system: tiny6410_a70 touchscreen: 7" 1wire (/dev/touchscreen-1wire) kernel: 2.6.38-FriendlyARM tslib: 1.4 distro: debian squeeze -- does anyone have friendlyarm-ts-input.c ? -- the linux and ubuntu "-s" root file systems, for example: - rootfs_qtopia_qt4-s-20100917.gz ^^ - rootfs-ubuntu-0910-s-20100917.tar.gz for example ^^ contain a tslib plugin called "friendlyarm-ts-input" that provides support for this systems 7" 1wire touchscreen (/dev/touchscreen-1wire) so instead of: module_raw input the /etc/ts.conf file contains: module_raw friendlyarm-ts-input this maps to a tslib plugin: /usr/local/lib/ts/friendlyarm-ts-input.so (in rootfs_qtopia_qt4-s) ^^ I need the source for this - i'm sure many of us do :) friendlyarm-ts-input.c -- copying friendlyarm-ts-input.so over works but I not comfortable using it without the source -- cheers ===== keywords -> mini6410, tiny6410, tslib, 1.4, a70, 7" touchscreen, /dev/touchscreen-1wire, /etc/ts.conf, ts_calibrate
