Pengutronix offers a free Board Support Package for the popular FriendlyARM's Mini6410. It provides most of the required components to get this embedded target up and running. But this one is not a full featured Board Support Package yet. That's why it's yet dedicated for experienced users. Future releases will complete it more an more, to support beginners in the embedded world using the Mini6410 as well. Feature List: ------------- - PTXdist-2011.07.0 based buildsystem for easy setup and build [1] - recent GCC Toolchain (GCC 4.5.2, libc 2.13) for ARM11 [2] - Kernel: Recent 2.6.39 Linux (includes stable release .3) Support for the following list of hardware components - serial console - network - LED - GPIO - AD converter - I2C + EEPROM - Real time clock - two LC displays - framebuffer - touchscreen - more than one predefined configuration - one without graphic, for headless usage - one with full blown Qt support including an example how to use it - Basic documentation how to prepare and build all software components Additional info can be found here: http://www.oselas.org/oselas/bsp/pengutronix/index_en.html Comments are welcome. [1] http://www.oselas.org/software/ptxdist/index_en.html [2] http://www.oselas.org/oselas/toolchain/index_en.html
Mini6410: Free Board Support Package released
For the interested: I just uploaded the Linux-3.0 support for the Mini6410 to the well known repository. This is not a release yet. So, testers are welcome.
For the interested: I just uploaded high resolution timer support for this platform. This is one important step to make RT-Preempt work.
Unable to compile the kernel. Get the following errors: ---------------------- target: kernel.compile ---------------------- cd /usr/local/lib/ptxdist-2011.08.0/projects/OSELAS.BSP-Pengutronix-Mini6410-2011.0 7.0/platform-mini6410/build-target/linux-2.6.39 && PATH=/usr/local/lib/ptxdist-2011.08.0/projects/OSELAS.BSP-Pengutronix-Mini6410-2 011.07.0/platform-mini6410/sysroot-cross/bin:/usr/local/lib/ptxdist-2011.08.0/pr ojects/OSELAS.BSP-Pengutronix-Mini6410-2011.07.0/platform-mini6410/sysroot-cross /sbin:$PATH KCONFIG_NOTIMESTAMP=1 make \ -j4 HOSTCC=gcc ARCH=arm CROSS_COMPILE=arm-1136jfs-linux-gnueabi- INSTALL_MOD_PATH=/usr/local/lib/ptxdist-2011.08.0/projects/OSELAS.BSP-Pengutroni x-Mini6410-2011.07.0/platform-mini6410/packages/linux-2.6.39 PTX_KERNEL_DIR=/usr/local/lib/ptxdist-2011.08.0/projects/OSELAS.BSP-Pengutronix-Mini6410-2011.0 7.0/platform-mini6410/build-target/linux-2.6.39 CONFIG_DEBUG_SECTION_MISMATCH=y DEPMOD=/usr/local/lib/ptxdist-2011.08.0/projects/OSELAS.BSP-Pengutronix-Mini6410 -2011.07.0/platform-mini6410/sysroot-cross/sbin/arm-1136jfs-linux-gnueabi-depmod uImage "modules" make[1]: Entering directory `/usr/local/lib/ptxdist-2011.08.0/projects/OSELAS.BSP-Pengutronix-Mini6410-2011. 07.0/platform-mini6410/build-target/linux-2.6.39' scripts/kconfig/conf --silentoldconfig Kconfig warning: (ARCH_LPC32XX && ARCH_S3C64XX && ARCH_TCC8K) selects USB_ARCH_HAS_OHCI which has unmet direct dependencies (USB_SUPPORT) include/config/auto.conf:68:warning: symbol value 'elf32-i386' invalid for OUTPUT_FORMAT include/config/auto.conf:96:warning: symbol value 'arch/x86/configs/i386_defconfig' invalid for ARCH_DEFCONFIG include/config/auto.conf:221:warning: symbol value '-fcall-saved-ecx -fcall-saved-edx' invalid for ARCH_HWEIGHT_CFLAGS warning: (ARCH_LPC32XX && ARCH_S3C64XX && ARCH_TCC8K) selects USB_ARCH_HAS_OHCI which has unmet direct dependencies (USB_SUPPORT) *** Error during update of the configuration. make[3]: *** [silentoldconfig] Error 1 make[2]: *** [silentoldconfig] Error 2 make[1]: *** No rule to make target `include/config/auto.conf', needed by `include/config/kernel.release'. Stop. make[1]: Leaving directory `/usr/local/lib/ptxdist-2011.08.0/projects/OSELAS.BSP-Pengutronix-Mini6410-2011. 07.0/platform-mini6410/build-target/linux-2.6.39' make: *** [/usr/local/lib/ptxdist-2011.08.0/projects/OSELAS.BSP-Pengutronix-Mini6410-2011. 07.0/platform-mini6410/state/kernel.compile] Error 2
Did you build the whole BSP or did you try to build the kernel component only? It seems the buildsystem was confused by a manual change. Try the following: - clean the kernel component: ptxdist clean kernel - configure the kernel if you want: ptxdist menuconfig kernel - build the kernel: ptxdist targetinstall kernel This should give you the file "platform-mini6410/images/linuximage".
Thanx! That's ok. But what about yaffs2 support? I used milkymist-rtems-yaffs2-3849a10 kernel patch, but the compiled kernel still can't see init script. May be it is possible to include the older kernel with yaffs2 to bsp?
Yes, that is possible. Run "ptxdist platformconfig" and change the used linux version to your need. Then add a subfolder with the patch stack that is required to change this vanilla kernel to the kernel you need (configs/platform-friendlyarm-mini2440/patches/). Follow the style the other subfolders in this directory are using. As a last step add your kernel config to "configs/platform-friendlyarm-mini2440". All these components make PTXdist building your kernel the next time your run "ptxdist go". What PTXdist is doing in your case: - download the vanilla sources and extract them - apply the patch stack in "configs/platform-friendlyarm-mini2440/patches/linux-<anns-yaffs-patches>" according to the "series" file in this directory - configure and build this kernel with the defines kernel config If you send me the required patch stack for this kernel I can add it to the BSP's repository for reference.
I used this - https://github.com/milkymist/rtems-yaffs2/ to add yaffs support to kernel. And this patch http://www.aleph1.co.uk/lurker/message/20110603.135250.634d89fa.en.html. But the compiled kernel doesn't work :(. Can you look at it please? /sbin/init is in rootfs. But kernel can't find it :(( Creating 3 MTD partitions on "nand": 0x000000000000-0x000000100000 : "uboot" 0x000000100000-0x000000300000 : "kernel" 0x000000300000-0x000010000000 : "rootfs" dm9000 Ethernet Driver, V1.31 eth0: dm9000a at c886e000,c8872004 IRQ 108 MAC: 08:90:90:90:90:90 (chip) input: gpio-keys as /devices/platform/gpio-keys/input/input0 samsung-ts s3c64xx-ts: driver attached, registering input device input: S3C24XX TouchScreen as /devices/virtual/input/input1 S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c-rtc s3c64xx-rtc: rtc disabled, re-enabling s3c-rtc s3c64xx-rtc: rtc core: registered s3c as rtc0 TCP cubic registered VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5 s3c-rtc s3c64xx-rtc: setting system clock to 2011-09-05 23:18:04 UTC (1315264684) yaffs: dev is 32505858 name is "mtdblock2" rw yaffs: passed flags "" VFS: Mounted root (yaffs2 filesystem) on device 31:2. devtmpfs: mounted Freeing init memory: 96K Failed to execute /sbin/init. Attempting defaults... Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance. [<c002ab40>] (unwind_backtrace+0x0/0xe4) from [<c0229258>] (panic+0x68/0x180) [<c0229258>] (panic+0x68/0x180) from [<c00203a0>] (init_post+0xa0/0xc4) [<c00203a0>] (init_post+0xa0/0xc4) from [<c0008958>] (kernel_init+0x104/0x13c) [<c0008958>] (kernel_init+0x104/0x13c) from [<c00265b4>] (kernel_thread_exit+0x0/0x8)
"readelf -A <your-arm-root>/bin/<any executable>" Here from my BSP: [me@host] readelf -A platform-mini6410/root/usr/bin/qt4-demo Attribute Section: aeabi <----------- this one File Attributes Tag_CPU_name: "ARM1176JZ-S" Tag_CPU_arch: v6KZ Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_VFP_arch: VFPv2 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed [...] Or you can run this kernel with "init=/bin/sh" as a try. The kernel must support the ABI your userland uses.
I just uploaded the YAFFS support into my Mini6410 BSP. Maybe you can test with the kernel from the current repository
great work! will there be USB support soon? I have a CSR bluetooth device which would be great to have it working!
For the interested: I just made the November release of our free Board Support Package for the FriendlyARM's Mini6410. Updated features are: - PTXdist-2011.10.1 - Qt-4.7.4 - Kernel: 2.6.39, stable release 4 - Kernel 3.0, stable release 8 - Kernel 3.1, (experimental) - U-Boot, with support to boot from network and SD/MMC card - Linux based tools to prepare an SD/MMC card to make the Mini6410 boot from Please be a aware: this release still doesn't offer full feature support of the Mini6410. It still lacks USB and NAND support. Feature List: ------------- - PTXdist based buildsystem for easy setup and build - more than one predefined configuration - one without graphic, for 'headless' usage - one with full blown Qt support including an example how to use it - recent GCC Toolchain (GCC 4.5.2, libc 2.13) for ARM11 with hard floating point support - Bootloader U-Boot-1.1.6 - Kernel: Support for the following list of hardware components - serial console - SD/MMC card - network - LED - GPIO - AD converter - I2C master and I2C EEPROM - Real time clock - Keypad - various LC displays (LCD70 and N43) - framebuffer - touchscreen - Comprehensive documentation how to prepare and build all software components and to deploy the Mini6410. Additional info can be found here: http://www.oselas.org/oselas/bsp/pengutronix/index_en.html
For the interested: I just uploaded the OneWire kernel driver and the corresponding OnerWire TSLIB extension for the MINI6410 and the Kernel-3.0 to the Mini6410 board support package GIT repository. Testers are welcome, as I have no OneWire based touchscreen.
Juergen Beisert, do you know if the Pengutronix BSP for the Mini6410 has support to the V4L2 library? I want to use opencv and another web applications that will need to use the CAM130 or some usb camera. Thanks.
Support for the libv4lv2 is part of PTXdist, you can enable and test it. But it is untested in conjunction with the Mini6410. So, its up to you to make it work, if some special settings are required to get it up and run. Feel free to ask here or at our Mini6410 mailing list@pengutronix,
Hi Juergen, I applied the patches for 1wire device from OSELAS BSP for Mini6410 git repository to my 3.4 kernel but still no output on N43i display. Could you suggest me what else should I try out?
@Giannis Damigos: I only know the N43i from its schematics. So, I cannot suggest something useful, because I cannot test it @Kaushik Kale: It also works with the Tiny6410 and its development baseboard. We recently have tested it at the LinuxTag in Berlin.
@Juergen Could you please try my kernel on your N43 display? Looking at mach-mini6410.c source code, I think that I should change the initial value of mini6410 features string.
sudo git clone http://git-public.pengutronix.de/Cloning into 'git-public.pengutronix.de'... fatal: http://git-public.pengutronix.de/info/refs not found: did you run git update-server-info on the server? Has anyone experience this problem and know why?
Try on a per repository base, not the whole server: git clone http://git-public.pengutronix.de/git-public/OSELAS.BSP-Pengutronix-Mini6...
