Hi all, I'm stuck with executing Twonky media server on the mini2440. I don't understand why. I downloaded Linux ARM little endian glibc 2.2.5 version here: http://www.twonkyforum.com/downloads/6.0.34/ Then I unziped the file on the mini to the sdcard. Trying to lauch mediaserver, here is what I get: [root@FriendlyARM local]# ls -l /sdcard/twonkymedia -rwxrwxrwx 1 root root 2768 Sep 7 19:17 Linux-HowTo.txt -rwxrwxrwx 1 root root 57677 Sep 7 19:17 RevisionHistory drwxrwxrwx 2 root root 4096 Sep 7 19:17 cgi-bin -rwxrwxrwx 1 root root 193 Sep 7 19:17 initial_keystore.dat drwxrwxrwx 2 root root 4096 Sep 7 19:17 plugins -rwxrwxrwx 1 root root 421 Sep 7 19:17 radio.m3u drwxrwxrwx 4 root root 12288 Sep 7 19:17 resources -rwxrwxrwx 1 root root 4788 Sep 7 19:17 twonkymedia -rwxrwxrwx 1 root root 153 Sep 7 19:17 twonkymedia-server-defau lt.ini -rwxrwxrwx 1 root root 3775 Sep 7 19:17 twonkymedia.sh -rwxrwxrwx 1 root root 1646664 Sep 7 19:17 twonkymediaserver [root@FriendlyARM local]# /sdcard/twonkymedia/twonkymedia.sh TwonkyMedia server ------------------ Syntax: /sdcard/twonkymedia/twonkymedia.sh {start|stop|restart|reload|status} [root@FriendlyARM local]# /sdcard/twonkymedia/twonkymedia.sh start Starting /sdcard/twonkymedia/twonkymedia ... /sdcard/twonkymedia/twonkymedia.sh: line 154: /sdcard/twonkymedia/twonkymedia: not found [root@FriendlyARM local]# /sdcard/twonkymedia/twonkymedia -/bin/sh: /sdcard/twonkymedia/twonkymedia: not found [root@FriendlyARM local]# I don't understand the "not found" answer as the file exists and I have execute rights. I have to precise that I use the stock configuration, so FriendlyARM rootfs with 2.6.32.2 kernel. Can anyone help and explain my mistake? Thanks
Unable to execute a file
"not found" means in your case the program cannot be launched due to missing libraries for example. Run a "readelf -d <your program>" and search for lines with "(NEEDED)" in: the listed library must exist on your target. Or start your program with the "strace" tool.
I didn't know the readelf command. Here is the result : Dynamic section at offset 0xc38 contains 21 entries: Tag Type Name/Value 0x00000001 (NEEDED) Shared library: [libpthread.so.0] 0x00000001 (NEEDED) Shared library: [libc.so.6] 0x0000000c (INIT) 0x8604 0x0000000d (FINI) 0x8b9c 0x00000004 (HASH) 0x8130 0x00000005 (STRTAB) 0x8398 0x00000006 (SYMTAB) 0x81e8 0x0000000a (STRSZ) 268 (bytes) 0x0000000b (SYMENT) 16 (bytes) 0x00000015 (DEBUG) 0x0 0x00000003 (PLTGOT) 0x10d1c 0x00000002 (PLTRELSZ) 192 (bytes) 0x00000014 (PLTREL) REL 0x00000017 (JMPREL) 0x8544 0x00000011 (REL) 0x853c 0x00000012 (RELSZ) 8 (bytes) 0x00000013 (RELENT) 8 (bytes) 0x6ffffffe (VERNEED) 0x84dc 0x6fffffff (VERNEEDNUM) 2 0x6ffffff0 (VERSYM) 0x84a4 0x00000000 (NULL) 0x0 And if I look at the /lib folder [root@FriendlyARM /]# ls -l /lib/libc* -rwxr-xr-x 1 root root 1189276 Mar 26 2009 /lib/libc-2.8.so lrwxrwxrwx 1 root root 11 Jan 8 2010 /lib/libc.so.6 -> libc-2 .8.so -rwxr-xr-x 1 root root 181740 Mar 26 2009 /lib/libcidn-2.8.so lrwxrwxrwx 1 root root 14 Jan 8 2010 /lib/libcidn.so.1 -> lib cidn-2.8.so -rwxr-xr-x 1 root root 38324 Mar 26 2009 /lib/libcrypt-2.8.so lrwxrwxrwx 1 root root 15 Jan 8 2010 /lib/libcrypt.so.1 -> li bcrypt-2.8.so [root@FriendlyARM /]# ls -l /lib/libpth* -rwxr-xr-x 1 root root 84248 Mar 26 2009 /lib/libpthread-2.8.so lrwxrwxrwx 1 root root 17 Jan 8 2010 /lib/libpthread.so.0 -> libpthread-2.8.so [root@FriendlyARM /]# So the libraries seems to be present. Also there is no strace tool on the mini, and I don't know how to use it your help is appreciated
Maybe you can run $ LD_DEBUG=all /sdcard/twonkymedia/twonkymedia to get more information what is going wrong.
Hi Juergen Thank you for your support. I tried your command but I think the problem is elsewhere: [root@FriendlyARM /]# $ LD_DEBUG=all /sdcard/twonkymedia/twonkymedia sh: $: not found [root@FriendlyARM /]# $LD_DEBUG=all /sdcard/twonkymedia/twonkymedia sh: =all: not found [root@FriendlyARM /]# $PATH sh: /sbin:/usr/sbin:/bin:/usr/bin: not found [root@FriendlyARM /]# As you can see, the "not found" statement is always present, even when I try to display the content of $PATH variable. I'm not so familiar with linux, I have to say that this problem is out of my knowledge.
Try this: $ LD_DEBUG=all /lib/ld-<your-lib-rev>.so /sdcard/twonkymedia/twonkymedia "ld-<your-lib-rev>.so" is the loader for dynamically linled programs. Here on my Mini6410 rootfs it is "/lib/ld-2.13.so".
Nothing more : [root@FriendlyARM /]# ls -l /lib/ld* -rwxr-xr-x 1 root root 121560 Mar 26 2009 /lib/ld-2.8.so lrwxrwxrwx 1 root root 9 Jan 8 2010 /lib/ld-linux.so.3 -> ld -2.8.so [root@FriendlyARM /]# $ LD_DEBUG=all /lib/ld-2.8.so /sdcard/twonkymedia/twonkymedia -/bin/sh: $: not found [root@FriendlyARM /]# $ LD_DEBUG=all /lib/ld-linux.so.3 /sdcard/twonkymedia/twonkymedia -/bin/sh: $: not found [root@FriendlyARM /]# $LD_DEBUG=all /lib/ld-2.8.so /sdcard/twonkymedia/twonkymedia -/bin/sh: =all: not found [root@FriendlyARM /]# It's like $ is taken as an executable file which of course doesn't exist...
Ups, '$' is the prompt. I'm using it to show one should use the rest of the line as a command to enter. Don't add it to the command. The command is "LD_DEBUG=all /lib/ld-<your-lib-rev>.so /sdcard/twonkymedia/twonkymedia", independent of the prompt sign you (or your system) are/is using.
Oh sorry, I thought there was something like this, like for assigning a value to an environment variable like $PAHT, that's why I also test it without space. As you are always root on the stock mini2440 root fs, the character is "#" so it did not catch my attention. I'll test it properly this evening. Thank you for the explanation
There is nothing like a fixed prompt sign in our world. Neither '$' nor '#' is fixed for root. Its just a matter of taste what character you setup in your environment.
I forgot it was possible to change rhe prompt, I always used the original prompt in my Linux distros (mainly Fedora, Knoppix). Now, thanks to your explanation, I got some results: [root@FriendlyARM /]# LD_DEBUG=all /lib/ld-2.8.so /sdcard/twonkymedia/twonkymedia 773: file=/sdcard/twonkymedia/twonkymedia [0]; generating link map 773: dynamic: 0x00010c38 base: 0x00000000 size: 0x00008d98 773: entry: 0x0000874c phdr: 0x00008034 phnum: 6 773: 773: 773: file=libpthread.so.0 [0]; needed by /sdcard/twonkymedia/twonkymedia [0] 773: find library=libpthread.so.0 [0]; searching 773: search cache=/etc/ld.so.cache 773: search path=/lib/tls/v4l/half:/lib/tls/v4l:/lib/tls/half:/lib/tls:/lib/v4l/half:/lib/v4 l:/lib/half:/lib:/usr/lib/tls/v4l/half:/usr/lib/tls/v4l:/usr/lib/tls/half:/usr/l ib/tls:/usr/lib/v4l/half:/usr/lib/v4l:/usr/lib/half:/usr/lib (system search path) 773: trying file=/lib/tls/v4l/half/libpthread.so.0 773: trying file=/lib/tls/v4l/libpthread.so.0 773: trying file=/lib/tls/half/libpthread.so.0 773: trying file=/lib/tls/libpthread.so.0 773: trying file=/lib/v4l/half/libpthread.so.0 773: trying file=/lib/v4l/libpthread.so.0 773: trying file=/lib/half/libpthread.so.0 773: trying file=/lib/libpthread.so.0 773: 773: file=libpthread.so.0 [0]; generating link map 773: dynamic: 0x4001cef0 base: 0x40001000 size: 0x0001e204 773: entry: 0x4000538c phdr: 0x40001034 phnum: 9 773: 773: 773: file=libc.so.6 [0]; needed by /sdcard/twonkymedia/twonkymedia [0] 773: find library=libc.so.6 [0]; searching 773: search cache=/etc/ld.so.cache 773: search path=/lib:/usr/lib/tls/v4l/half:/usr/lib/tls/v4l:/usr/lib/tls/half:/usr/lib/tls: /usr/lib/v4l/half:/usr/lib/v4l:/usr/lib/half:/usr/lib (system search path) 773: trying file=/lib/libc.so.6 773: 773: file=libc.so.6 [0]; generating link map 773: dynamic: 0x40147f18 base: 0x40020000 size: 0x0012b238 773: entry: 0x400351dc phdr: 0x40020034 phnum: 10 773: 773: checking for version `GLIBC_2.0' in file /lib/libpthread.so.0 [0] required by file /sdcard/twonkymedia/twonkymedia [0] Segmentation fault [root@FriendlyARM /]# So we can see there is a segmentation fault in /lib/libpthread.so.0 Maybe replacing this library with the one of a cross compiler like codeSourcery could be an idea?
Do not assemble the required libraries from different sources. Use the binariey libraries from one toolchain only. This is what buildsystems like openembedded/buildroot/PTXdist do: Everything that will be part of the root filesystem will be built with one toolchain (compiler/linker/libs). You should follow the same approach.
I agree with you, but I use the original rootfs from friendlyarm, so I don't know what toolchain they used. I think it is the one which is in the download section, and I think it comes from codeSourcery. I will use this one as it is provided by FriendlyARM. Anyway, do you think it can solvethe problem?
> Anyway, do you think it can solve the problem? Yes it will. It makes your system consistent. Copying binaries from here and there may work...but mostly not. If you want a reliable system you should think about using a buildsystem.
That's the next step I would like to explore: building a whole root fs by myself to understand more linux architecture. As I have understood, buildroot, openembedded and PTXDist are tools to avoid doing everything by hand each time you want to generate a rootfs, but I would like to try one time to understand the full process instead of reading an internet page, applying what is written and leaving the tool do all the job. I wanted to copy all the original FriendlyARM rootfs on an NFS server to be able to analyse it, and compare it easyly with another one, such as pengutronix one. But I wasn't able to connect to my network hard drive, doing the same method which works on my workstation. I also have to find how to find the most suitable linux distro, find and understand the differences between openembedded, buildroot, PTXDist and so on. For the moment I keep the original stock rootfs because is is complete, with all drivers for GPIOs, ADC, screen and so on.
Hi Juergen, I'm back with this topic. I've just tried with a fresh emDebian Lenny Grip installation. I have the same troubles than before. Using LD_DEBUG reports the same segmentation fault issue checking for GLIBC_2.0 in /lib/libpthread.so.0. This time, I have not modified the libraries, it is juste the fresh original installation. Should I understand I have to cross compile glibc and install it on the mini? The twonkymedia package mentions "Linux ARM little endian glibc 2.2.5", is there something I missed? The revision is now 6.0.37 (http://www.twonkyforum.com/downloads/6.0.37/) and the error is still present. Thanks again for your help!
Ok, one last question: I'm not so familiar with ARM architecture versions. Mini2440 uses ARMv4t architecture. I thought that maybe the program I try to use is compiled for ARMv5t architecture. Could it be the cause of the error? In a more general way, I think it is not possible to use a software compiled for ARMv5t on an ARMv4t processor, but ARMv4t compiled software should run on ARMv5t processor, am-I right? Thaks for your explanations
If it is compiled for ARMv5, it should give you an "illegal instruction", but not a "segmentation fault". Maybe you can check it with the help of the "readelf" tool. This example is from my host, where I built my board support packages: [jb@isonoe]> readelf -A platform-mini2440/root/bin/busybox Attribute Section: aeabi File Attributes Tag_CPU_name: "4T" Tag_CPU_arch: v4T Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_VFP_arch: VFPv2 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align8_needed: Yes Tag_ABI_align8_preserved: Yes, except leaf SP Tag_ABI_enum_size: int Tag_unknown_44: 1 (0x1) In contrast: [jb@isonoe]> readelf -A platform-mini6410/root/bin/busybox Attribute Section: aeabi File Attributes Tag_CPU_name: "ARM1176JZF-S" Tag_CPU_arch: v6KZ Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_VFP_arch: VFPv2 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align8_needed: Yes Tag_ABI_align8_preserved: Yes, except leaf SP Tag_ABI_enum_size: int Tag_ABI_HardFP_use: SP and DP Tag_unknown_44: 1 (0x1) Tag_Virtualization_use: Allowed And yes, an ARMv4 program should run without any problems on an ARMv5 CPU. (like an i386 or i486 program should still run on a modern Pentium)
