When I boot my new kernel at first it boots fine... then it prints many (like couple of hundred) of such lines: ... Empty flash at 0x00ea7ffc ends at 0x00ea8000 Empty flash at 0x00eb3ffc ends at 0x00eb4000 Empty flash at 0x00eb7ffc ends at 0x00eb8000 Empty flash at 0x00ec3ffc ends at 0x00ec4000 ... And at the end it says: VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 124K Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. [<c002cb7c>] (unwind_backtrace+0x0/0xec) from [<c02d7e24>] (panic+0x54/0xdc) [<c02d7e24>] (panic+0x54/0xdc) from [<c002764c>] (init_post+0x9c/0xbc) [<c002764c>] (init_post+0x9c/0xbc) from [<c0008478>] (kernel_init+0x114/0x150) [<c0008478>] (kernel_init+0x114/0x150) from [<c0028a4c>] (kernel_thread_exit+0x0/0x8) Is the "empty flash" thing something to worry about? The rootfs partition is for sure bigger than the jffs2 image that I wrote to it... Can I fix this somehow? Also how do I pass the init= option to the kernel? regards, -- Luke
errors booting new kernel
I added init=/sbin/init to bootargs but it still says: Failed to execute /sbin/init. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. [<c002cb7c>] (unwind_backtrace+0x0/0xec) from [<c02d7e24>] (panic+0x54/0xdc) [<c02d7e24>] (panic+0x54/0xdc) from [<c002764c>] (init_post+0x9c/0xbc) [<c002764c>] (init_post+0x9c/0xbc) from [<c0008478>] (kernel_init+0x114/0x150) [<c0008478>] (kernel_init+0x114/0x150) from [<c0028a4c>] (kernel_thread_exit+0x0/0x8)
Yes, I think it is something to worry about. However, I am struggling to keep up with where you are at. Maybe, if you describe your current setup. IE Supervivi in NOR, u-boot in NAND, maybe reference the tutorial I posted.
I've finished the tutorial.
I have u-boot in both nor and nand.
MINI2440 # mtdparts
device nand0 <mini2440-nand>, # parts = 4
#: name size offset mask_flags
0: u-boot 0x00040000 0x00000000 0
1: u-boot_env 0x00020000 0x00040000 0
2: kernel 0x00500000 0x00060000 0
3: rootfs 0x3faa0000 0x00560000 0
active partition: nand0,0 - (u-boot) 0x00040000 @ 0x00000000
defaults:
mtdids : nand0=mini2440-nand
mtdparts: <NULL>
MINI2440 #
I have download the kernel, and root and trying to boot the damn thing.
Here's the list of my env vars:
MINI2440 # printenv
bootdelay=3
baudrate=115200
ethaddr=08:08:11:18:12:27
ipaddr=10.0.0.111
serverip=10.0.0.4
netmask=255.255.255.0
usbtty=cdc_acm
mini2440=mini2440=0tb
bootargs_init=init=/sbin/init
root_nfs=/mnt/nfs
ifconfig=ip=dhcp
${mini2440} ${root_mmc}
${mini2440} ${root_nand}
mtdids=nand0=mini2440-nand
mtdparts=mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x0050
0000(kernel),0x3faa0000(rootfs)
bootcmd=nboot.e kernel ; bootm
bootfile=x256l26359.jffs2
loadaddr=0x31000000
bootargs=root=/dev/mtdblock3 rootfstype=jffs2 console=ttySAC0,115200
init=/sbin/init rootwait=5
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
Environment size: 1220/131068 bytes
MINI2440 #
Now I see there are errors in the nand after reset...
MINI2440 # reset�
U-Boot 1.3.2-mini2440 (Oct 30 2011 - 10:56:54)
I2C: ready
DRAM: 64 MB
NOR Flash not found. Use hardware switch and 'flinit'
Flash: 0 kB
NAND: 1024 MiB
USB: S3C2410 USB Deviced
In: serial
Out: serial
Err: serial
MAC: 08:08:11:18:12:27
Loading from NAND 1GiB 3,3V 8-bit, offset 0x60000
Image Name:
Created: 2011-10-30 22:50:34 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2076216 Bytes = 2 MB
Load Address: 30008000
Entry Point: 30008000
reading NAND page at offset 0x25a800 failed
** Read error
Wrong Image Format for bootm command
ERROR: can't get kernel image!
MINI2440 #
I think I will do the process all over again, starting with scrubbing the
nand...
I suspected at times that you could not just jump in anywhere, but to go back to the nand scrub stage. I must have gone through that procedure over a hundred times before moving on.
Also I'm using tftp instead of reading from sd card (as in tutorial). I hope this shouldn't make a difference? It's much faster and easier this way...
Shit, I made it all over again, from scrubbing to the very end - same thing: empty flash and kernel panic :(
I'm thinking of clearing the partition table. But I'd need a factory default. Do you have one for the 1GB nand?
I think my jffs2 is bad... I can't check it as those mounting scripts (from the tutorial) don't work for me. It says the jffs2 filesytem is ukknown. Probably because of a missing kernel module...
The mounting script in the Linux tutorial on this site works for me . . . many times. You run that script on your host machine, to check your JFFS2 filesystem.
Ah, tiredness finally caught up on you! How are you making you JFFS2 filesystem? Hopefully, not: [mini2440-bootstrap] # mkfs.jffs2 –lqnp –e 16 –r target –o output/my_rootfs.jffs2
"I know, but it doesn't work for me as I said." Just checking, that you were running it on the host. What is your host machine running? There weren't any special applications required on Ubuntu 9.04 or 10.04LTS to mount the JFFS2 filesystem.
I'm making jffs2 like it is stated in the wiki: mkfs.jffs2 –lqnp –e 16 –r target –o output/my_rootfs.jffs2 But now I see it must be wrong :)
Yes. the 16 is for a 64M NAND flash. You needed a different number here. From memory all flash sizes from 128M to 1GB use the same number. Look at "erase block size".
Yes, I've looked already :) This explains the mounting problems. But anyways. I'm gonna try a new kernel too.
Ok. problems, problems, problems... Nobody wants to help with the 2.6.38.8 compilation problems, so I'm still trying to boot of the 2.6.35.9 patched by serg_io. No I don't have the "empty flash" messages. The root is mounted and also init is found,... but killed ;) VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 132K Kernel panic - not syncing: Attempted to kill init! [<c002eef4>] (unwind_backtrace+0x0/0xec) from [<c0312654>] (panic+0x5c/0xe4) [<c0312654>] (panic+0x5c/0xe4) from [<c0041fcc>] (do_exit+0x64/0x684) [<c0041fcc>] (do_exit+0x64/0x684) from [<c00426a8>] (do_group_exit+0xbc/0xf4) [<c00426a8>] (do_group_exit+0xbc/0xf4) from [<c004e204>] (get_signal_to_deliver+0x394/0x3e8) [<c004e204>] (get_signal_to_deliver+0x394/0x3e8) from [<c002c410>] (do_notify_resume+0x58/0x65c) [<c002c410>] (do_notify_resume+0x58/0x65c) from [<c002a0f0>] (work_pending+0x20/0x24) I made my jffs2 with -e 128, I hope this is good. Maybe I'm missing some libraries and init simply wont start? I used the libraries from arm-2008q3/arm-none-linux-gnueabi/libc/armv4t/lib/* and put them to /lib - I hope that is also ok (however wiki tells me tu put them in the jffs root, but "then Kernel panic - not syncing: No init found." So I don't know which is worse). I bet I need just a little tweak, addition link or library, mkfs.jffs2 setting change to make it work :/ HELP please regards,
Ok. One step further... It was the filesytem as I suspected. I built the whole thing using buildroot (a tool from busybox site) and the linux starts... well I think it starts because the console ouput gets cut as soon as it starts loading. This is what I get: VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 132K Starting logging: OK Starting network... Starting input-event-daemon: done input-event-daemon: daemon(): No such device And then the serial connection gets offline. Now what? :)
It's there afaik:
MINI2440 # printenv
bootdelay=3
baudrate=115200
usbtty=cdc_acm
root_nfs=/mnt/nfs
ifconfig=ip=dhcp
bootfile=u-boot.bin
loadaddr=0x31000000
filesize=3A814
fileaddr=31000000
ipaddr=10.0.0.111
serverip=10.0.0.4
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
The kernel reports what command line content it received, like this one: [...] Kernel command line: console=ttyS2,115200n8 noinitrd rw root=/dev/nfs nfsroot=/home/jb/work/ptx/bsps/mybsp/platform-myplatform/root,nolock,tcp ip=dhcp debug earlyprintk [...] You should see in your kernel log, if the "init=" is set correctly.
good to know, thank you. I actually didn't have it in the kernel command line. I added it and it doesn't change the unwanted behavior. However something new appeared (CRC error): ... Kernel command line: init=/sbin/init root=/dev/mtdblock3 rootfstype=jffs2 console=ttySAC0,115200 ... s3c-rtc s3c2410-rtc: setting system clock to 2000-05-02 15:50:45 UTC (957282645) jffs2_scan_inode_node(): CRC failed on node at 0x38816efd4: Read 0xffffffff, calculated 0x0d611447 VFS: Mounted root (jffs2 filesystem) on device 31:3. Freeing init memory: 132K Starting logging: OK Starting network... It wasn't there before for sure.
Now I have more of it, lol Empty flash at 0x0b2c8584 ends at 0x0b2c8800 jffs2_scan_inode_node(): CRC failed on node at 0x38816fd4: Read 0xffffffff, calculated 0x0d611447 Empty flash at 0x38817728 ends at 0x38817800 Badly rebuild bad block table? Or my NAND starts to break?
In my many hours of messing around with the own JFFS2 filesystems I would generally end up with this warning. Is seems that the root filesystem throws up this message the first time you change anything after a fresh boot. Ignoring this message seemed to be a safe thing to do and no one could offer any help on my concern. Try searching <CRC failed on node at> on this site and Google. I did not get the Empty flash message though. I'd suggest that needs sorting. NAND breaking down? You have been working this unit pretty hard, but I doubt it. Bad block table? That's why you need to do a nand scrub each time with u-boot (correct me if I am wrong), which for your 1GB machine takes alooooong time.
It takes about 11 minutes. But it is dangerous. As far as I understand it the nand comes with a preprogrammed map of factory bad blocks. Scrubbing removes this map copying it to memory and then recreating it. If something goes wrong in the process you lose this precious information and can have weird memory errors from then on... If someone knows better please correct me. Anyways what should I try now to see the friggen shell on my console? :)
I already have set the getty in inittab accordingly: ttySAC0::respawn:/sbin/getty -L ttySAC0 115200 vt102 # GENERIC_SERIAL before it was ttyS0 also vt100 - no difference I can write in the console but nothing happens, nothing is desplayed (except for what I'm writing). User root has shell /bin/sh which is present (the file) /etc/passwd entry for root: root:x:0:0:root:/root:/bin/sh so no password. What else can I do/check?
There's this file used by buildroot that is used to build /dev/* when static dev is selected: device_table_dev.txt It has a list of all created devices including ttySAC Maybe ttySAC has bad majon/minor numbers? How can check that? Buildroot's howto http://buildroot.uclibc.org/buildroot.html#faq) says it's enough to set the serial port in the buildroot configuration. Symptoms are exactly the same as mine, but the soltion doesn't wokr :( So close... yet so far :)
Yup, every time you read something about scrubbing NAND you are given these "dire" warnings. And expressing concerns in this area as well was met with silence. I scrubbed the NAND probably a hundred or more times with Bao's tutorial and the unit still works. Perhaps, what I need to know is WHY DO YOU (apparently) HAVE TO SCRUB THE NAND? I understand that the BBT is modified whenever bad blocks are encountered in the future. Now, you got me thinking about what really happens when running Barebox in the Pengutronix BSP, as it seems to set things up a lot quicker. Your console problem: - have you enabled virtual console (?) in the kernel I'll fish out the details.
Device Drivers --->
Character devices --->
[*] Virtual terminal
[*] Enable character translations in console
[*] Support for console on virtual terminal
Graphics support --->
[*] Support for frame buffer devices --->
<*> S3C2410 LCD framebuffer support
Console display driver support --->
<*> Framebuffer Console support
[*] Map the console to the primary display device
[*] Select compiled-in fonts
[*] VGA 8x8 font
Ah, you mean when you enter a command you see the test displayed but that on hitting the enter key nothing happens after that. Don't know why.
Where? On localhost (host computer)? I don't have ttySAC. On mini? I don't have shell! :) Anyways I changed init=/sbin/init to init=/bin/sh. I get a shell, but I don't think it's the way to go... Freeing init memory: 132K /bin/sh: can't access tty; job control turned off / #
Are you able to run something like minicom on the host and talk to mini2440, ie navigate the root directory? ttySAC0, ttySAC1 and ttySAC2 should be on the mini2440. I think I might have lost the "top-level" view of what you are trying to do. I never used buildroot. And after playing about this device for about 2 years I am now only using the Pengutronix BSP. Off to work I go.
/ # ls -al /dev/ttySAC* -rw--w---- 1 root root 59 May 2 11:20 /dev/ttySAC0 -rw-r--r-- 1 root root 0 Nov 1 2011 /dev/ttySAC1 -rw-r--r-- 1 root root 0 Nov 1 2011 /dev/ttySAC2 -rw-r--r-- 1 root root 0 Nov 1 2011 /dev/ttySAC3
I haven't got access to my mini2440 at work, but I don't see the major and minor numbers in your clip. I thought they were suppose to be before the date.
Sorry, sometimes I don't pick up important details. I have no static dev experience. Talking about experience . . . you may have only started "Linux since last Friday", but you do have significant other computer/software experience?
Why are you using static device nodes???? If you do not want to use udev (as it slow down system's start up) you can use the devtmpfs instead. Using static device nodes is error prone. "I wonder what are the drawbacks of using /bin/sh as init..." Hit CTRL-C and you will see it. ;-)
"jffs2_scan_inode_node(): CRC failed on node at 0x38816efd4: [...]". If you erase the flash and write a new JFFS2 image into it, and you mount this filesystem the first time, JFFS2 scans the whole flash in the background. You can see it, if you configure your kernel to flash one of the LEDs (refer "LED trigger") if an NAND access occurs. If you disturbing this scan by hitting the RESET button, because you are impatient, such messages can occure the next time you boot the system. Mostly harmless and you can ignore them (AFAIK).
ctrl-d u mean :) well... then I have to recompile the kernel, as it doesn't include devtmpfs :/ Anywyas... with /bin/sh as init i can mount proc but I can't run some of the xenomai binaries... /usr/xenomai/bin # sh ./xeno latency ./xeno: exec: line 15: /usr/xenomai/bin/latency: not found /usr/xenomai/bin # ls -al /usr/xenomai/bin/latency -rwxr-xr-x 1 root root 29528 Nov 1 2011 /usr/xenomai/bin/latency
I've compiled the kernel with devtmpfs and changed static dec to devtmpfs. Now the boot process looks like this: ... Starting network... can't open /dev/ttyS0: No such file or directory can't open /dev/ttyS0: No such file or directory ... or if I change to /dev/ttySAC0 then you can substitute in the above lines...
This is bad... init=/bin/sh /usr/xenomai/bin # ls -al /dev/ttyS* ls: /dev/ttyS*: No such file or directory ???
Haha, changed the inittab entry to console... ::respawn:/sbin/getty -L console 115200 vt100 # GENERIC_SERIAL and I get the login prompt! But ;) I don't know how to login :) ... Starting network... Welcome to Buildroot buildroot login: root Login incorrect buildroot login: So what next? :)
oops that's for the Pengutronix BSP. Someone did ask that same question on here in the last year or so. Search <buildroor login>?
Eh... I hate this. When I changed ttySAC0 to console on the device it worked after reboot. Now when I changed it on the host and made fs again and put it back on the mini2440 it doesn't work anymore...
I thought default didn't work, as per your last post. This is happening too fast! Spelling mistakes and all.
it works! Almost ;) Welcome to Buildroot buildroot login: root -sh: can't access tty; job control turned off # I'd love to get rid of the waring/error message... And now it's time to make the xenomai work ;)
Maybe some day... ;) Now it still seems impossible to me :) I get too many nasty errors ... and help from nowhere - I'm a pioneer ;)
I hope you are referring to xenomai. Is there not a forum associated with xenomai? Tomorrow is another day.
Sure I'm referining to xenomai. With mini I get help for which - thank you all :) About xenomai I'm on a mail list - but they're not as fast as you ;)
Those were an unusual 2 or 3 days. Because I am in NZ I am used to posting a question and maybe hearing back 6-12 hours later. Now that you have done things the hard way, have you had a look at the Pengutronix BSP for the mini2440?
Yes, I've taken their kernel patches to try to build xenomai 2.6.0 on them. But the kernel won't compile yet.
I didn't read the complete conversation. But i have also faced this crash when i was booting filesystem from Nand flash. This is because, When you boot first time, kernel and fs boots without any issue. After booting, it will have a sync with the fs partition in nandflash. Read and write will be happening frequently. If you reset the board this sync is lost and it will corrupt the filesystem, so second it will not boot. Instead of reset try rebooting with the reboot command. (reboot -f also might not work). reboot will do proper operation with the fs so second time it should boot without any issue. Try with the reboot command still if you face this issue then its something else.
changed the inittab entry to console... ::respawn:/sbin/getty -L console 115200 vt100 # GENERIC_SERIAL i am not getting the serial console this error. VFS: Mounted root (yaffs filesystem) on device 31:3. Freeing init memory: 188K Warning: unable to open an initial console. request_module: runaway loop modprobe binfmt-464c request_module: runaway loop modprobe binfmt-464c request_module: runaway loop modprobe binfmt-464c request_module: runaway loop modprobe binfmt-464c request_module: runaway loop modprobe binfmt-464c pls any one help me inittab pls send the my mail Thanks
