error in building the openembedded through the bitbake
Piyush
hello guys
I am trying to build the openembedded with the bitbake and I am using the
bill tutorial for it and I have successfully has exported the path to the
environment variable .
I am using the local.conf copied from mini2440.conf.
But as the building process progresses it gets stuck to a point and after
that gives out series of errors.
Here is the output:
me/piyush/work/oe/build/tmp/staging/i686-linux/usr/lib
../bfd/.libs/libbfd.a ../libiberty/libiberty.a
| libtool: link: gcc -W -Wall -Wstrict-prototypes -Wmissing-prototypes
-isystem/home/piyush/work/oe/build/tmp/staging/i686-linux/usr/include -O2
-Wl,-rpath-link
-Wl,/home/piyush/work/oe/build/tmp/staging/i686-linux/usr/lib -Wl,-rpath
-Wl,/home/piyush/work/oe/build/tmp/staging/i686-linux/usr/lib -Wl,-O1 -o
cxxfilt cxxfilt.o bucomm.o version.o filemode.o
-L/home/piyush/work/oe/build/tmp/staging/i686-linux/usr/lib
| ar.o: In function `main':
| ar.c:(.text+0x1190): multiple definition of `main'
| arlex.o:arlex.c:(.text+0x0): first defined here
| arparse.o: In function `yyerror':
| arparse.c:(.text+0x9): undefined reference to `linenumber'
| arparse.o: In function `yyparse':
| arparse.c:(.text+0x42d): undefined reference to `yylex'
| collect2: ld returned 1 exit status
| make[4]: *** [ar] Error 1
| make[4]: *** Waiting for unfinished jobs....
| arlex.o: In function `main':
| arlex.c:(.text+0x0): multiple definition of `main'
| ar.o:ar.c:(.text+0x1190): first defined here
| make[4]: *** [ranlib] Error 1
| make[4]: Leaving directory
`/home/piyush/work/oe/build/tmp/work/armv4t-angstrom-linux-gnueabi/binutils-cros
s-2.18.50.0.7-r6/binutils-2.18.50.0.7/build.i686-linux.arm-angstrom-linux-gnueab
i/binutils'
| make[3]: *** [all-recursive] Error 1
| make[3]: Leaving directory
i/binutils'
| make[2]: *** [all] Error 2
| make[2]: Leaving directory
i/binutils'
| make[1]: *** [all-binutils] Error 2
| make[1]: *** Waiting for unfinished jobs....
| ldmain.o: In function `main':
| ldmain.c:(.text+0x1820): multiple definition of `main'
| ldlex.o:ldlex.c:(.text+0x0): first defined here
| ldgram.o: In function `yyparse':
| ldgram.c:(.text+0x8d7): undefined reference to `yylex'
| ldgram.c:(.text+0xc78): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0xca2): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0xe78): undefined reference to `ldlex_version_file'
| ldgram.c:(.text+0xed5): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0xee6): undefined reference to `ldlex_version_file'
| ldgram.c:(.text+0x1065): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x10e9): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x10ee): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x10f9): undefined reference to `ldlex_script'
| ldgram.c:(.text+0x114a): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x1159): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x1200): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x1232): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x1241): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x1284): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x1291): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x12b8): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x12c1): undefined reference to `ldlex_script'
| ldgram.c:(.text+0x12d1): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x1310): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x133f): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x1349): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x1398): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x13a1): undefined reference to `ldlex_script'
| ldgram.c:(.text+0x13b1): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x1b07): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x1b1c): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x1b4e): undefined reference to `ldlex_both'
| ldgram.c:(.text+0x1b97): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x1ba9): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x1c61): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x1c71): undefined reference to `ldlex_script'
| ldgram.c:(.text+0x1e4e): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x1e78): undefined reference to `ldlex_expression'
| ldgram.c:(.text+0x2177): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x21a7): undefined reference to `ldlex_defsym'
| ldgram.c:(.text+0x2384): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x2399): undefined reference to `ldlex_script'
| ldgram.c:(.text+0x24cf): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x265c): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x2669): undefined reference to `ldlex_version_script'
| ldgram.c:(.text+0x2679): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x268a): undefined reference to `ldlex_popstate'
| ldgram.c:(.text+0x26a0): undefined reference to `ldlex_mri_script'
| lexsup.o: In function `parse_args':
| lexsup.c:(.text+0xc28): undefined reference to `parser_input'
| lexsup.c:(.text+0xc64): undefined reference to `parser_input'
| lexsup.c:(.text+0xf2b): undefined reference to `lex_string'
| lexsup.c:(.text+0xf33): undefined reference to `lex_redirect'
| lexsup.c:(.text+0xf39): undefined reference to `parser_input'
| lexsup.c:(.text+0xf5c): undefined reference to `lex_string'
| lexsup.c:(.text+0x12bc): undefined reference to `parser_input'
| lexsup.c:(.text+0x16e6): undefined reference to `parser_input'
| ldlang.o: In function `load_symbols':
| ldlang.c:(.text+0x3cab): undefined reference to `parser_input'
| ldmain.c:(.text+0x24b1): undefined reference to `parser_input'
| ldmain.c:(.text+0x24ed): undefined reference to `parser_input'
| ldmain.c:(.text+0x24fc): undefined reference to `lex_string'
| ldmain.c:(.text+0x26aa): undefined reference to `lex_string'
| ldmain.c:(.text+0x26b2): undefined reference to `lex_redirect'
| ldexp.o: In function `exp_relop':
| ldexp.c:(.text+0x4da): undefined reference to `lineno'
| ldexp.o: In function `exp_bigintop':
| ldexp.c:(.text+0x51a): undefined reference to `lineno'
| ldexp.o: In function `exp_intop':
| ldexp.c:(.text+0x55a): undefined reference to `lineno'
| ldexp.o: In function `exp_get_abs_int':
| ldexp.c:(.text+0x1b38): undefined reference to `lineno'
| ldexp.o: In function `exp_nameop':
| ldexp.c:(.text+0x1d74): undefined reference to `lineno'
| ldmisc.o:ldmisc.c:(.text+0x6a8): more undefined references to `lineno'
follow
| ldmisc.o: In function `vfinfo':
| ldmisc.c:(.text+0x977): undefined reference to `lex_string'
| ldmisc.c:(.text+0xb2e): undefined reference to `lineno'
| ldfile.o: In function `ldfile_open_command_file':
| ldfile.c:(.text+0x384): undefined reference to `lex_push_file'
| ldfile.c:(.text+0x39c): undefined reference to `lineno'
| ldfile.o: In function `ldfile_try_open_bfd':
| ldfile.c:(.text+0x5fa): undefined reference to `parser_input'
| ldfile.c:(.text+0x603): undefined reference to `ldlex_both'
| ldfile.c:(.text+0x631): undefined reference to `yylex'
| ldfile.c:(.text+0x6f1): undefined reference to `yylex'
| ldfile.c:(.text+0x701): undefined reference to `yylex'
| ldfile.c:(.text+0x717): undefined reference to `yylex'
| ldfile.c:(.text+0x781): undefined reference to `ldlex_popstate'
| ldfile.c:(.text+0x786): undefined reference to `yyin'
| ldfile.c:(.text+0x7a1): undefined reference to `yyin'
| ldfile.c:(.text+0x7f9): undefined reference to `yylex'
| ldfile.c:(.text+0x831): undefined reference to `yylex'
| ldfile.c:(.text+0x856): undefined reference to `yylex'
| ldfile.c:(.text+0x869): undefined reference to `yylex'
| make[4]: *** [ld-new] Error 1
i/ld'
i/ld'
i/ld'
| make[1]: *** [all-ld] Error 2
| make[1]: Leaving directory
i'
| make: *** [all] Error 2
| + die 'oe_runmake failed'
| + oefatal 'oe_runmake failed'
| + echo FATAL: 'oe_runmake failed'
| FATAL: oe_runmake failed
| + exit 1
NOTE: package binutils-cross-2.18.50.0.7-r6: task do_compile: Failed
ERROR: Function 'do_compile' failed (see
/home/piyush/work/oe/build/tmp/work/armv4t-angstrom-linux-gnueabi/binutils-cross
-2.18.50.0.7-r6/temp/log.do_compile.22772
for further information)
ERROR: Task 677
(/home/piyush/work/oe/mini2440/re...stripped-down
Piyush
ERROR: Task 677
(/home/piyush/work/oe/mini2440/recipes/binutils/binutils-cross_2.18.50.0.7.bb,
do_compile) failed with exit code '1'
Waiting for 3 active tasks to finish:
0: linux-libc-headers-2.6.23-r4 do_populate_staging (pid 22776)
1: gcc-cross-intermediate-4.2.4-r5 do_setscene (pid 22784)
2: qemu-native-0.10.3-r1 do_compile (pid 22796)
Waiting for 2 active tasks to finish:
0: gcc-cross-intermediate-4.2.4-r5 do_setscene (pid 22784)
1: qemu-native-0.10.3-r1 do_compile (pid 22796)
NOTE: package linux-libc-headers-2.6.23-r4: task do_populate_staging:
Succeeded
Waiting for 1 active tasks to finish:
0: qemu-native-0.10.3-r1 do_compile (pid 22796)
NOTE: package gcc-cross-intermediate-4.2.4-r5: task do_setscene: Succeeded
So I want to know why I am getting this error, please help me guys am I
missing something or some library.
I am using ubuntu 10.04 and I have installed the gcc compiler 3.4
Please tell me guys what is this error all about.
