CUPS Cross Compiling for MINI2440
stalin
I am trying to cross compile the cups for mini2440
This is my configuration
./configure --host=arm-linux --prefix=/opt/FriendlyARM/mini2440/root_qtopia
--disable-gnutls --disable-gssapi --disable-dbus
cups version cups-1.5rc1
but i am getting following errorLinking libcups.so.2...
/usr/local/arm/4.3.2/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.2/../../../../arm
-none-linux-gnueabi/bin/ld:
backchannel.o: Relocations in generic ELF (EM: 3)
backchannel.o: could not read symbols: File in wrong format
collect2: ld returned 1 exit status
make[1]: *** [libcups.so.2] Error 1
make: *** [all] Error 1
can anyone tell me how to solve this issue
Juergen Beisert
Google is your friend
stalin
I Solved the problem by googling
but now i am getting Segmentation Fault
when i use lp,lpr,lpq or and cups commands
stalin
Segmentation Fault Also Sovled
Now i am able to run cups on mini2440.
but when say lp , it says schedular error .
I tried
lp -d /dev/lp0 filename
gives
connection refused
Please help
TungPham
eh, I've tried cups on mini2440 and i gave up.
- cups is too big with php, apache web-server so it run very slow.
- scheduler error (the same with Stalin)
If your target does not support too much printer or printing protocol so
you can write your self printing system like this:
 ____________     ______     __________     _______
|font control| + |filter| + |scheduler | + | back-end |
                            |(optional)|
font control: load and draw font.
filter: convert print document to the bitmap and send to the back-end
scheduler: like the spooler in window.
back-end: work with printer( send command, config paper, handing error)
I've just implemented simple printing system( no spooler) and it take about
1 to 1,5 second per ticket with QL570 label printer.
Hope this help,
TangQiang
I suggest you to use buildroot, it may cost you half
 a day to learn it, but it is really easy to port cups to arm.
duma
stalin,
but, how to solved the segment fault?
Sushant
Hello stalin,
I have same problem how to solve it?
/opt/EmbedSky/4.3.3/bin/../lib/gcc/arm-none-linux-gnueabi/4.3.3/../../../../arm-
Juergen Beisert
This error message could mean your ARM cross linker tries to link in a
library for your host (x86).
BTW: CUPS does its work on the Mini2440. But with 64 MiB of SDRAM it can
print only small pages or pages with low resolution. At least if you need
Ghostscript as part of the filter chain.
Smith
hello Juergen Beisert,
only try to check how to cross compile the cups in cross compiler 4.3.3v
