Hi, if I connect a usb mouse after the QT application has already started, the mouse won't be recognized by the QT application. My variable QWS_MOUSE_PROTO is as follows: export QWS_MOUSE_PROTO="Tslib:/dev/input/event1 MouseMan:/dev/input/mouse1" If I connect the mouse before I start my QT app, everything works fine (touchscreen + mouse). How can I solve this problem? Regards, Markus
QWS_MOUSE_PROTO: Connect USB mouse after start of QT app
Using the kernel and rootfs built with PTdist 2011.07.0 mine does. Maybe, export QWS_MOUSE_PROTO="IntelliMouse:/dev/input/mice Tslib:/dev/input/event1 Have you got "mice"? That works as well as the stylus. Maybe, mouse will work in your case. HTH, Dave
Hi Dave, yes, this works, but it causes another problem. The touchscreen events and the mice events bite one another. The effect is that the mouse pointer moves some pixels around the point at which I press the stylus. And often the mouse pointer jumps to a different control. I also use ptxdist 2011.07.0. and the last BSP from pengutronix. Regards, Markus
Mine seems to track well if I press down on the screen. If I lightly touch the stylus it can be displaced, as you mention. There has been a lot of discussion on trying to get finger presses to work properly, maybe tweaking some of the variables in /etc/ts.conf or adding some other parameters. My keyboard stopped working after this experiment! Looks like even with my setup you gotta leave some of the USB devices plugged in before powering up. Good luck. Dave.
Markus, Read comment about Qt and hotplugging. I'll clarify what I did at this end. Unlpug USB mouse, fire up the board, ran a Qt /demo/browser app, stylus works, USB keyboard doesn't work (!), plugging USB mouse and it works. Keyboard still non-functional after plugging mouse in. Remove the .zip extension. Dave
Further, If I leave mouse plugged in and disconnect the keyboard as soon as I tell the app to run and plug the keyboard in after the app is running it doesn't work. The mouse keeps working. Appears to be something to do with the USB devices. My /etc/profile.environment is attached. Dave
Dave, if you point Qt to device nodes that are created only if a hotplug device appears it can't work. For the keyboard you should use a tty instead, because it collects the input events from any connected (or in future connected) device and forwards it to the app. For the touchscreen and/or mouse I guess the same happens with the "/dev/input/mice" devnode.
Hi Dave,
MINI2440_KEYEVENT=/dev/input/event3
export QWS_KEYBOARD=LinuxInput:${MINI2440_KEYEVENT}
The name of the event depends on the order of plugging in
the devices.
/dev/input/event0 -> touchscreen
/dev/input/event1 -> gpio-buttons
/dev/input/event2 -> usb-mouse or usb-keyboard
/dev/input/event3 -> usb-mouse or usb-keyboard
I use the following environment and i can plug in the
usb keyboard before or after starting the qt app.
When the app is running I can plug out an in the keyboard
and it works.
export QWS_KEYBOARD=TTY:/dev/tty1
But my problem is the mouse. "IntelliMouse:/dev/input/mice"
supports hotplugging, but the events "/dev/input/mice" and
"/dev/input/event1" disturb one another. This means the mouse
pointer moves nervy or jumps suddendly.
Here is the start script for my app.
Please test with two configurations:
1: export QWS_MOUSE_PROTO="Tslib:${MINI2440_TOUCHEVENT}
MouseMan:/dev/input/mice"
2: export QWS_MOUSE_PROTO="Tslib:${MINI2440_TOUCHEVENT}
#!/bin/sh
# Mini2440 related settings
MINI2440_FBDEV=/dev/fb0
MINI2440_KEYEVENT=/dev/input/event0
MINI2440_TOUCHEVENT=/dev/input/event1
# touchscreen relevant settings
if grep -q "mini2440=3" /proc/cmdline ; then
# this size is for the portrait 240 x 320 display of type
"TD035STED4"
# change it, if you are using another display (sizes are in [mm])
MINI2440_LCD_WIDTH=55
MINI2440_LCD_HEIGHT=71
# Rotate screen
export
QWS_DISPLAY=LinuxFb:mmWidth=${MINI2440_LCD_WIDTH}:mmHeight=${MINI2440_LCD_HEIGHT
export QWS_SIZE=240x320
echo "Display x35 (TD035STED4) Portrait mode 240x320"
elif grep -q "mini2440=5" /proc/cmdline ; then
"ACX502BMU"
# Rotate screen
export
echo "Display x35 (ACX502BMU) Portrait mode 240x320"
elif grep -q "mini2440=6" /proc/cmdline ; then
"LCDN3502"
MINI2440_LCD_WIDTH=71
MINI2440_LCD_HEIGHT=54
# Rotate screen
export
QWS_DISPLAY=Transformed:LinuxFb:mmWidth=${MINI2440_LCD_WIDTH}:mmHeight=${MINI244
0_LCD_HEIGHT}:Rot90
export QWS_SIZE=320x240
echo "Display w35i (LQ035Q1DG06) Landscape mode 320x240"
fi
export TSLIB_TSDEVICE=${MINI2440_TOUCHEVENT}
export TSLIB_CONSOLEDEVICE=none
export TSLIB_FBDEVICE=${MINI2440_FBDEV}
#export TSLIB_CALIBFILE=/etc/pointercal
#export TSLIB_CONFFILE=/etc/ts.conf
#export TSLIB_PLUGINDIR=/usr/lib/ts
#export QWS_MOUSE_PROTO="Tslib:${MINI2440_TOUCHEVENT}
#export QWS_KEYBOARD=LinuxInput:${MINI2440_KEYEVENT}
Regards,
Markus
Juergen, Thanks for that clarification. I hadn't ticked that box during my Qt browser build. Next time I build it I'll give it a try. It is not a problem for me I just leave the keyboard and mouse plugged in all the time :) Dave
Markus, Your post slipped in while I was answering Juergen. Did test 1 and 2. Test 1 behaves normally for me. The second one the mouse is OK, but the stylus causes the cursor to jump to random places across the screen. Do you expect me to do anything with the script or is it just for my information? Dave
Dave,
My stylus causes the cursor to jump with the first test
( /dev/input/mice ). Did you mean the same?
The script was just for your information.
Markus
Dave, Markus, you should try without the touchscreen as a devnode. Only try with the mice device and enable the touchscreen-to-mouse-emulation in the kernel. Maybe this would help you to work with one device only.
Juergen, export QWS_MOUSE_PROTO="MouseMan:/dev/input/mice" The usb mouse works as expected, but the cursor doesn't follow the stylus. The cursor moves somewhere on the screen Markus
Hi Markus, it works as I promised. But it needs very strange patches of the touchscreen driver. For example X and Y positions have to be swapped and the Y position must be inverted. And INPUT_MOUSEDEV must be Y and INPUT_MOUSEDEV_SCREEN_X/INPUT_MOUSEDEV_SCREEN_Y must contain your screen resolution (so, one kernel cannot be used for different screen sizes). But after these changes Qt can work with only the 'export QWS_MOUSE_PROTO="IntelliMouse:/dev/input/mice"' for both input devices. And you can remove the USB mouse and re-attach it and it still works as expected.
Good morning, **** My stylus causes the cursor to jump with the first test ( /dev/input/mice ). Did you mean the same? **** No. The first test behaved like my setup. You do have to firmly press with the stylus. If you touch the screen lightly the cursor can jump around the proper location a bit. The 2nd test was totally non-functional. The cursor would move to random places on the screen and the relationship of cursor position with respect to the mouse movement is . . . well let's say "is not apparent to me"! *** The effect is that the mouse pointer moves some pixels around the point at which I press the stylus. *** A few pixels is a pretty small displacement. I'd say my stylus contact point and the stylus track within 1-2mm on an N35 screen, with a reasonable press on the screen. Which display are you using? There could be differences in behaviour between different touchscreens. Dave
Dave, I have got three different 3.5in displays: w35i LQ035Q1DG06 x35 ACX502BMU t35 TD035STED4 All of them have the same behaviour in relation to the touch screen. The w35i has to be rotated for my app, because it's in landscape mode. Juergen, I don't know, if it is a good idea to patch the kernel driver for a dedicated display. Then I have to make different kernels for different 3,5inch displays. I only want to change the boot parameter mini2440 at barebox. Now I will just restart my app after connecting an usb mouse. So long. I won't have access to the hardware the next 3 weeks, because we make our vacation in Denmark.
hello, the usb mouse not work in mini2440 SET ENV variable is : export QTDIR=/usr/local/Qt export QWS_MOUSE_PROTO=tslib:/dev/event1 -- mouse #export QWS_MOUSE_PROTO=tslib:/dev/event0 ---touch screen export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export TSLIB_TSDEVICE=/usr/local/tslib/lib/ts export TSLIB_TSEVENTTYPE=INPUT
