need some advice please:
kernel: 2.6.36 with following set: <src touchscreen for mini6410 >
<Mini6410 1-wire host and TouchScreen Driver>
On target: cat /dev/touchscreen-1wire responds to touch on screen.
( c 10 181 ) => driver working
cat /dev/touchscreen exists but is inactive
( c 10 180 ) => registered by the kernel from the lines below
ls /sys/bus/platform/drivers shows samsung-ts
ls /sys/bus/platform/devices shows s3c-ts as registered device
If I: cat /dev/touchscreen-1wire > /dev/touchscreen &
generates a response. I get the message: cat: write error :
Invalid argument when trying /usr/bin/ts_calibrate
I have configured and exported TSLIB_TSDEVICE and TSLIB_CALIBFILE
have i missed the boat totally?
touchscreen-1wire advice
you aren't missing anything there is practically no information around about this problem i got my mini6410 going by -> copying "friendlyarm-ts-input.so" from a one of the friendlyarm-provided file systems that are labelled with a "-s" (eg rootfs_qtopia_qt4-s) friendlyarm-ts-input.so is a tslib module it replaces the generic input module i have not been able to locate source but copying the binary works see my other post for a little more info -> http://www.friendlyarm.net/forum/topic/2964 take a look at how tslib is configured on a "-s" rootfs its useful as a working reference
thanks jono i had considered doing that, but like you, would like the source code instead of friendlyarm-ts-input i was hoping input,compiled from input-raw.c could be used ../tslib/plugins/input-raw.c
ive spent several hours trying to make input-raw.c work - no success tho it is very frustrating that friendlyarm-ts-input.c is nowhere to be found i've also noticed that the qtopia "-s" images have a /etc/ts.detected file, contents: CHECK_1WIRE=N i haven't worked out the relevance of that file yet ideas anyone ?
i have seen a reference to modifying input-raw.c ( http://blog.sina.com.cn/superbigapple Topic: TINY6410 MINI6410 transplantation of TSLIB1.4 ) google translate the following, tekkamanninja.blog.chinaunix.net , for information regarding porting tslib. found this site to be a minefield of information. i hope you are cleverer at using it.
Hi Sean_h May I know what that command "cat /dev/touchscreen-1wire > /dev/touchscreen" is for? Have you managed to get it touchscreen working? If yes, would you shade some light how you did that? what OS and environment are you running at?
Hi vib Sorry, a bit late on this. I know /dev/touchscreen-1wire is working. The "cat /dev/touchscreen > /dev/touchscreen &" was an attempt to re-direct from stdout to another driver. No, I have not got it working yet. Have you had success?
Still no luck. I have checked through dmesg, that both touchcreen and touchscreen initialized. However, I still can't get the touch screen going. :-(
Have you tried the copying of friendlyarm-ts-input.so from a working platform. jono indicated that this works but i have not tried it yet.
Yes, I've, it works with regards to that. That is, the position calibration comes up prompting for input. But after all initializations, the touchscreen does not respond to touch. I made a diff between the Ubuntu-0910 (from the DVDs) and the Xubuntu-MyDownload. The /dev. /lib, /bin folders, I don't see anything suspicious.
Hi All, does anybody have fixed the issue? We are experiencing probably the same trouble; everything seems to work correctly, but when we reboot after the first calibration the event of touch screen is not captured anymore or even not generated. If we try to run manually by prompt command the calibration procedure after the first calibration boot this gives error. It's very strange because the boot process is the same and so seem to be the environment variables: the only difference between the first boot and the next ones is an if that launch the calibration procedure by the same boot. Does anybody have any idea? Thanks. Federico and Daniele.
I suggest you read the following, it worked for me. http://www.friendlyarm.net/forum/topic/3366
We followed the post you suggested, but we get the same error. Have anybody used successfully Mini6410 and touchscreen function with linux distribution different than the ones given by friendly arm? Thanks. F.
