Dhruv Dhruv Hi all, plz help me out, everything seems to be fine but nothing is cumin up in display.... my LCD is NEC 3.5" 1GB Nand Bootarguments: bootdelay=3 baudrate=115200 ethaddr=08:08:11:18:12:27 ipaddr=10.0.0.111 serverip=10.0.0.4 netmask=255.255.255.0 usbtty=cdc_acm mtdparts=mtdparts=mini2440-nand:256k@0(u-boot),128k(env),5m(kernel),-(root) mini2440=mini2440=0tb bootargs_base=console=ttySAC0,115200 noinitrd bootargs_init=init=/sbin/init root_nand=root=/dev/mtdblock3 rootfstype=jffs2 root_mmc=root=/dev/mmcblk0p2 rootdelay=2 root_nfs=/mnt/nfs set_root_nfs=setenv root_nfs root=/dev/nfs rw nfsroot=${serverip}:${root_nfs} ifconfig_static=run setenv ifconfig ip=${ipaddr}:${serverip}::${netmask}:mini2440:eth0 ifconfig_dhcp=run setenv ifconfig ip=dhcp ifconfig=ip=dhcp set_bootargs_mmc=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_mmc} set_bootargs_nand=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_nand} set_bootargs_nfs=run set_root_nfs; setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_nfs} ${ifconfig} mtdids=nand0=mini2440-nand bootcmd=mmcinit ; ext2load mmc 0:2 0x31000000 uImage ; bootm 0x31000000 bootargs=console=ttySAC0,115200 root=/dev/mmcblk0p3 rootfstype=ext3 mini2440=0tb rootdelay=3 init=/system/bin/init partition=nand0,0 mtddevnum=0 mtddevname=u-boot Environment size: 1198/131068 bytes MINI2440 # and following is my console output U-Boot 1.3.2-mini2440 (May 25 2010 - 19:15:21) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: 1024 MiB Found Environment offset in OOB.. USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:08:11:18:12:27 Hit any key to stop autoboot: 0 mmc: Probing for SDHC ... ===============> MMC CMD Timeout mmc: No answer to CMD8 trying SD trying to detect SD Card... Manufacturer: 0x1b, OEM "SM" Product name: "SD ", revision 1.0 Serial number: 3914402499 Manufacturing date: 5/2008 CRC: 0x00, b0 = 1 READ_BL_LEN=15, C_SIZE_MULT=7, C_SIZE=3453 size = 2329935872 SD Card detected RCA: 0xb368 type: SD 2060444 bytes read ## Booting kernel from Legacy Image at 31000000 ... Image Name: Linux-2.6.27 Created: 2011-08-22 15:03:19 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2060380 Bytes = 2 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux........................................................................... ........ Linux version 2.6.27 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) 1 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 Machine: Mini2440 development board Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) MM: CPU does not support supersection mapping for 0x55000000000 at 0xf0d00000 S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz S3C24XX Clocks, (c) 2004 Simtec Electronics CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0,115200 root=/dev/mmcblk0p3 rootfstype=ext3 mini2440=0tb rootdelat irq: clearing pending status 02000000 irq: clearing subpending status 00000002 PID hash table entries: 256 (order: 8, 1024 bytes) timer tcon=00500000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57 Console: colour dummy device 80x30 console [ttySAC0] enabled Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60188KB available (3896K code, 636K data, 116K init) SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok net_namespace: 288 bytes NET: Registered protocol family 16 S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4800000, irq 33 DMA channel 1 at c4800040, irq 34 DMA channel 2 at c4800080, irq 35 DMA channel 3 at c48000c0, irq 36 S3C244X: Clock Support, DVS off SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 ...stripped-down
need help on android bootup
Looks like a pretty old Linux kernel. Have you been "through the hoops" setting up u-boot for 1GB NAND. Also, how have you partitioned your SD card?
The 1GB SD Card is partitioned to: 1. Partition 1: LINUX-SWAP 512mb 2. Partition 2: EXT2 20 mb 3. Partition 3: EXT3 approx 480mb wat do u mean by "Have you been "through the hoops" setting up u-boot for 1GB NAND.", coz i have used d uboot from http://sites.google.com/site/belina76/android-booting
actually i have configured kernel as per NEC 3.5" LCD display along with its default config, coz i was suspecting the kernel image to be config for T3.5 LCD.
U-Boot 1.3.2-mini2440 (May 25 2010 - 19:15:21) I2C: ready DRAM: 64 MB Flash: 2 MB NAND: 1024 MiB Found Environment offset in OOB.. USB: S3C2410 USB Deviced In: serial Out: serial Err: serial MAC: 08:08:11:18:12:27 Hit any key to stop autoboot: 0 mmc: Probing for SDHC ... ===============> MMC CMD Timeout mmc: No answer to CMD8 trying SD trying to detect SD Card... Manufacturer: 0x1b, OEM "SM" Product name: "SD ", revision 1.0 Serial number: 3914402499 Manufacturing date: 5/2008 CRC: 0x00, b0 = 1 READ_BL_LEN=15, C_SIZE_MULT=7, C_SIZE=3453 size = 2329935872 SD Card detected RCA: 0xb368 type: SD 2060444 bytes read ## Booting kernel from Legacy Image at 31000000 ... Image Name: Linux-2.6.27 Created: 2011-08-22 15:03:19 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2060380 Bytes = 2 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux........................................................................... ........ Linux version 2.6.27 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) 1 CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177 Machine: Mini2440 development board Memory policy: ECC disabled, Data cache writeback CPU S3C2440A (id 0x32440001) MM: CPU does not support supersection mapping for 0x55000000000 at 0xf0d00000 S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz S3C24XX Clocks, (c) 2004 Simtec Electronics CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on CPU0: D VIVT write-back cache CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256 Kernel command line: console=ttySAC0,115200 root=/dev/mmcblk0p3 rootfstype=ext3 mini2440=0tb rootdelat irq: clearing pending status 02000000 irq: clearing subpending status 00000002 PID hash table entries: 256 (order: 8, 1024 bytes) timer tcon=00500000, tcnt a4ca, tcfg 00000200,00000000, usec 00001e57 Console: colour dummy device 80x30 console [ttySAC0] enabled Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 64MB = 64MB total Memory: 60188KB available (3896K code, 636K data, 116K init) SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 Calibrating delay loop... 201.93 BogoMIPS (lpj=504832) Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok net_namespace: 288 bytes NET: Registered protocol family 16 S3C2440: Initialising architecture S3C2440: IRQ Support S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics DMA channel 0 at c4800000, irq 33 DMA channel 1 at c4800040, irq 34 DMA channel 2 at c4800080, irq 35 DMA channel 3 at c48000c0, irq 36 S3C244X: Clock Support, DVS off SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 NetWinder Floating Point Emulator V0.97 (double precision) ashmem: initialized NTFS driver 2.1.29 [Flags: R/W DEBUG]. yaffs Aug 22 2011 20:29:48 Installing. msgmni has been set to 117 io scheduler noop registered (default) Console: switching to colour frame buffer device 30x20 fb0: s3c2410fb frame buffer device adc initialized input: buttons as /class/input/input0 buttons initialized leds initialized s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = ...stripped-down
buttons initialized leds initialized s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 brd: module loaded loop: module loaded nbd: registered device at major 43 logger: created 64K log 'log_main' logger: created 256K log 'log_events' logger: created 64K log 'log_radio' dm9000 Ethernet Driver, V1.31 Now use the default MAC address: 08:90:90:90:90:90 eth0: dm9000e at c4804000,c4806004 IRQ 51 MAC: c3900934 (friendly-arm) usbcore: registered new interface driver zd1211rw usbcore: registered new interface driver zd1201 Linux video capture interface: v2.00 ovcamchip: v2.27 for Linux 2.6 : OV camera chip I2C driver usbcore: registered new interface driver ov511 ov511: v1.64 for Linux 2.5 : ov511 USB Camera Driver Driver 'sd' needs updating - please use bus_type methods S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c2440-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit) NAND_ECC_NONE selected by board driver. This is not recommended !! Scanning device for bad blocks Bad eraseblock 1888 at 0x0ec00000 Bad eraseblock 3186 at 0x18e40000 Bad eraseblock 5363 at 0x29e60000 Creating 4 MTD partitions on "NAND 1GiB 3,3V 8-bit": 0x00000000-0x00060000 : "supervivi" 0x00060000-0x00260000 : "Kernel" 0x00260000-0x40260000 : "root" mtd: partition "root" extends beyond the end of device "NAND 1GiB 3,3V 8-bit" -- size truncated to 0x0 0x00000000-0x40000000 : "nand" s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes mice: PS/2 mouse device common for all mice usbcore: registered new interface driver appletouch input: s3c2410 TouchScreen as /class/input/input1 s3c2410 TouchScreen successfully loaded S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver s3c2440-i2c s3c2440-i2c: slave address 0x10 s3c2440-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter mapped channel 0 to 0 s3c2440-sdi s3c2440-sdi: powered down. s3c2440-sdi s3c2440-sdi: initialisation done. s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). usbcore: registered new interface driver hiddev s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver UDA1341 audio driver initialized failed to get memory region resouce s3c2410-iis: probe of s3c2410-iis.0 failed with error -2 s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz). TCP cubic registered NET: Registered protocol family 17 RPC: Registered udp transport module. RPC: Registered tcp transport module. s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz). mmc0: new SD card at address b368 mmcblk0: mmc0:b368 SD 993792KiB mmcblk0: p1 p2 p3 s3c2410-rtc s3c2410-rtc: setting system clock to 2011-08-20 07:48:43 UTC (1313826523) Waiting 3sec before mounting root device... kjournald starting. Commit interval 5 seconds EXT3 FS on mmcblk0p3, internal journal EXT3-fs: mounted filesystem with ordered data mode. VFS: Mounted root (ext3 filesystem). Freeing init memory: 116K init: cannot open '/initlogo.rle' init: cannot find '/system/bin/playmp3', disabling 'bootsound' sh: can't access tty; job control turned off / # warning: `rild' uses 32-bit capabilities (legacy support in use)
u-boot with 1Gb has been a source of problems for many people, but if u-boot from that site works then that's great. Things that look suspect to me: < Kernel command line: console=ttySAC0,115200 root=/dev/mmcblk0p3 < rootfstype=ext3 mini2440=0tb rootdelat what is delat? Shouldn't that be rootdelay? I see in the top posting you have rootdelay. Doesn't sem to be reported correctly. < Creating 4 MTD partitions on "NAND 1GiB 3,3V < 8-bit": < 0x00000000-0x00060000 : < supervivi" < 0x00060000-0x00260000 : < "Kernel" < 0x00260000-0x40260000 : "root" I expected to see: u-boot, env, kernel and root. As per this line at the top: < mtdparts=mtdparts=mini2440-nand:256k@0 < (u-boot),128k(env),5m(kernel),-(root) As you are using u-boot and evidently have a uImage I don't know why there is Supervivi above. good luck. davef
thanks for ur feedback...do u have images for kernel rootfs and uboot for 1GB Nand wit N3.5 lcd.. or can u guide me wit how to a build correct one.
