Hello, i'm experiencing problems similar to those: http://www.friendlyarm.net/forum/topic/9 When downloading a file via FTP or sending packets (TCP or UDP) from the device it doesn't take long for the driver to crash. Crashing means the device loses its IP address (at least its not possible to ping it anymore). What seems to be strange is when sending UDP Packets after the crash (TCP not possible because it cant handshake anymore) packets will be send to the network (can be sniffed with Ethereal or Wireshark), but it doesn't send UDP packets, it sends out raw Ethernet-II-Frames. So it appears that the device driver has problems to communicate with the upper layers after the crash. When limiting transmit speed to about 20 kb/s it seems to run a long time without a crash. However, when increasing the number of parallel send threads the crash occurs pretty quickly, even with limited transfer rate per thread. Obviously limiting the speed to 20 kb/s and just one thread can't be the solution to this. After finding the solved bug in the linux driver I suspect the CE bug to be similar. I hope someone with more experience in driver developing could look into this. To reproduce the problem just set up a mini2440-Board with CE 5.0 and an FTP-Server and try to download a bunch of files (e.g. \windows), it should crash pretty quickly. The problem isn't caused by the FTP-Server because I have the same issues with a custom socket application.
Mini2440: Bug in DM9000 Driver for CE ?
Hello, I have exactly the same problem. It seems that there's really a bug in that driver. Any ideas ? Thank you
After having to rebuild a new OS for the new 128MB-Boards this error seems to be gone, at least I can't get it to crash anymore, stable FTP downloading with ~600 kb/s. I used this BSP to build my OS: http://www.andahammer.com/Downloads/mini2440-en.rar
Hello again, Currently I'm using the BSP indicated as mini2440-bsp-en-090901 (last version). This driver is crashing sometimes using FTP. Please note that crashing is not inmediate... it needs about 5-6 ftp downloads of 1Mb file and about 5-6 dirs in windows directory. Examining the BSP DM9000 driver code I encountered a problem that can cause this driver to crash. I'm not an expert in WCE driver development, but I think that there's a possible workarond to solve this: As I understand, the DM9000 has memory to alloc up to 2 IP TX packets (I and II), but the driver is using these 2 packets incorrectly. In fact, the driver is sending these two packets without any check. The DM9000 datasheet indicates "... The D9000 starts to trasmit the index I packet. BEFORE the trasmission of the index I packet ends, the data of the next (index II) packet can be moved to TX RAM.", but also "AFTER the index I packet ends trasmission, write the byte count data of the index II to BYTE_COUNT registed an then set the bit 0 of TX control register to trasmit the index II packet". The driver is NOT checking if pack I is trasmitted before setting length and send packet II. This timing can cause, in some conditions, the driver to fail to a non recoverable status (the m_nTx variable has a wrong value and can't be recovered). As a workaround I modified the driver to send only one packet at a time: In file "dm9000.cpp", function C_DM9000:DeviceSend (..), replace the line "for (;m_nTx < 2;)" by line "for (;m_nTx < 1;)". In my case this is solving the crash, but in theory is also slowing the transfers (I didn't notice any slowdown). I hope this post helps to modify the driver in a more elegant way.
Hello, Did the above fix solve the problem? I am using the build-in web server and randomly the web server hangs and does not even respond to ping. I tried to built my own web server, but with it I am not able to send data more than 16KB, I don't know why? Thanks, Jagan.
Hello matt, The above dm9000.cpp fix solved completely the bug (at least in my case). Regards Baldwin
Hello, It solved hte problem! thanks for the tip! I was also able to change the Web Server Port using the regedit tool. There is a software known as mobile registery editor which connects through Sync to MINI2440 and then under services you can chnage the port from default 80 to 75 for example. Remember the value under services is in HEX, so we will have to input the new value in HEX. The port itself is little bit confusing , it is someting like 00 00 50 00..., we will have to only change 50 to 4B to have the new port 75 instead of 80. Hope this helps...
Hi to all. I hope you still reading this post. I need to use a mini2440 WinCE board for a school project, may you share a WinCE5-Os image so I can directly use the fix? Really thank you.
