I want to develop an application that use image processing like Fingerprint Recognition, Eye Detection/Recognition. I'm looking for a library to process an image. I find OpenCV by Intel but I don't know how to port on my mini2440 (ARM+linux). Does anybody know a library for processing image on ARM + (linux/wince) ?
Image Processing
You can compile OpenCV for friendly arm if you configure OpenCV like this: ./confugure --host=arm-linux --disable-shared # I disable shared libraries to simplify deployment of binaries make # builds everuthing then you can run binaries on the friendly arm, but you have to make sure that they don't require GUI to run. For example I modified to facedetect.cpp to write the output to disk, instead of displaying it in the window: compiling: arm-linux-g++ -O2 -I ../../include/opencv facedetect_noui.cpp -L../../src/.libs/ -lcv -lhighgui -lcxcore -lml -lcvaux -lrt -lpthread -ldl -lz -lpng12 -ljpeg -o facedetect Running of FriendlyARM: [root@FriendlyARM c]# ./facedetect lena.jpg --out=test.png detection time = 39033.4 ms Saving output to test.png P.S. Here is another example: http://www.computer-vision-software.com/blog/2009/03/arm-wrestling-with-...
Hello Vladimir, Did you use OpenCV for Linux in your project ? If you don't mind, can you explain step-by-step about that project? Thank you, Ito
Hello, yes, I am running Linux on FriendlyARM and Linux (Ubuntu 9.10) on my building host. I downloaded version 2.0 from http://sourceforge.net/projects/opencvlibrary/files/opencv-unix/2.0/ , unpacked it and configured it with the above settings.
Hello, just thought that you can try with this source code, to build OpenCV and compile the sample see above.
Hello Vladimir, I have followed your instruction, and I got this error message : ito@ito-desktop:~/Downloads$ arm-linux-g++ -o2 -I facedetect_noui.cpp -L/home/igi/OpenCV-2.0.0/src/.libs -lcv -lhighgui -lcxcore -lml -lcvaux -lrt -lpthread -ldl -lz -lpng12 -ljpeg -o facedetect /usr/local/arm/4.3.2/bin/../arm-none-linux-gnueabi/libc/armv4t/usr/lib/crt1.o: In function `_start': init.c:(.text+0x30): undefined reference to `main' collect2: ld returned 1 exit status What does it mean ? Thank you, Sincerely Ito
Oh, I'm sorry, my bad, I forgotto "include" the .h file..... Now i have built it successfully Thank's alot for you Bravo Vladimir.....^^ Sincerely, Ito
Hello, To Vladimir and Ito, I have followed your tutorial carefully and I can build facedetect. But when i run it in my Qtopia friendlyARM, error was occured. ERROR : Could not load classifier cascade Usage : facedetect [--cascade="<cascade-path>"] [--nested-cascade[="nested-cascade-path"]] [--scale[=<image scale> [filename|camera_index] What's wrong ? Gary
Hello Gary, he program searches for the training information , by default it is in ../../data/haarcascades/haarcascade_frontalface_alt.xml and ../../data/haarcascades/haarcascade_eye_tree_eyeglasses.xml relative to the directory where facedetect.cpp sample is. I am exporting my whole OpenCV directory to mini2440 through NFS, so all the files are found automatically. On the other hand, if you are copying facedetect binary to mini2440 alone, you will also have to copy above files. And specify them using command line. I.E. ./facedetect --cascade=haarcascade_frontalface_alt.xml --nested-cascade=haarcascade_eye_tree_eyeglasses.xml etc. if you have copied them to the same directory as your facedetect binary.
Somebody help me please. I found error. what's error? Thank you root@ultimate-laptop:~/Downloads/OpenCV-2.0.0/samples/c# arm-linux-g++ -o2 -I coding.cpp -L//root/Downloads/OpenCV-2.0.0/src/.libs -lcv -lcxcore -lhighgui /home/ultimate/Downloads/usr/local/arm/4.3.2/bin/../arm-none-linux-gnueabi/libc/ armv4t/usr/lib/crt1.o: In function `_start': init.c:(.text+0x30): undefined reference to `main' collect2: ld returned 1 exit status and this my code..... #include "cv.h" #include "cxcore.h" #include "highgui.h" #include "stdio.h" #define CamID 0 #define NameOri "Original Image" #define NamePro "Process Image" int main( int argc, char **argv ) { int i,j; int height,width,step,channel,depth; int stepr, channelr; uchar *data,*datar; i=j=0; CvCapture *CapImg = NULL; CapImg = cvCreateCameraCapture( CamID ); if( CapImg == NULL ) { puts("unable to load the frame"); exit(0); } cvNamedWindow( NameOri ); cvNamedWindow( NamePro ); IplImage *ProOriImg = NULL; IplImage *ProNewImg = NULL; do { if( ProNewImg != NULL ) { cvReleaseImage( &ProNewImg ); ProNewImg = NULL; } ProOriImg = cvQueryFrame( CapImg ); ProNewImg = cvCreateImage( cvSize( ProOriImg->width,ProOriImg->height ),ProOriImg->depth,ProOriImg->nChannels ); cvSetZero( ProNewImg ); height = ProOriImg->height; width = ProOriImg->width; step = ProOriImg->widthStep; channel = ProOriImg->nChannels; data = (uchar *)ProOriImg->imageData; stepr = ProNewImg->widthStep; channelr = ProNewImg->nChannels; datar = (uchar *)ProNewImg->imageData; for( i = 0; i < height; i++ ) { for( j = 0; j < width; j++) { if(((data[i*step+j*channel+2]) > (30+data[i*step+j*channel])) && ((data[i*step+j*channel+2]) > (30+data[i*step+j*channel+1]))) { datar[i*stepr+j*channelr+2] = 255; } else datar[i*stepr+j*channelr+2] = 0; } } cvShowImage( NameOri,ProOriImg ); //cvShowImage( NamePro,ProNewImg ); }while( cvWaitKey(1) == -1 ); if( ProNewImg != NULL ) { cvReleaseImage( &ProNewImg ); ProNewImg = NULL; } cvDestroyWindow( NameOri ); cvDestroyWindow( NamePro ); cvReleaseCapture( &CapImg ); return 0; }
Hello, it looks like you an extra -I parameter, ie replace arm-linux-g++ -o2 -I coding.cpp -L//root/Downloads/OpenCV-2.0.0/src/.libs -lcv -lcxcore -lhighgui with arm-linux-g++ -o2 coding.cpp -L//root/Downloads/OpenCV-2.0.0/src/.libs -lcv -lcxcore -lhighgui On the second thought , It looks like this form doesn't like grater and smaller signs in the body of the message, in my original text I meant that you have to specify location of OpenCV headers after -I
Hi again. I tried to get a frame from cmos camera using cvCreateCameraCapture(0). This method always return NULL that means no camera found. My CMOS camera works great. Can somebody help me ? Thanks azzido
I can't solve the problem. I tried to get a frame via V4l ioctl(videofd, VIDIOC_QUERYCAP, &cap) and the camera can't be open. Why can't get a frame using cvCreateCameraCapture ? How can I get a frame from CMOS Camera ? Many thanks.
Hello, in short, standard driver for CAM130 (CMOS camera) is not V4L compliant. For longer explanation see http://www.friendlyarm.net/forum/topic/505?lang=en
Hi Vladimir ! I've ot a couple of questions. Sorry if they are to basic but I am relatively new to Embeded Linux. My goal is to run OpenCV on TI's OMAP3530 and I have a Gumstix and a OMAP35evm board at hand. I am trying to do this. Using Ubuntu 9.04 Using CodeSourcerys toolchain Exported : export CC=/home/mkn/workspace/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueabi -gcc export CXX=/home/mkn/workspace/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gnueab i-g++ 1. Downloaded and extracted OpenCV-2.0.0 to /home/mkn/workspace/OpenCV-2.0.0 2. Cross compiled OpenCV with ./confugure --host=arm-linux --disable-shared 3. make 4. Succes Copied the /samples/c/edge.c and stripped it for GUI (see attached file) Compiled it with: arm-none-linux-gnueabi-gcc -o2 -I/home/mkn/OpenCV-2.0.0/include/opencv edge.c -L/home/mkn/OpenCV-2.0.0/src/.libs -lcv -lhighgui -lcxcore -lml -lcvaux -lrt -lpthread -ldl -lz -lpng12 -ljpeg -o edge And now I am getting into trouble (due to my lack of knowledge). So these are my questions. A. When cross compiling OpenCV where is the binaries located (libs). Not using any prefix argument. As far as I can see in the configure script it is located in /usr/lib. Are the x86 binaries overwritten now ? B. I would like to be able to develop and test apps on my host and afterwards cross compile and copy to my targets NFS. Where should I put the binaries on the target ? C. So what would be the correct command line for compiling for ARM with directives to the .h files and cross compiled libs There might be other questions but understanding of the above might get me a bit further. Your comments and help is highly appreciated. Thanks in advance. Morten 2. Cross compiled
#include "cv.h" #include "highgui.h" int edge_thresh = 128; IplImage *image = 0, *cedge = 0, *gray = 0, *edge = 0; int main( int argc, char** argv ) { char* filename = argc == 2 ? argv[1] : (char*)"left04.jpg"; if( (image = cvLoadImage( filename, 1)) == 0 ) return -1; // Create the output image cedge = cvCreateImage(cvSize(image->width,image->height), IPL_DEPTH_8U, 3); // Convert to grayscale gray = cvCreateImage(cvSize(image->width,image->height), IPL_DEPTH_8U, 1); edge = cvCreateImage(cvSize(image->width,image->height), IPL_DEPTH_8U, 1); cvCvtColor(image, gray, CV_BGR2GRAY); cvReleaseImage(&image); cvReleaseImage(&gray); cvReleaseImage(&edge); return 0; }
A. if you just configure OpenCV and then run make to build it , the binaries are not installed anywhere (i.e they stay withing the build tree). If you want to install, run "make install" and everything will be installed in /usr/local by default. You can change this location during configuration time with --prefix=..... parameter for ./configure or during installation by specifying installation directory : make install DESTDIR=..... B. I suggest that you setup the separate directories for compiling OpenCV for your pc and another one for your board, i.e create /home/mkn/workspace/pc and unpack and configure OpenCV there , and also create /home/mkn/workspace/gumstix and unpack and cofigure OpenCV there one more time. Then, for your program you can setup make file that will use one directory with all the parameters to build code for PC and another one for your board, i.e create /home/mkn/workspace/app and inside create a Makefile with something like this: HOSTCC=gcc HOSTCXX=g++ BOARDCC=/home/mkn/workspace/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-gn ueabi-gcc BOARDCXX=/home/mkn/workspace/CodeSourcery/Sourcery_G++_Lite/bin/arm-none-linux-g nueabi-g++ HOSTFLAGS=-o2 -I/home/mkn/workspace/pc/OpenCV-2.0.0/include/opencv -L/home/mkn/workspace/pc/OpenCV-2.0.0/src/.libs -lcv -lhighgui -lcxcore -lml -lcvaux -lrt -lpthread -ldl -lz -lpng12 -ljpeg BOARDFLAGS=-o2 -I/home/mkn/workspace/gumstix/OpenCV-2.0.0/include/opencv -L/home/mkn/workspace/pc/OpenCV-2.0.0/src/.libs -lcv -lhighgui -lcxcore -lml -lcvaux -lrt -lpthread -ldl -lz -lpng12 -ljpeg host: app.cpp $(HOSTCC) $(HOSTFLAGS) app.cpp -o host_app gumstix: app.cpp $(BOARDCC) $(BOARDFLAGS) app.cpp -o gumstix_app default: host gumstix Then, to build your app for the host computer you will have to type make host and for your board: make gumstix Of course, it is just a quick&dirty example. Next, to run the code on your board you can either copy it over using ftp/ssh/sd card/ and run it there. Alternatively, you can export directory with your files using NFS and mount it from the board and run binary without copying. For example, when I do this kind of things I put all my binaries to /opt/FriendlyARM , I export it using NFS: /etc/exports contains: /opt 10.0.2.5(rw,sync,no_subtree_check,all_squash,anonuid=1000,anongid=1000) where 10.0.2.5 - IP address of the FriendlyARM board, and on the board I mount it using following line in fstab: 10.0.2.1:/opt/FriendlyARM /mnt nfs noauto,nolock,wsize=512,rsize=512 0 0 then I can mount it manuall by typing mount /mnt in the console, and execute binary files from /opt/FriendlyARM without copying them. C. This seem to be correct example, doesn't it work for you?
Hi Vladimir Fonov ! I cannot locate the V4L2 library (libv4l2) on my mini2440 (kernel version 2.6.29). I have a USB camera with Vimicro chip and it is recognized by kernel. Also, I develop an application that get a capture from camera (640 x 480) using V4L2 and it works great. But when I tried to get a frame from camera using OpenCV it fails. CvCapture *CapImg = NULL; CapImg = cvCreateCameraCapture( 0 ); CamImg is allways null. I think the reason is OpenCV can't locate V4L2 library. I'm alo looking for using CvCaptureCAM_V4L(index) because it's written in V4L2. Many thanks Vladimir Fonov
Hello Irinel, "I cannot locate the V4L2 library (libv4l2) on my mini2440" basic V4L is not a library, it is interface to the kernel, using standard libc functions (open,close,read,ioctl,mmap) all you need is kernel headers to describe constants and structures during compilation time. "But when I tried to get a frame from camera using OpenCV it fails." maybe OpenCV doesn't support your type of camera? Frankly I am not using OpenCV myself so, I have very limited knowledge about it. I suggest inserting some printf's with diagnostic messages into src/highgui/cvcap_libv4l.cpp (that's where OpenCV's V4L functions are located) or compiling OpenCV and your application with debugging support, and using gdb+gdbserver to setup a couple breakpoints in cvcap_libv4l.cpp and check what is going on.
hello, I am building a project on FriendlyArm in which i will be caputuring live images and processing it onboard, is this possible on FriendlyArm as i haven't tried it yet. If yes, pls help me out on this. The project is Traffic Monitoring using Image Processing. Regards
Hi all I exactly did the steps as Vladimir has mentioned, but while running make, the following error is coming. /usr/bin/ld: /root/Downloads/OpenCV-2.0.0/src/.libs/libcxcore.a(sgetrf.o): Relocations in generic ELF (EM: 40) /root/Downloads/OpenCV-2.0.0/src/.libs/libcxcore.a: could not read symbols: File in wrong format collect2: ld returned 1 exit status make[2]: *** [opencv-haartraining] Error 1 make[2]: Leaving directory `/root/Downloads/OpenCV-2.0.0/apps' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/root/Downloads/OpenCV-2.0.0' make: *** [all] Error 2 Any help will be appreciated. Thanks
here's the full compilation log--> http://pastebin.com/UL4QRPA9
Hi I successfully cross-compiled opencv and got 4 directories generated: include bin share lib As i am running qtopia 2.2 rootfs on my board, i copied contents of the above 4 directories to those in the board fs (for eg. bin to /bin of board) Is this ok? will it work this way or do I need to make the rootfs again? Also how to test whether the opencv is working or not? PS. I'm actually a newbie :) Thanks for your help. Tan
I used the following link and installed OpenCV. http://www.linuxconfig.org/introduction-to-computer-vision-with-opencv-o... g++ and gcc commands are readily compiling but not arm-linux-gcc. I searched and found it is because of no link in the libraries. I want to use arm-linux-gcc not arm-linux-g++. Can someone please tell me a set of commands I need to execute to link the libraries.
Hi, I successfully cross compiled the OpenCV2.1.0 and got 4 directories : include bin share lib I disabled the Python support and FFMPEG. -- General configuration for opencv 2.1.0 ===================================== -- -- Built as dynamic libs?: ON -- Compiler: -- C++ flags (Release): -Wall -pthread -ffunction-sections -O3 -DNDEBUG -fomit-frame-pointer -DNDEBUG -- C++ flags (Debug): -Wall -pthread -ffunction-sections -g -O0 -DDEBUG -D_DEBUG -- Linker flags (Release): -- Linker flags (Debug): -- -- GUI: -- GTK+ 2.x: 1 -- GThread: 1 -- -- Image I/O: -- JPEG: build -- PNG: build -- TIFF: build -- JPEG 2000: build -- -- Video I/O: -- DC1394 1.x: 0 -- DC1394 2.x: 0 -- FFMPEG: 0 -- codec: -- format: -- util: -- swscale: -- gentoo-style: -- GStreamer: 0 -- UniCap: FALSE -- PvAPI: -- V4L/V4L2: / -- Xine: FALSE -- -- Interfaces: -- Old Python: 0 -- Python: OFF -- Python interpreter: /usr/bin/python2.6 -- Python numpy: -- Use IPP: NO -- Use TBB: NO -- Build Documentation 0 -- -- Install path: /tmp/openCV -- -- cvconfig.h is in: /home/astha/Desktop/OpenCV-2.1.0_arm/release -- ----------------------------------------------------------------- -- -- Configuring done Then i transfer cross compiled lib/ onto my board and run the sample program. There I tried to get a frame from Microsoft and then T-Link cameras using cvCreateCameraCapture(0).This method always return NULL that means no camera found. Both the cameras are working fine. Can somebody help me ? Its look like v4l is missing. But how to get that? and i didnt disable the V4L at the time of cross compilation. Please help...
Hi, I am able to cross compiled the OpenCV2.1.0 successfully and now its working fine with microsoft camera but its not working with T-link webcam and its giving error : "HIGHGUI ERROR: V4L2: Pixel format of incoming image is unsupported by OpenCV Unable to stop the stream.: Bad file descriptor " What can be reason and how to fix it?
hi Vladimir! First of all thank u! when I try to configure: ./configure --host=arm-linux --disable-shared bash: ./configure: No such file or directory would you tell me whats wrong! my pc os is ubuntu 10.10 and opencv 2.2 is now installed on ubuntu! on my pc every thing is fine and i can run samples. thanks again!
Many thanks Vladimir, your shared are great. I use OpenCV-2.0.0 as Vladimir share link, cross-compile = arm-linux-4.3.2. ; Ubuntu 10.10 I create 2 directory: </home/mgdaubo/micro2440/PC> for host PC, and </home/mgdaubo/micro2440/targetboard> for my micro2440 board. copy OpenCV-2.0.0 source directory to both PC and targetboard directory. #########Then I compile opencv like this: *** for host PC: follow: http://www.linuxconfig.org/introduction-to-computer-vision-with-opencv-o... *** for target board: export PATH=/home/mgdaubo/Compiler/arm-linux-4.3.2/bin #my path to compiler cd /home/mgdaubo/micro2440/targetboard/OpenCV-2.0.0 ./configure --host=arm-linux --disable-shared --with-gtk=no --prefix=/home/mgdaubo/micro2440/targetboard make install There is no error. So, in targetboard directory, 4 new directorys appeared: bin, include, lib, share. And the source code directory "OpenCV-2.0.0" i have copied before. ######## Now compile application *** Makefile is very similar to Vladimir's: HOSTCC=gcc HOSTCXX=g++ BOARDCC=/home/mgdaubo/Compiler/arm-linux-4.3.2/bin/arm-linux-gcc BOARDCXX=/home/mgdaubo/Compiler/arm-linux-4.3.2/bin/arm-linux-g++ HOSTFLAGS=-o2 -I/home/mgdaubo/micro2440/PC/include/opencv -L/home/mgdaubo/micro2440/OpenCV/PC/lib -lcv -lhighgui -lcxcore -lml -lcvaux -lrt -lpthread -ldl -lz -lpng12 -ljpeg BOARDFLAGS=-o2 -I/home/mgdaubo/micro2440/targetboard/include/opencv -L/home/mgdaubo/micro2440/targetboard/lib -lcv -lhighgui -lcxcore -lml -lcvaux -lrt -lpthread -ldl host: app.cpp $(HOSTCC) $(HOSTFLAGS) app.cpp -o host_app tget: app.cpp $(BOARDCC) $(BOARDFLAGS) app.cpp -o tget_app default: host tget *** app.cpp is very simple: #include "highgui.h" int main( int argc, char** argv ) { IplImage* img = cvLoadImage( argv[1]); cvSaveImage( argv[2] , img); cvReleaseImage( &img ); return 0; } ######## the result: host_app can be compiled and work well in host PC. But "make tget" give error: /tmp/cc1pd1lB.o: In function `main': app.cpp:(.text+0x28): undefined reference to `cvLoadImage' app.cpp:(.text+0x50): undefined reference to `cvSaveImage' app.cpp:(.text+0x5c): undefined reference to `cvReleaseImage' collect2: ld returned 1 exit status make: *** [tget] Error 1 It's seem that the linker cannot find the "include" directory. I can't understand. I try to do something: - export PKG_CONFIG_PATH=/home/mgdaubo/micro2440/targetboard/lib/pkgconfig - specify -I to source directory: -I/home/mgdaubo/micro2440/targetboard/OpenCV-2.0.0/include/opencv - specify -L to source directory: -L/home/mgdaubo/micro2440/targetboard/OpenCV-2.0.0/src/.libs Still get same error. Any idea, please help me out :((
Hi, I searched and take look at many site on internet, but still get that error. However, use the pre-compiled OpenCV files on this site, I can compile my app and run properly :D http://wiki.openarmlab.org/index.php?title=Opencv_on_mini2440
Hello, Does anybody know how to cross compile the OpenCV with ffmpeg? I'm trying: ./configure --host=arm-linux CPPFLAGS=-I/usr/arm/local/include/ LDFLAGS=-L/usr/arm/local/lib --without-python --with-ffmpeg --without-quicktime CXXFLAGS=-D__STDC_CONSTANT_MACROS But, at the end: Video I/O --------------------- Use QuickTime / Mac OS X: no Use xine: no Use gstreamer: no Use ffmpeg: no <----------- I'm getting no here Use dc1394 & raw1394: no Use dc1394_v2 & raw1394: no Use v4l: yes Use v4l2: yes Use unicap: no
Hi,guys.I've configured(./confugure --host=arm-linux --disable-shared) OpenCV for mini 2440 and it past make well,but while compilation I cannot get rid from error : /usr/local/arm/4.3.2/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.2/../../../../arm -none-linux-gnueabi/bin/ld: cannot find -lml collect2: ld returned 1 exit status I compile as follow: arm-linux-gcc `pkg-config --cflags opencv` -c video_server_arm.c -o video_server_arm.o arm-linux-gcc video_server_arm.o -o video_server_arm `pkg-config --libs opencv` -I /usr/include/opencv -lpthread /usr/include/opencv---here cv.h and highgui.h reside
hi I could compile my opencv program on my host successfully and I could make a binary file on my host (Ubuntu 9.10). now I want to port it on my board. I copied opencv directories and my binary files to root via usb diss(UDisk) but it doesn't work. where should I copy my /bin /lib /include /share folders in root ? in /opt ? where ? thank you
Well . . . first did you cross-compile opencv rather than compile it? "port it on my board", sounds like you haven't cross-compiled it. Or, do you mean place it on my board? On the host you have checked that you actually have generated ARM binaries for armv4t? <readelf -A <filename> The files in bin normally just get placed in /bin on the target. Likewise, files in lib go in /lib on the target. For a the few sources that I have cross-compiled you ignore include and share files. Also, you need to be more explicit about "but it doesn't work". Include your error messages
thank you for replying ... you are right. I should say I cross compile it and I want to place it on my board. I copied 4 folders to root and when I run the program this error appears : /lib/libcv.so.4 : file too short what does it mean ? I just followed : http://wiki.openarmlab.org/index.php?title=Opencv_on_mini2440 http://apollo.upc.es/humanoide/trac/wiki/OpenCv Would you explain more ? "On the host you have checked that you actually have generated ARM binaries for armv4t? <readelf -A <filename>"
Ah... I should say I have no ld.co.conf file in /etc and I copied my /bin directory to /bin on ARM and also /lib on /lib and ...
finally I could solve it ! I made soft links again : ln -sb And now I can run my binary file , but now I get this error : VIDIOC_Streamon : no space left on device. What should I do ? how I can reduce my process volume ? :(
Error "No space left" indicates problem with USB bandwidth? How can I solve it? I have two USB camera 640x480 connected to board via hub.
Hi there. Please help me with cross-compiling OpenCV for mini2440. I did the steps as Vladimir said but it has some errors after "make" command. Somebody knows this problem please help me, thanksss. $ tar -jxvf OpenCV-2.0.0.tar.bz2 $ cd OpenCV-2.0.0 $ make ----------------error of "make" command--------------- /usr/local/arm/4.3.2/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.2/../../../../arm -none-linux-gnueabi/bin/ld: cannot find -lgtk-x11-2.0 collect2: ld returned 1 exit status make[2]: *** [opencv-haartraining] Error 1 make[2]: Leaving directory `/usr/local/OpenCV2440/OpenCV-2.0.0/apps' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/usr/local/OpenCV2440/OpenCV-2.0.0' make: *** [all] Error 2
oh, sorry. My cross-compile is: $ tar -jxvf OpenCV-2.0.0.tar.bz2 $ cd OpenCV-2.0.0 $ ./configure --host=arm-linux --disable-shared $ make
Hi, Does one of you have a feedback ont the possibility to to live cam blob tracking sing 2440 and openCV at30 fps mini for 240*240 video size ? Thanks Fred
Hi,Guys! While "make" I get some error /usr/local/arm/4.3.2/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.2/../../../../arm -none-linux-gnueabi/bin/ld: cannot find -lgtk-x11-2.0 May be the problem in my toolchain?
Same Problem... and I thought I had the right ARM compiled version of GTK /usr/local/arm/4.3.2/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.2/../../../../arm -none-linux-gnueabi/bin/ld: cannot find -lgtk-x11-2.0 help if you can!
Same error here. Using Ubuntu 10.04, ARM-Linux GCC 4.3.2 and OpenCV 2.0.0 Did anybody find the solution?
one possible solution to remove the "cannot find -lgtk-x11-2.0" error is, check whether you installed the gtk libs on the pc or not. you can check this one in ubuntu from system package manager. if they are not installed you can install them manually from this package manager itself.. i hope this will solve your problem..
Hi all, i got a problem i am able to run opencv in mini2440 but the problem is not all the functions like cvWaitKey(), cvCaptureFromCAM() etc. what could be the reason ...?? i am using the following specifications ... on host machine <<<< ------ ubuntu 10.04 opencv2.1.0 cmake 2.8.0 gcc 4.4.3 on target machine <<<< ----- mini2440 vivi bootloader kernel 2.6.32 qutopia 2.2.0 uvc compatible webcam i also checked with microsoft webcam too ... but no use. did any one have the solution/suggestion ...??
Hi, i need to convert jpeg image to bmp image using Linux commands on ARM.. but i should not convert it on the host.. Input should is given to ARM and conversion to be seen on screen.. Please guide me..
hi, everyone !!! I have developing a project for robot trackline, use Micro2440 kit. I was tried to cross compiler Opencv 2.0 for arm, follow intrustion, but not sucessed. It take to me many time to cross compiler. I was tired.. Anyone for me the idea.. or the sloved, or can shared the library OpenCV 2.0 has cross compiler for Micro2440 ... Thanks you, so much. PS: My english is so bad. Thus, Please everyone inogre, thanks, so much.
hi, I have got the source code OpenCV 2.0 has cross compiler there. It is actived good in Micro2440. Link here : http://wiki.embeddednirvana.org/Opencv_on_mini2440 Thanks you everyone.
i have been trying to compile my simple hello world program, with opencv header on it, but the more i tried, it got the following error. always like those error displayed. //------------------------------------------------------------------- edubuntu@edubuntu-Satellite:~$ arm-linux-gcc -I/usr/include/opencv -L/usr/local/lib -lml -lcvaux -lhighgui -lcv -lcxcore test.c In file included from /usr/include/opencv/cxcore.h:70, from /usr/include/opencv/cv.h:58, from test.c:1: /usr/include/opencv/cxtypes.h:155: warning: redefinition of `ushort' /usr/local/arm/3.3.2/include/sys/types.h:152: warning: `ushort' previously declared here /usr/local/arm/3.3.2/lib/gcc-lib/arm-linux/3.3.2/../../../../arm-linux/bin/ld: skipping incompatible /usr/local/lib/libml.so when searching for -lml /usr/local/arm/3.3.2/lib/gcc-lib/arm-linux/3.3.2/../../../../arm-linux/bin/ld: cannot find -lml collect2: ld returned 1 exit status edubuntu@edubuntu-Satellite:~$ //---------------------------------------------------------------------- i have also check this: edubuntu@edubuntu-Satellite:~$ pkg-config --cflags opencv -I/usr/local/include/opencv and this: edubuntu@edubuntu-Satellite:~$ pkg-config --libs opencv -L/usr/local/lib -lcxcore -lcv -lhighgui -lcvaux -lml and this: edubuntu@edubuntu-Satellite:~$ arm-linux-gcc -v Reading specs from /usr/local/arm/3.3.2/lib/gcc-lib/arm-linux/3.3.2/specs Configured with: ../gcc-3.3.2/configure --target=arm-linux --with-cpu=strongarm1100 --prefix=/usr/local/arm/3.3.2 i686-pc-linux-gnu --with-headers=/work/kernel.h3900/include --enable-threads=pthreads --enable-shared --enable-static --enable-languages=c,c++ Thread model: posix gcc version 3.3.2 what am i missing ? what should i do now?...please help me out....
I'd look into: /usr/include/opencv/cxtypes.h and /usr/local/arm/3.3.2/include/sys/types.h and see if ushort is defined in them both. Just a guess! You sure that is 3.3.2 and not 4.3.2?
hi devef, thanks for your reply, the warning is not the main problem i think.but the error said that they can not find my opencv library.....so the warning is ok....but how could i solve this error....so the arm-linux can find the opencv library. i ve downgraded my gcc version from the latest into 3.3.2 version according to some forum advice.but nothing change...i still unable to compile my program... anyone has idea to solve that...? running on ubuntu 10.10, with the latest update intel dual core 2.2 GHz
hi all, I got a problem when cross-compile follow Vladimir Fonov tutorial. This error: kakaka@kakaka-M52L-S3:~/Desktop/nhanVD$ arm-linux-gnueabi-g++-4.4 -o2 -I /home/kakaka/Desktop/nhanVD/OpenCV-2.0.0/include/opencv facedetect_noui.cpp -L /home/kakaka/Desktop/nhanVD/OpenCV-2.0.0/src/.libs -lcv -lhighgui -lcxcore -lml -lcvaux -lrt -lpthread -ldl -lz -lpng12 -ljpeg -o facedetect /usr/lib/gcc/arm-linux-gnueabi/4.4.5/../../../../arm-linux-gnueabi/bin/ld: cannot find -lz /usr/lib/gcc/arm-linux-gnueabi/4.4.5/../../../../arm-linux-gnueabi/bin/ld: cannot find -lpng12 /usr/lib/gcc/arm-linux-gnueabi/4.4.5/../../../../arm-linux-gnueabi/bin/ld: cannot find -ljpeg collect2: ld returned 1 exit status Vladimir Fonov or someone tell me why I got this problem. Thank you !
Hi huunhan, i think the reason behind your errors is, your cross compiler is not linking with dynamic libs. This linking depends not only on the cross compiler but also on the host machine behavior. so once cross check whether these jpeg, png libs are installed in your host machine or not. If you are using ubuntu as your host machine, you can check this one in the system package manager. By the by, which tool you are using for the cross-compilation...??
hai frends,plse help me am very new to this mini2440 .am using linux in mini2440 kit and am using ubuntu in host development pc. Nw my target is to compile hello world program in host development pc and to transfer the binary output in mini2440 kit. and am able to compile the code in host pc but i dnt knw how to transfer binary file and to see the results in mini2440 anothr question when i compile the program in development pc in linux ubuntu."a.out" file is generating.wthr is it binaryfile. In mini 2440 which flavour of linux were using ? pls pls pls help me
Hello, Well i know this place may not be the best place to this question but i think that many of you know how to compile and output requred dll files. Therefore i decided to ask my question in here. İ do not know linux and i have a wave cellphone using bada. İ need binaries of opencv compatible with arm processor. As bada is based on linux i believe that linx version can be helpfull for me. Although i tried many times i got many exhaustive errors. So i was tired. İ am using windows 7 and i have bada sdk. Could u please send me opencv 2.2 or 2.3 binary files to my mail aselmanb@yahoo.com . Me and my friends need it but we could not resolve problems. İf one can help me i will be appreciate. Thanks to everyone.
Hi, I came across a nice image processing control. I am sure it will enhance your knowledge about image processing and manipulation. Aspose.Imaging for .NET is an <a href="http://www.aspose.com/categories/.net-components/aspose.imaging-for-.net... processing & manipulation component</strong></a> that allows developers to create, edit, draw or convert images in their .NET application. It allows developers to convert image files to PSD, BMP, JPEG, PNG, TIFF and GIF formats. Moreover a set of pens, brushes and fonts can be used to draw images or add new elements & text to existing images. Aspose.Imaging for .NET works well with both web & windows applications. Moreover, it adds the support for Silverlight platform. Many Thanks
Hello, and thank you for these informations. I got a build error when i execute the command arm-linux-g++ : Command : doctorwho@ubuntu:/opt/mini2440/OpenCV-2.0.0/samples/c$ arm-linux-g++ -O2 -I ../../output/include/opencv facedetect_noui.cpp -L../../output/lib/ -lcv -lhighgui -lcxcore -lml -lcvaux -lrt -lpthread -ldl -lz -lpng12 -ljpeg -o facedetect Answer : ../../output/lib//libhighgui.a(lib_highgui_la-loadsave.o): In function `cv::imdecode_(cv::Mat const&, int, int, cv::Mat*)’: loadsave.cpp:(.text+0xcd8): warning: the use of `tmpnam’ is dangerous, better use `mkstemp’ ../../output/lib//libcv.a(lib_cv_la-cvcascadedetect.o): In function `_ZN2cv17CascadeClassifier16detectMultiScaleERKNS_3MatERSt6vectorINS_5Rect_IiEES aIS6_EEdiiNS_5Size_IiEE.omp_fn.0′: cvcascadedetect.cpp:(.text+0x4f98): undefined reference to `GOMP_loop_dynamic_start’ …. …. Have you an idea ? Thank you
hai i am vivek i have successfuly installed opencv 2.3 on my ubuntu 11.10 now when i try to cross compile a simple program to run an mini2440 i get thes error arm-linux-gcc -I/home/vivek/opencv_for_mini2440/project_files main.c -L /usr/lib -lopencv_core -o main error: opencv/cv.h: No such file or directory Can anyone please help me.
Hi thanx for sharing such a great tutorial.I cross compiled opencv 2.1.0 successfully.Now I wants to cross compile cvBlob library,I followe the same procedure as opencv cross compilation but I am getting some error.Could you please help me solve this.Thanks in advance....!!!
Hi.... I already build kernel on mini2440.now i want to interface USB cam and want to see captured image on mini2440 screen.Please tell me different ways to achieve this. Anyone please help me.....
Hi Pavan, May i know ur exact idea of implementation, to only capture the image over USB Cam u can find Qtopia app already there...if you want to to any image processing then has to do lot of work...is it for project or any hobby purpose based on it can suggest u
