Hi, On arm9home forums i can see a new dvd release http://www.arm9home.net/read.php?tid-14121.html but the download links are very very slow (115.com) and stop after few hours. Can someone upload the new dvd's for the mini6410 on a more faster site (megaupload,rapidshare,fileserve ??)? PS: i'm not from China that's why i'm having download stability problems! I want to test the new update :) :)! Waiting impatiently :) thank you very much! laurent
New release Mini6410 ???
maybe put them on the friendlyarm FTP (quick for me)? Release date is 2011-07-22 :) I don't mind beta release or not, i've already having some issues with the 2011-03-26 ! Or at least upload the new superboot :) regards, laurent
Translated text for the update: A friendly arm Mini6410 development board 2011-07-22 re-release of a major update to support more of the LCD screen (covering the 3.5-inch to 10 inch), more types of Nand Flash, WinCE really support 256M RAM, burning without a PC various OS's powerful Superboot, Android supports 2D/3D acceleration, support for 3G mobile phone SMS, TVOut and so on. 。 . 。 . Update details at a glance: Superboot Update Description: 1. Added support for LCD graphics modes, including automatic detection of critical hardware information, such as the installation progress bar shows PC 2. Added support for key-selected programming each system, without a PC 3. Added support for more MLC Flash type: K9GAG08U0D and K9GAG08UDE 4.increased NAND Flash start automatically recognize the SD card or NAND (as startup mode may be) Android Update Description: 1. Added support for 2D/3D acceleration, UI fluency increased dramatically; open and close the window when there is significant dynamic effects (only 256M of memory development board). 2. increase the power automatically dial-up Internet access 3G and more to do for business users to use the Android application development. 3. adds support for USB 3G card to use to send SMS functionality (support for the Android standard API interface). 4. Added support for dynamic wallpaper. 5. Added support for USB keyboard and mouse. 6. Added support for TV Out function support automatic output to the TV (only 4-inch screen). 7. Fixed Android insert U disk can not be opened under the File Brower the Bug. 8. LCD N43, A70, S70, W35, X35, T35, W50, L80, G10, VGA1024x768, VGA800x600, VGA640x480 8. Added support for more LCD type: N43, A70, S70, W35, X35, T35, W50, L80, G10, VGA1024x768, VGA800x600, VGA640x480 and so on. 9. WiFi firmware update, the speed has improved significantly. 10. Added support for Mini USB WiFi wireless network card (chip model RT8192cu). 11. Optimizes the file system to reduce the space occupied by about 20M of Flash. 12. items added boot parameter "SkipCali = y", in order to achieve calibration of the touch screen to skip the boot screen. 13. Fixed start the WiFi, the WiFi equipment in the allocated power lead to start the unusual case of problems. Linux Update Description: 1. Fixed JPEG hardware codecs under Linux the bug 2. LCD N43, A70, S70, W35, X35, T35, L80, G10, VGA1024x768, VGA800x600, VGA640x480等 (2) increase support for more type of LCD: N43, A70, S70, W35, X35, T35, L80, G10, VGA1024x768, VGA800x600, VGA640x480 etc. 3. WiFi firmware update, the speed has improved significantly 4. Added support for Mini USB WiFi wireless network card (chip model RT8192cu) 5. Optimizes the file system to reduce the space occupied by about 20M of Flash 6. Added support for more MLC Flash support: K9GAG08U0D and K9GAG08UDE 7.added boot parameter entry "SkipCali = y", skip the boot in order to achieve touch screen calibration interface WindowCE Update Description: 1. LCD N43, A70, S70, W35, X35, T35, W50, L80, G10, VGA1024x768, VGA800x600, VGA640x480等 1. Added support for more LCD type: N43, A70, S70, W35, X35, T35, W50, L80, G10, VGA1024x768, VGA800x600, VGA640x480 etc. 2. BSP truly 256M of memory (in System Properties is displayed as 190M or so, before the 41M), can automatically identify 128M/256M memory, and maximize free memory. 3. Flash Driver (SLC and MLC) with a new MDD / PDD framework for implementation, drive more perfect to use, add support for more MLC Flash type: K9GAG08U0D and K9GAG08UDE Some of my issue are fixed in this release PLEASE POST LINK :) thanks, laurent
