Hi, I have compiled mplayer for the Mini2440. I can play music very well. But when I play video , I have some issue. I try to play the panda.mpg video that is in the Qtopia file system. The video is 300x168. When I run the video with : ./mplayer panda.mpg -framedrop -quiet -vf -vo fbdev2, there is no problem. But when I try to resize the video, the video is too slow and there is a lag. I think that the s3c2440 has no hardware unit for the frame resizing. I know that here is options that can accelerate the video as -vfm ffmpeg -lavdopts lowres=1:fast:skiploopfilter=all, but with this solution I can't choose the size of the video. Does someone have an idea in order to solve this problem. mplayer use ffmpeg for the video and the audio.
Mplayer is too slow !
Tutorial on the compilation of Mplayer for Mini2440 available on http://ultimatewebfree.kinssha.org/index.php/tutorielmini2440 The tutorial is in french, but I will translate it english when I have the time.
BSP: Board Support Package. ;-) Refer http://www.oselas.com/oselas/bsp/pengutronix/mini2440_bsp_en.html
Ok it's what I thought. And what do you want to do ? Put the whole tutoriel on the BSP or just take the steps ?
Using your build rules to enable other users to get the same result you got, but without all these manual steps. And some of your findings I would like to add to the BSP manual.
Yes no problem, but pay attention to the modifications to do in the makefile and motion file. If you wrote a "Thanks to" section think to my name !
I am not able access the link "Tutorial on compilation of mplayer on mini2440" Does anybody know the alternative link?
Does anyone have the tutorial that was referenced here? I am needing to put mplayer on a mini2440 to play audio files and can not figue out how to do it...
The tutorial is available here : http://sigmapic.free.fr/index.php?option=com_content&view=article&am...
Hi to *Baby* I read your tutorial and it work for panda.mpg very good with small size but when I run for 239:319 with this command it is so slow. mplayer /udisk/panda.mpg -vo fbdev2 -quiet -vf rotate=1, scale=239:319 what is your way for solving this problem?
