Hi everybody, I bought one FriendlyArm model OK6410 (with Arm11), and I have an issue to boot via SD card, it reads files but don't boot. I checked the four micro switches and according to the manual they are in position correct to boot from SD card but it does not work. It came with Windows embedded CE 6.0, but it is all in damn Chinese! I would need to change the idiom or install other SO (may be in English). I also would like to discover how to access the bios. Does anyone know why this site don't have discussion about OK6410 on this forum?
Why don't discuss about OK6410
as asdf allready sayed, its no from friendlyarm. actualy it has the same cpu (s3c6410) but propaply not all the ports are connected as on the mini6410, so your kernel will propaply need another "mach" file... or if you are lucky, they are 100% compatible (try to compare the schematics if you find them) english product pages http://arm9board.net/sel/prddetail.aspx?id=348&pid=200 (for the ok6410) http://arm9board.net/sel/prddetail.aspx?id=365&pid=200 (for the ok6410-bh) (where there are downloads too, like kernel, rootfs) or the english wiki: http://arm9board.net/wiki/index.php?title=Main_Page getting started http://www.arm9board.net/wiki/index.php?title=Embedded_Linux
Yup, it is not from FriendlyARM. Somehow, you or someone gave you the impression that it is from FriendlyARM. It will still work, but not the way this forum could resolve.
I bought one as a possible second source item. The board is OK, the Linux isn't - it comes with a cramfs file system installed which is quite useless and does not have the ease of file system loading like the FriendlyArm 6410 - it's back to the dark ages of DNW... It also does not have Alsa in the distributions and as FriendlyArm have it all done already I don't see what I have to 'roll my own'. If you want to update from cramfs to yaffs it's VM time and you have to install it from the supplied tgz. This takes ages, which for my production purposes makes it a complete non-starter. Andy.
Thank you everybody for help. Well, unfortunately for me it is not from friendlyarm. I still didn't discover what can I do with this damn chinese WinCE in my OK6410 board. At least I just would like to discover how to change it's language, or discover how to install some SO in English for it. :(
Hi, I had flashed the win CE to english version by using VS2005. anyone who need help can email me at boochinboon@gmail.com. I will send you the 5 files to be use with the SDwriter.exe. which will self boot.
I have a map OK6410 I want to start the program and then install an inside but I can not do that someone tells me how his qYes does this map and I must do to make it work? please help me this is urgent
