Linux installation on mini 6410
cgtyyldrm
ı have mini 6410+4.3"" LCD. ı want to install linux from sd card.
although  making all of installion steps, ı cant install. after insert
 sd card into board, all of leds light on but there was no beep beep.plaese
help me!
vib
Attach a serial cable to check at what stage the system failed. Meanwhile,
check the spelling in the ini file if you typed it. Perhaps share your ini
file.
cgtyyldrm
#This line cannot be removed. by FriendlyARM(www.arm9.net)
CheckOneButton=No
Action=install
OS= linux
VerifyNandWrite=No
StatusType = Beeper| LED
#################### Linux #####################
Linux-BootLoader = Linux/u-boot_nand-ram256.bin
Linux-Kernel = Linux/zImage_n43
Linux-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs
init=/linuxrc console=ttySAC0,115200
Linux-RootFs-InstallImage = linux/rootfs_qtopia_qt4.ubi
Linux-RootFs-RunImage = linux/rootfs_qtopia_qt4.ext3
################### WindowsCE6 #################
WindowsCE6-Bootloader= WindowsCE6\NBOOT_N43-RAM256.nb0
WindowsCE6-InstallImage = WindowsCE6\NK_N43-i.bin
WindowsCE6-RunImage = WindowsCE6\NK_N43-i.bin
################### Android ####################
Android-BootLoader = Android/u-boot_nand-ram256.bin
Android-Kernel = Android/azImage_a70
Android-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs
 init=/linuxrc console=ttySAC0,115200 androidboot.console=s3c2410_serial0
Android-RootFs-InstallImage = Android/rootfs_android.ubi
Android-RootFs-RunImage = Android/rootfs_android.ext3
################### Ubuntu #####################
Ubuntu-BootLoader = Ubuntu/u-boot_nand-ram256.bin
Ubuntu-Kernel = Ubuntu/uzImage_n43
Ubuntu-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs
Ubuntu-RootFs-InstallImage = Ubuntu/rootfs_ubuntu.ubi
Ubuntu-RootFs-RunImage = Ubuntu/rootfs_ubuntu.ext3
############### UserBin part #################
UserBin-Image=WindowsCE/NK.nb0
userBin-StartAddress=50100000
vib
1. Try without a space after OS=.
2. Try use uppercase for L.
3. Make sure you ve got the folder structure correct.
4. Make sure you ve got the hidden partition - can verify only through the
process.
5. Without hyperterminal, you can really know much what is happening when
6410 bootup. Attach one and you will see the faults immediately.
cgtyyldrm
how many minutes does linux installing take from sd card ?
vib
At least 2 minutes. But it is fully loaded, it is not slow from my
experience for a system of 533MHz. With Xubuntu, I could even run the
latest Firefox,etc.
Kaushik Kale
Is it always required to have the SD Card for booting? Can we not transfer
the OS to the Nand and have that working without SD Card?
vib
Of course you can. SD card is an option for having the convenience to store
a few OSes in one place. With the OSes in SD card, you simply choose one
you like to run it. If you are happy with it you can change it to install,
which it is permanently copied to NAND, and runs it from NAND until next
changes with the SD card. isn't that brilliant!
virk
plz can somebody describe the complete procedure of installing ubuntu on
mini6410.. i don't know from where to start..thanks
Tiny
Plz can somebody share the rootfs_qtopia_qt4.ubi adn zImage_n43 for linux
Thanks in advance
Madhan
Yep, for me too.I downloaded files from the server but I miss the
zImage_n43 file.
What I have is zImage file. And my LCD is 4.3inch.
