Hi all, i got a problem i am able to run opencv in mini2440 but the problem is not all the functions like cvWaitKey(), cvCaptureFromCAM() etc. what could be the reason ...?? i am using the following specifications ... on host machine <<<< ------ ubuntu 10.04 opencv2.1.0 cmake 2.8.0 gcc 4.4.3 on target machine <<<< ----- mini2440 vivi bootloader kernel 2.6.32 qutopia 2.2.0 uvc compatible webcam i also checked with microsoft webcam too ... but no use. did any one have the solution/suggestion ...??
OpenCV on mini2440
Your system don't have gtk,so it can't show windows. But we seldom use gtk in ARM-linux. QT is a good choice,but i don't know how to deal with it,either.
@punith can u please post the steps on how u compiled opencv for arm and how u ported the program on mini2440
Hi, Maybe it helps you (you have to use translator): http://lukasz-skalski.com/index.php/opencv/linuks-embedded-w-cyfrowym-pr... Lukasz Skalski www.lukasz-skalski.com
hai when i try to run the opencv file on mini244o i get this error #armtest i get #armtest:error while loading shared libraries:libcv.so.4:cannot open shared object file:No such file or directory
