I'm trying to compile the s3c2410_boot_usb program on my ubuntu 11.10. I need it to put files on my mini2440 board via usb. I got it from here: http://code.google.com/p/mini2440/downloads/detail?name=s3c2410_boot_usb...= And it was referenced from here: http://narnia.cs.ttu.edu/drupal/node/131 And the above tutorial was referenced on the wiki of this site :) But the program is really old (2006) and it won't compile: luke@dragilla:~/Desktop/moje/mini2440/s3c2410_boot_usb$ make cc -lusb -o s3c2410_boot_usb boot_usb.o boot_usb.o: In function `find_qt2410_device': boot_usb.c:(.text+0x83): undefined reference to `usb_busses' boot_usb.o: In function `qt2410_send_file': boot_usb.c:(.text+0x2df): undefined reference to `usb_bulk_write' boot_usb.o: In function `main': boot_usb.c:(.text+0x325): undefined reference to `usb_init' boot_usb.c:(.text+0x32a): undefined reference to `usb_find_busses' boot_usb.c:(.text+0x33f): undefined reference to `usb_find_devices' boot_usb.c:(.text+0x38c): undefined reference to `usb_open' boot_usb.c:(.text+0x39f): undefined reference to `usb_strerror' boot_usb.c:(.text+0x3d1): undefined reference to `usb_claim_interface' boot_usb.c:(.text+0x3da): undefined reference to `usb_strerror' collect2: ld returned 1 exit status make: *** [s3c2410_boot_usb] Error 1 Yes, I do have libusb-dev installed. Any ideas how to fix it? Or maybe I should use a different tool? regards, -- Luke
s3c2410_boot_usb
I didn't know it, but it seems it's based on boot_usb (s3c2410_boot_usb). Anyways I'm having the same compilation errors trying to make usbpush. Must be something wrong with the new ubuntu and it's library dependencies. Luckily in the package of usbpush there's a staticly linked version of boot usb, which seems to work just fine. Thank you.
Here is an alternative program to upload files to the mini2440 board (basing on the original s3c2410_boot_usb but with many improvements): http://programmers-projects.de/node/16 The source code is included in the tar.gz archive.
If anyone else has this problem. The solution is changing the make target to the following in the makefile: s3c2410_boot_usb: boot_usb.o $(CC) -o $@ $< $(LDFLAGS) This is caused by new gcc needing the lib flags after the source files
Hi! If you wanna use usbpush, edit the makefile, replacing the lines bellow: usbpush: usbpush.o --> replaced line $(CC) -o $@ $< $(LDFLAGS) --> original line #$(CC) $(LDFLAGS) -o $@ $< usbpush.o: usbpush.c --> replaced line $(CC) -o $@ $< $(LDFLAGS) --> original line #$(CC) $(CFLAGS) -o $@ -c $<
