i manage to establish a ppp connection but have identical local and remote ip addresses. i can ping www.google.com and traceroute www.google.com but the connection is dropped when i try and use a web browser. thanks in advance. cat /var/log/messages: Apr 5 21:51:41 FriendlyARM local2.info chat[989]: send (ATDT*99#^M) Apr 5 21:51:41 FriendlyARM local2.info chat[989]: expect (CONNECT) Apr 5 21:51:41 FriendlyARM local2.info chat[989]: ^M Apr 5 21:51:41 FriendlyARM local2.info chat[989]: ^M Apr 5 21:51:41 FriendlyARM local2.info chat[989]: CONNECT Apr 5 21:51:41 FriendlyARM local2.info chat[989]: -- got it Apr 5 21:51:41 FriendlyARM local2.info chat[989]: send (\d) Apr 5 21:51:42 FriendlyARM daemon.info pppd[987]: Serial connection established. Apr 5 21:51:42 FriendlyARM daemon.info pppd[987]: Using interface ppp0 Apr 5 21:51:42 FriendlyARM daemon.notice pppd[987]: Connect: ppp0 <--> /dev/ttySAC1 Apr 5 21:51:44 FriendlyARM daemon.notice pppd[987]: local IP address 41.119.235.100 Apr 5 21:51:44 FriendlyARM daemon.notice pppd[987]: remote IP address 41.119.235.100 Apr 5 21:51:44 FriendlyARM daemon.notice pppd[987]: primary DNS address 209.212.96.1 Apr 5 21:51:44 FriendlyARM daemon.notice pppd[987]: secondary DNS address 209.212.97.1
ppp has same local and remote ip address
cat /var/log/messages on termination looks as follows: Apr 5 21:51:42 FriendlyARM daemon.info pppd[987]: Using interface ppp0 Apr 5 21:51:42 FriendlyARM daemon.notice pppd[987]: Connect: ppp0 <--> /dev/ttySAC1 Apr 5 21:51:44 FriendlyARM daemon.notice pppd[987]: local IP address 41.119.235.100 Apr 5 21:51:44 FriendlyARM daemon.notice pppd[987]: remote IP address 41.119.235.100 Apr 5 21:51:44 FriendlyARM daemon.notice pppd[987]: primary DNS address 209.212.96.1 Apr 5 21:51:44 FriendlyARM daemon.notice pppd[987]: secondary DNS address 209.212.97.1 Apr 5 22:09:21 FriendlyARM daemon.info pppd[987]: LCP terminated by peer (User request) Apr 5 22:09:21 FriendlyARM daemon.info pppd[987]: Connect time 17.7 minutes. Apr 5 22:09:21 FriendlyARM daemon.info pppd[987]: Sent 4624 bytes, received 12475 bytes. Apr 5 22:09:24 FriendlyARM daemon.notice pppd[987]: Connection terminated. Apr 5 22:09:24 FriendlyARM local2.info chat[1017]: timeout set to 3 seconds Apr 5 22:09:24 FriendlyARM local2.info chat[1017]: abort on (NO CARRIER) Apr 5 22:09:24 FriendlyARM local2.info chat[1017]: send (\d+++\d) Apr 5 22:09:26 FriendlyARM local2.info chat[1017]: expect (OK)
I had the same problem. The symptom was actually that the connection would disconnect and drop back to the AT command mode, which would cause PPPD to complain that it was receiving it's own echos. (AT mode locally echos everything). I traced it to the fact that the local and remote IP addresses were the same. I fixed it by added "noipdefault" to the pppd options. Now the local and mote IP are different (remote is actually defaulting to 10.64.64.64, but I think the remote IP address is irrelevant -- as long as it isn't the same as the local IP). Note: I don't have this problem with my Verizon modem, just my AT&T modem.
