lqtopia2 Error
Wedyan
hey all
while building the Qt for My mini2440 on Ubntu pc i have this error
I dont know what to do or where to find this lqtopia2 !!
./arm-none-linux-gnueabi/bin/ld: cannot find -lqtopia2
Aniket Kumar Lata
Sir, Even I am facing the same problem..
hiren
Dear All,
 well i gone through the way how to install and try to build hello world
program. As i start to launch designer application of qt2.0 and found such
attached non opaqe screen so, when i opened sub menu it will make me in bad
bad situation so, i cant even read it. well i like to make clear i m using
ubuntu 11.10 OS. i installed compiler and setup seems to be ok. only i m
not able to open Designed app to make some form.
  Thanks in advance if someone help me.
thanks
fedeponte
Mini2440, UBUNTU, ARM-LINUX-GCC: ld: cannot find -lqtopia2
Hello everybody!
I'm a new user of UBUNTU, FORUM, and Mini2440 Platform.
I known all 2 mounth ago and I must develop with this.
I have a problem: I can't start beacause I never compile example project
"Hello".
I have done a virtual machine with Virtual Box on Windows7 64bit and I have
install and upgrade UBUNTU 11.10.
With terminal I try to compile the "Hello" example from CD and I read so:
ubuntu@ubuntu-VirtualBox:~$ cd
/home/ubuntu/opt/FriendlyARM/mini2440/arm-qtopia/hello
ubuntu@ubuntu-VirtualBox:~/opt/FriendlyARM/mini2440/arm-qtopia/hello$ ls
build  description-pak  hello.cpp      hello.h    hello.pro.user  Makefile
copia  hello_base.ui    hello.desktop  hello.pro  main.cpp
./build
rm -f .obj/release-shared/moc_hello_base.o
rm -f .moc/release-shared/moc_hello_base.cpp
rm -f .ui/release-shared/hello_base.cpp .ui/release-shared/hello_base.h
rm -f .obj/release-shared/hello.o .obj/release-shared/main.o
.obj/release-shared/hello_base.o
rm -f *~ core *.core
/home/ubuntu/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qt2/bi
n/uic
hello_base.ui -o .ui/release-shared/hello_base.h
/home/ubuntu/opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-g++ -c -pipe
-DQWS -fno-exceptions -fno-rtti -Wall -W -Os  -DQT_NO_QWS_VFB
-DQTOPIA_DATA_LINKING -DQCONFIG=\"qconfig-qpe.h\" -DQTOPIA_TARGET=\"hello\"
-DQTOPIA_TRTARGET=\"hello\" -DQT_NO_DEBUG
-I/home/ubuntu/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtop
ia/mkspecs/qws/linux-arm-g++
-I. -I../qtopia-2.2.0-FriendlyARM/qtopia/include
-I../qtopia-2.2.0-FriendlyARM/qt2/include -I.ui/release-shared/
-I.moc/release-shared/ -o .obj/release-shared/hello.o hello.cpp
-I.moc/release-shared/ -o .obj/release-shared/main.o main.cpp
n/uic
hello_base.ui -i hello_base.h -o .ui/release-shared/hello_base.cpp
-I.moc/release-shared/ -o .obj/release-shared/hello_base.o
n/moc
.ui/release-shared/hello_base.h -o .moc/release-shared/moc_hello_base.cpp
-I.moc/release-shared/ -o .obj/release-shared/moc_hello_base.o
/home/ubuntu/opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-g++  -o hello
.obj/release-shared/hello_base.o .obj/release-shared/moc_hello_base.o
-luuid -lqtopia2 -lqtopia -lqpe
-L/home/ubuntu/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qtop
ia/lib
-L/home/ubuntu/opt/FriendlyARM/mini2440/arm-qtopia/qtopia-2.2.0-FriendlyARM/qt2/
lib
-lqte
/home/ubuntu/opt/FriendlyARM/toolschain/4.4.3/bin/../lib/gcc/arm-none-linux-gnue
abi/4.4.3/../../../../arm-none-linux-gnueabi/bin/ld:
collect2: ld returned 1 exit status
make: *** [hello] Errore 1
There is somebody to help me?
Thank you so much!
Fede.
