'm seeing the screen didn't messed up after reboot. I just confirmed by testing it. Thanks for the effort adding it in the download.
I have done all these images but i am getting an error like this(only some part is mentioned here) block 2 is bad block 625 is bad block 1382 is bad block 3549 is bad can any one help plz?
I have successfully compiled tslib and qt-everywhere-4.6.2 and loaded the library files from home/tslib/lib and usr/local/Qt to target-board(mini2440friendlyArm) of usr/local/Qt/lib and usr/local/tslib/lib in my case the apllication runs on terminal but when i touch to the screen it does not response anything and when i run through hypertreminal by commenting out to the last 3 lines of rcS file and it gives the error "lib/libts-0.0.s0.0;ELF file version does not match current one can you help me please its urgent
