how can i made MINI2440 to be web server
zlatan14
My OS is winCE.
I need to send data to pic with RS232 by typing on web and then MINI2440
get string and sent it though serial port and PIC get string and shown on
LCD.I can send the data to pic and pic to LCD .
My diagram.
LCD <<<<<< PIC <<<<<<< MINI2440 <<<<< web(if i have to type on AA on web it
must be shown on LCD)
ps.The data that i send from MINI2440 to pic by using serial port.
Question
1.If i want to typing from web and the MINI2440 must be web server or web
application?
2. I don t know how to make MINI2440 can be web server or web application?
3.Is there another to use mini2440 to be server?
Thank you.
Screwface
Hi zlatan,
If you use the factory root image on the mini, there is already a working
webserver. It is boa? You can put your webpages in /www directory. Of
course, if you want to be able to write on LCD, you will have to create
your own interface.
Why do you want to use a PIC to drive your LCD? Maybe you can drive it with
the mini!
Bye
zlatan14
My reason that I have to use pic.
I have to use more port and in the future I may be use xbee to send data
from mini2440 to pic.But now I still use serial port.
My question.
1.Boa can run on windowCE or linux?
2.If I need to use serial port on linux do u have command on serial port?
3.So how can I make file from C on linux?
Thank you.
Alexey_
are you using DAC or ADC on the pic?
Screwface
Boa runs on Linux, If I remember well, there is also a webserver in
WindowsCE but I don't know WinCE very well as it seems to be more difficult
to me.
If you want to use the serial port in Linux, you have to write your
commands to /dev/ttySx "file".
You will have to use open, read, write, close. Maybe you can find examples
on the mini DVD or googling a  bit.
zlatan14
Thank you for the answers.
i have ubuntu-10.11-i386 can i use this to run command in linux and cross
compile to mini2440?
Screwface
Yes I think you can. I use Fedora x64 but it should be ok with ubuntu x86
zlatan14
Thank You
catt
hi..i face problem when i communicate serially xbee to con1 of
mini2440.That xbee can send data serially to laptop. however,the data
cannot send serially to mini2440..can anybody help me please..
raja
hi every one...can any one tell me " what are the servers that mini2440
supports like boa ....
in my project iam using sensors like temp, pressure,Ldr, humidity,gas
sensors connected to my mini2440 board. now i have to send these sensors
data on to the web..
can i do it with boa web server or with my sql web server or any other ser
is best....plz give me ur valuable suggestions..
 and also tell me how implement that web server with mini2440 board...
thanks a lot
I think for Boa you have to write CGI scripts.  I never bothered.  I use
thttpd with PHP to send my sensor data.
Writing PHP scripts is very similar to C. Try searching for <thttpd php>
and you should find a HowTo I wrote, on this site.
People have tried Apache and there are several very long threads on here,
but I don't know how successfully.
One nice thing about PHP is that you can modify the script on the mini2440
and see an immediate result . . . good or bad!
sean_h
Hi
I managed to get Boa to run on Mini6410 platform by:
On Target: edit /etc/boa/boa.conf file:
Port 8000
User nobody
ServerName www.xyz.com
On target, tftp cgitest.cgi (see later) from host to:
/var/www/cgitest.cgi
On target cd /usr/sbin
./boa &
From host: http://target_ip_address(dotted quad):8000/cgitest.cgi
Read the following excellent tutorial for cgitest.cgi at:
www.ibm.com/developerworks/linux/library/pa-migrate4/
Regards
Ryuk
Hi
I have a problem about serial communication between COM1(RS232) on mini2440
and Xbee.
I can send data between Xbee and PC(physical RS232 port) or latop (Prolific
USB-Serial Converter). Also between COM1 port (232) on mini 2440 and PC or
laptop.
But when I try to send data between Xbee and Com1(232)port on mini2440
I canīt get data on both sides.
Can anybody help me, I've spended so much time on this.
Thank you
Regards
Juergen Beisert
Host <-> Minii2440 is a host to device connection. Also host <-> Xbee seems
a host to device connection in your case. But you need a different cable to
make a device <-> device communication work.
Ryuk
Ok, serial cable was the problem, If you need to connect serial port 232 on
mini 2440 (DCE) with another device (e.g. xbee(DCE)), you need a cross
female - female cable. It let us to connect two serial ports DCE.
I hope it helps somebody.
voiconvuive
hi all,
i wanna read adc an0 on mini2440 in cgi script, i use shell bourne scritp
to write.
Please hellp me read adc and send to web server
Thank in advance.
First, you have to decide which distribution you are going to use. The
FriendlyArm distro has got Boa, which accepts CGI scripts.  Then go to this
site:
http://www.pengutronix.com/oselas/bsp/pengutronix/mini2440_bsp_en.html
and grab a copy of:
OSELAS.BSP-Pengutronix-Mini2440-Quickstart.pdf
and read the ADC section.  You may need to re-compile the FriendlyArm
kernel (it has been so long since I used it).
A second option is to use the Pengutronix mini2440 BSP.  It will take
awhile to setup, BUT once you have got it working adding and changing stuff
becomes a lot easier.  You could then tick the "thttpd" box and still write
your script in CGI.
Why do you have to use CGI?
voiconvuive
hi davef,
thank for your help.
I use friendlyarm mini2440 and i cant find
/sys/devices/platform/s3c24xx-adc/s3c-hwmon/in0_input.
I use CGI because i see in /www folder has file leds.cgi on mini2440.
That's a sample demo which control led via String be sent from "submit
button" HTML.
Therefore, i think i can use bourne shell to write application read adc.
Please help me.
voiconvuive
I see on mini2440 has a demo read Voltage from AN0 and display touchscreen
but i dont know how do it work?
Because FriendlyArm's example uses kernel calls (ioctl) instead of
userspace (sysfs) calls.
The 2.6.32.2 kernel would need to be re-compiled with right boxes ticked in
kernel config.
Save yourself a lot of time and learn to use the Pengutronix BSP, unless
you really want to do everything from scratch.
rss
iam using mini 2440 wince in it
as i was working on web server my telnet ,ftp are working fine but when i
am typing ip address of my device on IE it was not opening the page why
pls can any body tell me
rss
yes its working the page had opened....
