Hi, I have reset the bootargs of Supervivi. I would like to what are the default parameter. Becaus eknox I have a boot delay of hours ... I have change the boot delay but I would like to have the default configuration. Thanks.
Supervivi default bootargs
Ok, but when I reset the bootargs there are automatically saved in Nand or I need to save it it Nand manually ?
You saying you are at Supervivi, you should: 1. use menu command to make bootargs changes with menu aid Supervivi> menu ... [s] Set the boot parameters [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB [q] Goto shell of vivi [i] Version: 0945-2K Enter your selection: s ##### Parameter Menu ##### [r] Reset parameter table to default table [s] Set parameter [v] View the parameter table [w] Write the parameter table to flash memeory [q] Quit Enter your selection: 2. use param command set to configure via console line param [eval|show|save [-n]|reset] -- set/get parameter You must issue save option from param command to persist the bootargs to the NAND. Renato
