Hi I think my FriendlyARM (tiny6410) may be faulty I downloaded the two dvds from this site but cannot get any image to load from a SD card. It will boot from the internal nand flash but not from a SD card. I have tried 3 sd cards and two different computers and different readers When I boot from SD card I either get nothing from the terminal or a BEEP BEEP BEEP BEEP and an error saying block 0x0 is bad. Also three leds flash. As I said before I have tried a 2GB Kingston Memory 4GB And 8GB Peak In fact the 2g Kingston will now not read in any computer so it seems to have corrupted it. I am using windows 7 and I run SD-Flasher in Administrator Mode and it says it has fused the SDCard but no boot? Also led 1 does not light. Is it something I am doing wrong or could it be a faulty SDCard Socket ?
Can't Boot From SDCard
Is the bootloader enabled to load from an SD card? Is the SD card partitioned correctly? I wasn't aware that Supervivi could load from an SDcard, maybe that's changed in the mini6410.
Jumped in a bit fast. Does SD-Flasher create the kernel and rootfs partitions? Think your bootloader needs to be SD aware. Does SD-Flasher handle this?
Ok I went out and bought another two 8gb SD cards sandisk and intergral And another card reader After another couple of hours I find no mater what image I try to "INSTALL" from the sd card I have no success But I can "RUN" Linux and Android from the SD card. I need to be able to run win CE6 on the tiny 6410 but am having no luck. I need some way of getting a WORKING image running from either the nand or the SD. I am using the images downloaded from this FTP server.. Thanks SImon
Can't help if you don't answer my questions. At least tell the forum what instructions you following!
I used the 6410 guide for dummies and the card does get partitioned. I ran the sd-flasher on the 8gb card and copied over all the images IE the whole content of the images directory to the sd card. I then altered the friendlyarm.ini to "install" "CE6" all the leds flash and the beeper sounds. If I set it to "Run" I get ID Err Unpacked NK.bin... Unpacked NK.bin Finished but there is no display. If I try "Install" for any OS it beeps and all LEDs flash If I try to "Run" any OS It only successfully runs Linux , Android loads but all the apps fail..
simonf, Have you searched for <NK.bin> and <no display>? Think there were a few threads re NK.bin Sorry, I can't help, as I haven't got a 6410 variant. Good luck.
The first sign of a correct SD card format is the single beep after powering up. If it does't beep, something is wrong. Nevertheless, to see the status of powering up, attach a serail cable to the serial0 of mini6410 and the other end connect it to your PC. With the use of Hyperterminal or minicom, you should be what is happening.
"The first sign of a correct SD card format is the single beep after powering up. If it does't beep, something is wrong." I don't Get the single beep and yes I have connected the com0 lead. If I change the action to "Install" with any image I get a constant Beep Beep Beep Beep and all four leds flash this is with 4 different makes of sd card. If I set it to "RUN" the linux image runs fine but if I change to CE6 I get ID Err Unpacked NK.bin... Unpacked NK.bin Finished but there is no display. Is there an easy way to install CE6 from the console ??
I presume you have followed the guides properly to flash/format/initialize the SD card and etc. 1) Did you switch S2 to Nand?
"I presume you have followed the guides properly to flash/format/initialize the SD card and etc." Yes I used SD-flasher and it partisioned the sdcard 1) Did you switch S2 to Nand? Yes I switched s2
In your previous message, you said in "install" mode, you got constant beeps. What messages did it show on screen through the serial cable? My experience tell me that the "run" is not as robust as the "install" mode. So I normally use "install" mode. i can't confirm for you that your SD reader is faulty. However, if you are confident that the SD partition and images have been done accordingly, it is very likely that the SD reader is out of order. My suggestion is, use the serial cable to check the state of reading images from the SD card. Also have you ever changed the u-boot? If you can, do contact the supplier.
Hi, I have EXACTLY the same issue this guy has. I´m using windows 7, 4gb kingston sd. - did all the manual stuff. - formated, fused, copied images. Using superboot. - linux and android run using "run", android fails apps - ubuntu does not run - windows CE does not run - "install" does not work, beeps forever with all leds flashing. - "install" in linux shows "ID err" at terminal. Any ideas? []s , Ricardo Mello
Same behavior here. Mine is tiny6410 too, the new revision with 2Gb MLC and con1/con2 connectors available. - no beep when booting - when I try "install" I get beeps and that's it. - when I try "run" it starts booting but then fails with kernel panic... From what I got reading the forums it's because these kernels do not support 2Gb flash. Tries all the images, same thing for all of them except CE6, it just sends "Unpacked NK.bin Finished" and stops - when I try "CheckOneButton=Yes" I only get ID Err on the console, then it hangs.
Hi All Problem Fix . Please Use The SuperBoot That Came With The DVD-B With Mini6410 ."ANY RELEASE IS Different From another" For Example I used 20100808 Version On 20111116 and It Did not Work. Also There Is no Wrong On any SD cart You Use . If SD-Flasher Fuse It , it means That You Got Your SD Cart Up and Running . 1.Flash Your SD CART With SD-Flasher : 1-1 : Insert The SD-CART and Run SDFlasher After Your computer Recognized The SD-Cart *Important 1-2 : Run Scan Then If Your Cart Seed Not Available Run , Relayout On The Bottom of the Program . 1-3 : Run Scan Again and It Will Show Yes On Available,s . " Please Load SuperBoot File Before Fusing Your File." *Important 1-4 : Fuse It . '--------------- until Now You Got Your SD Cart Running ------------- Copy The Code Below To The Text File And Rename It To FriendlyARM.INI <Code> #This line cannot be removed. by FriendlyARM(www.arm9.net) CheckOneButton=No Action=install OS= WindowsCE6 VerifyNandWrite=No StatusType = Beeper| LED #################### Linux ##################### Linux-BootLoader = Linux/u-boot_nand.bin Linux-Kernel = Linux/zImage_n43 Linux-CommandLine = root=/dev/mtdblock2 rootfstype=yaffs2 init=/linuxrc console=ttySAC0,115200 Linux-RootFs-InstallImage = linux/rootfs_qtopia_qt4.img Linux-RootFs-RunImage = linux/rootfs_qtopia_qt4.ext3 ################### WindowsCE6 ################# WindowsCE6-Bootloader= WindowsCE6\nboot_n43.nb0 WindowsCE6-BootLogo = WindowsCE6\bootlogo.bmp WindowsCE6-InstallImage = WindowsCE6\NK_N43.bin WindowsCE6-RunImage = WindowsCE6\NK_n43.bin ################### Android #################### Android-BootLoader = Android/u-boot_android.bin Android-Kernel = Android/azImage_N43 Android-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 Android-RootFs-InstallImage = Android/rootfs_android.ubi Android-RootFs-RunImage = Android/rootfs_android.ext3 ################### Ubuntu ##################### Ubuntu-Kernel = Ubuntu/uzImage_n43 Ubuntu-CommandLine = console=tty1 console=ttySAC0,115200 init=/linuxrc Ubuntu-RootFs-RunImage = Ubuntu/rootfs_ubuntu.ext3 ############### UserBin part ################# UserBin-Image=WindowsCE/NK.nb0 userBin-StartAddress=50100000 </Code> '------------------------------------------------------------------ 2-COPY The Appropriate File Which Is Wince Images . Folder -> WindowsCe6 Files Under WindowsCe6 -> NK_n43.bin + bootlogo.bmp + nboot_n43.nb0 ( The Original Ones Maybe With "I" Rename Them . File -> FriendlyARM.ini File -> SuperBoot(*your Own Version).bin '-----------------End Of part 2----------------------------------------- 3- Insert The Sd cart Then Turn It on Nor Flash . switch On In the Screen You will see The Installation Presses after it Finished . Turn The Device On NAND Flash and We are Done . "All OF This Article Will Be On LZADEH.COM For PERSIAN USERS" AND IF ANY Question,s I will Answer Them On The MINI2440 Page Of Facebook.
Hi, I have followed the same method to try to flash my Tiny6410 but I am getting the same error as simonf. All 4 LEDS flash while the buzzer produces a continuous beeping sound. Here is the steps that I took: 1. Fusing the SD card as above. 2. Setting in the FriendlyARM.ini: Action=install OS= linux 3. Set S2 config switch to SD-Boot 4. Insert SD card 5. Power on. 6. Beeping and flashing LEDs error. When I set Action=run, the system boots up fine. I am using a 4GB SD card if that makes a difference.
Hello kzcho, Which SD card are you using? Even I faced same problem, I tried with multiple cards and at the end it worked with trancend 8 GB Class 2 card. Thanks
Most of the Tiny6410 on SDKs have 2G flash. There is another directory on DVD 'B' that just has .ini files for SLC Flash. You need to use those (and a superboot if there is one in that directory). Fuse the SD with the same version of superboot that is in the images directory of your SD and make sure that is the same version listed in the friendlyarm.ini script. The beep beep beep.... means wrong files for 2G flash.
I bought in March tiny210 sdk1, I also have a problem with booting from sd card. I tested the micro sd kingston 2gb, transcend 2gb Board type: 2 ERROR: Media attach failed Install or Run in the ini file, the same result. After that, the file system on sd card goes bad, the developers superboot need to analyze in detail the work, or at least recommend a specific type of sd card. Pratik, You used the sdhc 8gb? what is your board?
I am using Windows 7 with 64 bits. SanDisk 16Gb. SD-Flasher.exe reports followings: For Relayouts - Relayouting, please wait... 0 Total, 0 Succeeded, 0 Failed ---- For scan - Scanning... Found 0 Disk(s) ---- I have no problem to see the 15gb flash from Windows 7 to copy files over and reformatted. Everything works fine. But SD-Flasher could not see it. Because it is 16gb? What is correct size of flash should used with tiny6410? Thanks, Howard
Hello guys, I am new comer in friendlyarm world. I got my friendlyarm tiny 6410sdk yesterday and I started it up. icons where marked with question marks and then I tried to install linux. I followed this steps: 1. Putting superboot-6410.bin on the SD card with the SD-Flash tool(i downloaded the sd-flasher on the website in downloads 2. I have copied the images directory from the DVD which came along with the board (so, the SD card contains a "images" directory in the root, under that "Android" directory, "superboot-6410.bin" and "FriendlyARM.ini" (I'm putting the contents of the ini file at the end of this post) 3. Inserting the SD card to the reader slot 4. Putting S2 switch to "SD-boot" state 5. Power on and what I got is exactly one beep, LED 4 blinking and That is all. The board stays in this state. I stoped it and I tried to boot now from nand but I got just the symbol of linux on the screen and LED D1 alight and that's all. I realy don't know how can I proceed to get a linux fonctionning os on it? ekhlesiaste.
Follow thse instructions for installation to NAND. http://www.minidevs.com/minidevs/info202.html Dave...
Hi guys, first, I'd like to thank you for your contribution. I tried to follow instructions as indicated but when I tried to boot from sd-card, I just got a log: Superboot-6410 ver: 1146 CPU: S3C6410 533MHz RAM: 256MB NAND: 2GB(MLC2) ID:ECD58472 Touch Device: 1-wire LCD Type: H43(Auto) and when I tried to boot from nand-flash i got another long log. when i read it, i saw a part saying : s3c-fimc: i2c transfer error four times. as I told you i don't realy know anything about embedded architecture. i would like to know what does it mean and how can I do? excuse me for my english. ekhlesiaste...
I'am just seing another thing in the log: /init: line 103: can't open /r/dev/console: no such file Kernel panic - not syncing: Attempted do kill init!
I had the same problem. The solution was to compile kernel with initial ram filesystem disabled (the option in general system section of config menu). ROOTWAIT should be also used in BOOT parameters.
Thanks guys, I tried the procedure of ArturW and it and it works.but the problem now is the calibration. I calibrate the screen using the touchscreen calibrate interface but it is steel line-streaked and some words are illegible. please have you an idea of how to solve the problem? thanks
Hi,Every One, Just I received the Tiny6410 board.When I turn power on in S2(NAND) mode all the icons on screen appears with question marks(except ADC and Recorder )simultaneously connected to PC host through serial port kernel booted properly.I can see the console [root.FriendlyARM] # I tried boot through SD card could not succeed.Followed all steps said in http://www.minidevs.com/Tiny6410/Bootloader.html but no booting nor even buzzer beeps and all LEDs-1,2,3,4 a dim glow. Please help me.
Hi,every one I bought a new Tiny 6410.And followed all the above procedures for flashing and then copied the image of android,friendly ARM.ini and Superboot.in files.But when i put the SD card and start i Couldn't hear any beep sound and only LED1,LED4 are switchd on.I can see only the Boot Parameters on the screen.Please help me.
Hi See this topic http://www.friendlyarm.net/forum/topic/5144
Hi every one, i bought OK6410. finding difficulties in boot from SD card. usb driver is not recognized. i think my antivirus in the system corrupted the file. can anybody tell me how to get usb driver for OK6410 board? i lost my dvd also. Bala
