Hello, I'm trying to make a software reboot on the mini2440, but I was unable to use this pinvoke : http://www.pinvoke.net/default.aspx/coredll.kerneliocontrol it didn't worked. I think it is not implemented in the WinCE image, I was wondering in put a trasistor on the nRst pin with a Gpio on its base, so I can toogle the Gpio pin and restart it, but it seems strange that I need to do it through hardware, some one knows something about it ? thanks
Software reboot on windows CE 6.0 in mini2440
[DllImport("coredll.dll")]
private static extern bool KernelIoControl(uint dwIoControlCode,
byte[] inBuf, uint inBufSize, byte[] outBuf, uint outBufSize, ref uint
bytesReturned);
private const uint FILE_DEVICE_HAL = 0x00000101;
private const uint METHOD_BUFFERED = 0;
private const uint FILE_ANY_ACCESS = 0;
private static uint CTL_CODE(uint DeviceType, uint Function, uint
Method, uint Access)
return ((DeviceType << 16) | (Access << 14) | (Function << 2) |
Method);
public static void SoftReset()
uint bytesReturned = 0;
uint IOCTL_HAL_REBOOT = CTL_CODE(FILE_DEVICE_HAL, 15,
METHOD_BUFFERED, FILE_ANY_ACCESS);
KernelIoControl(IOCTL_HAL_REBOOT, null, 0, null, 0, ref
bytesReturned);
Hello, I've tryied this code, but it didn't worked, I think this function is not implemented in the BSP. have you tried ? I will try to use the Watch Dog Timer to do it. thanks !
