Hi for everyone. I have a serious problem with my mini2440. I want to use the pin AIN1, AIN2, AIN3 (this is the pin of ADC) but i'm not able to ability in kernel. I try to include in kernel configuration but without response... How i make to use it?? Can you help me to enable it??. Thanks a lot for yourdisponition
how to use adc mini2440??
Hi The kernel only contains the driver for AIN0. If you want to use the pins AIN1,AIN2 and AIN3 then you will have to make your own drivers and then insert them into the kernel either as modules or else you can include them in the kernel , recompile the kernel and transfer the image in mini2440. Regards Vector Institute Specialised in Embedded Systems linuxsupport@vectorindia.org http://www.vectorindia.org
With a few adaptions a recent 2.6.39 supports all ADC channels. You need the "Hardware Monitoring support", "<*> Samsung built-in ADC" and a small adaption in the platform file to register the ADC unit at runtime.
Juergen Beisert hi, thanks for your response ;) what are this adaptation on kernel?? I try the adaptation described in precedent post, but don't works...
You have to modify the Mini2440 platform file in the kernel to register the "s3c_device_hwmon" device at run-time. Then the ADC driver occurs at run-time and you can access the channels.
hi everyone. hi,Juergen Beisert I have a problem. I test adc with AIN0, and it used to work very well. So, i connect it with my analog signal. it work well. but now, it always show 1022 and 1023 on screen although i remove my signal. I don't know maybe my "adc hardware" it error. I try setup Android OS again, but it not change. is "adc hardware" error. please, give me advice.
hi Juergen Beisert. yes. AIN0 is controlled by via W1, so I removed it, and replace it with my signal. It still worked, but now it always show value 1022 and 1023 although I place via W1 back. It not effect. I thinks. i will try with AIN1 but I don't know build kernel.
What is the maximum DC voltage that your analog signal can go to? I wouldn't try AIN1 or may have two ports that don't work! Its a good idea to have some form of protection, but that's another story.
hi davef
my signal is small, maybe less 3.3v.
I think, maybe it by my code, b/c i read it continuously.
for(i = 0; i<20; i++){
k =HardwareControler.readADC();
WEIGHTreceive.append(" " + String.valueOf(k));
It still work sometime, but not now.
davef, In this pdf, http://www.armkits.com/download/s3c2440.pdf, on page 27-2. It states that the analog signal should not exceed 3.6V.
