I lost some time trying to make this camera working using v4l2. Either Samsung driver is broken or I didn't provide some important ioctl's. I performed my tests on 2.6.28 kernel with fimc driver as .c sources and 2.6.38 kernel with already compiled binary drivers. 1. Capture mode Enumerating capabilities returned: V4L2_CAP_VIDEO_CAPTURE and V4L2_CAP_VIDEO_OVERLAY. There are 4 possible formats: - YU12: 4:2:0, planar, Y-Cb-Cr - 422P: 4:2:2, planar, Y-Cb-Cr - YUYV: 4:2:2, packed, YCBYCR - UYVY: 4:2:2, packed They don't work. ioctl(VIDIOC_S_FMT) doesn't return error, but it also doesn't fill properly v4l_fmt.fmt.pix.bytesperline and v4l_fmt.fmt.pix.sizeimage. Overriding these values doesn't help. Reading frames in "mmap" mode ends with "QUERYBUF for mmap failed 22: Invalid argument". read(fd,...) doesn't work either. 2. Overlay mode Enumerating capabilities returned the same values as in capture mode. VIDIOC_G_FMT failed, but fimc sourcecode gave a hint that two formats are possible: - RGB565 - RGB24 If FriendlyARM/qtopia can show image from the camera, then there must be some way to get these frames. Tracking cmos-camera application (it's closed source) ioctls helped a lot. I would never guess that: - overlay mode is used to capture frames - there is V4L2_CAP_VIDEO_CAPTURE capability, but mmap doesn't work - there is no support for V4L2_CAP_READWRITE capability, but you have to use read(fd,...) - RGB24 format gives you really RGB32 frames I still don't know how to get better resolution than 640x512. Anyway, if you want to capture some frames you have to: int fd=open("/dev/video0", O_RDWR); struct v4l2_framebuffer fb; bzero(&fb,sizeof(fb)); fb.fmt.width=640; fb.fmt.height=480; fb.fmt.pixelformat=V4L2_PIX_FMT_RGB24; ioctl(fd,VIDIOC_S_FBUF,&fb); int some_int_1=1; ioctl(fd, VIDIOC_OVERLAY, &some_int_1); read(fd, buf, 640*480*3); int some_int_0; ioctl(fd, VIDIOC_OVERLAY, &some_int_0); I hope this little tutorial will help you.
mini6410 and cam130 camera
"This code on CodeForge.com may be of helpful:http://www.codeforge.com/article/244807"
