hi, i have mini2440 running linux. can somebody suggest me what software can i use to make an application for mini2440? and how to embedd it to mini2440? thanks.
[help] programming mini2440
>>what software can i use to make an application for mini2440? text editor and compilator (for example gcc)
http://wingston.wordpress.com/embedded-programming-on-the-mini2440-using... This describes a way for complete begginers to get up and running with the mini2440. Once you have the BSP up on your mini2440 you can use the same ptxdist program to compile c code and send it to your mini2440 as an installed application.
