I'm trying to setup a NFS server for my Mini2440. But before I go that far I first want to be able to establish communications via the ping command. But ALL my attempts to ping any computer from the Mini2440 FAIL. When the Mini2440 is in ping mode I'm able to ping it from the computer but the Mini2440 gets no response from the computer. When I use a router setup I can at least ping the router from the Mini2440. I will explain all the details and setups now. Software: Host PC: Windows 7 64bit Pro (firewall disabled), Static IP: 192.168.1.40 NFS Server (Guest PC): Ubuntu 10.04.2 Virtual Machine (VMWare), Static IP: 192.168.1.42 Mini2440: u-bot binary from http://bill.station51.net/index.php?post/2010/04/27/Binary-Links-to-U-Boot Hardware: Mini2440: Mini2440v2 from www.developmentboard.net AND Mini2440 from www.thaieasyelec.net Router: Linksys Cisco WAG320N, Router IP: 192.168.1.1 therfore the GatewayIP = 192.168.1.1 Switch: Linksys EZX16W u-boot settings: bootdelay=3 ethaddr=08:08:11:18:12:27 serverip=192.168.1.42 netmask=255.255.255.0 usbtty=cdc_acm mini2440=mini2440=0tb bootargs_base=console=ttySAC0,115200 noinitrd bootargs_init=init=/sbin/init root_nand=root=/dev/mtdblock3 rootfstype=jffs2 root_mmc=root=/dev/mmcblk0p2 rootdelay=2 root_nfs=/mnt/nfs set_root_nfs=setenv root_nfs root=/dev/nfs rw nfsroot=${serverip}:${root_nfs} ifconfig_static=run setenv ifconfig ip=${ipaddr}:${serverip}::${netmask}:mini2440:eth0 ifconfig_dhcp=run setenv ifconfig ip=dhcp ifconfig=ip=dhcp set_bootargs_mmc=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_mmc} set_bootargs_nand=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_nand} set_bootargs_nfs=run set_root_nfs; setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_nfs} ${ifconfig} mtdids=nand0=mini2440-nand mtdparts=mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x0050 0000(kernel),0x07aa0000(rootfs) ipaddr=192.168.1.45 gatewayip=192.168.1.1 bootcmd=nfs 0x31000000 192.168.1.42:/home/jdoe/nfs/kernel/uImage ; bootm bootargs=console=ttySAC0,115200 root=/dev/nfs nfsroot=192.168.1.42:/home/jdoe/nfs/fs rw ip=192.168.1.45 mini2440=0tb partition=nand0,0 mtddevnum=0 mtddevname=u-boot Setups I have tried: 1.) Mini2440 (uboot settings, Gateway: None) <--ETH Crossover--> PC (Static IP: 192.168.1.40/42, Netmask: 255.255.255.0, Gateway: None) Mini2440# ping 192.168.1.40 (host pc) : ping failed; host 192.168.1.40 is not alive Mini2440# ping 192.168.1.42 (guest pc/nfs server) : ping failed; host 192.168.1.42 is not alive 2.) Mini2440 (uboot settings, Gateway: 192.168.1.1) <--ETH Crossover--> ROUTER <--ETH Crossover--> PC (Static IP: 192.168.1.40/42, Netmask: 255.255.255.0, Gateway: 192.168.1.1) Mini2440# ping 192.168.1.40 (host pc) : ping failed; host 192.168.1.40 is not alive Mini2440# ping 192.168.1.42 (guest pc/nfs server) : ping failed; host 192.168.1.42 is not alive Mini2440# ping 192.168.1.1 (router) : host 192.168.1.1 is alive 3.) Mini2440 (uboot settings, Gateway: None) <--ETH Crossover--> SWITCH <--ETH Crossover--> PC (Static IP: 192.168.1.40/42, Netmask: 255.255.255.0, Gateway: None) Mini2440# ping 192.168.1.40 (host pc) : ping failed; host 192.168.1.40 is not alive Mini2440# ping 192.168.1.42 (guest pc/nfs server) : ping failed; host 192.168.1.42 is not alive When the mini2440 is in ping mode and I send a ping from the host pc to 192.168.1.45 (Mini2440 ipaddr) I get a reply. Also, when the mini2440 is in ping mode and I send a ping from the guest pc to 192.168.1.45 (Mini2440 ipaddr) I get a reply. To verify that its not fooling me, I also try and ping the mini2440 when its not in ping mode and I do not get a reply, as it should be So what the hell is going on, I honestly don't know. Any advice will be appreciated Thank you
Can't ping host from uboot, cant do NFS
When I say ping mode it means when I've entered the ping command in uboot (Mini2440# ping ipaddress). Meaning that it brings up the ethernet interface for a short while, the period in which it tries to ping.
Mini2440 (uboot settings, Gateway: None) <--ETH Crossover--> SWITCH <--ETH Crossover--> PC (Static IP: 192.168.1.40/42 I don't use cross-over cables for this situation. I am running barebox, which is a later version of u-boot. The mini2440 can ping the host, but the I can't ping the mini2440 from the host or another PC. My understanding that while in barebox bootloader mode that this is normal. Good luck
Would you mind sharing your compiled binary for barebox? Yes, that is what I'm trying to say when I referring to ping mode. You can't ping the mini2440 in bootloader mode because the ethernet interface is down. The only time the ethernet interface is up (in bootloader mode) is when the mini itself is trying to ping something else. Only then I can ping the mini, as it should be.
It is from here: http://www.oselas.org/oselas/bsp/pengutronix/mini2440_bsp_en.html and compiled for the 64M. If that is adequate I am sure I could send it in about 3 hours . . . going out right now. dave
Hi dave, Uhmmm, I wish you had a pre-compiled binary for the 128M. I don't have much time to compile another bootloader myself. But if you can't help it leaves me with no other choice. I've started downloadinf the config scripts and toolchains from Oselas and is busy reading the Quickstart PDF. But if you could help me I will really appreciate it. To be honest, I'm still a bit new to all the embedded linux stuff but is slowly getting some ground beneath my feet. I'm not sure if barebox will solve my ethernet problems, but I will still be great if I have the latest and greatest bootloader. Thanks
Well, this BSP is the best thing since "sliced cheese". Although, I imagine that if I hadn't been through a lot of pain over the last year I wouldn't really appreciate what a professional tool can provide. And what is really going on behind a build development tool. Most of the guys use OE, at work, but still there is a lot of hard work going into that to streamline our ARM development work. I am trying to get Qt (Arora) going at the moment. I have cross-compiled (or should I say ticked the right boxes!) for iptables, tcpdump and thttpd. Help will be there. Dave
Cool!, I will definitely have look at all of this then. Thanks for your help! How is Qt Arora different from the standard Qt (4.6.2)? Is your standard Qt at least running on PTX?
Arora is a web browser that uses Qt, in this case (the supplied BSP) Qt 4.6.3 It's compiling at the moment. However, it is after midnight and I have work tomorrow. BFN, dave
The same case i had meet with you ,when the u-boot is in ping mode and I can send ping message from host pc to it, but when the u-boot is not in ping mode , i can't send any ping message to it, there is a explain about why we must make the u-boot into ping mode , a function eth_halt( ) in u-boot source codes, it shows each time when u-boot ping achieves, the ethernet will be halt until next ping starts, so if you want to ping mini2440 from, you must comfirm the u-boot is in ping mode or change the source codes of ping , what's more , you can use nfs and tftp service even though the ping module is not so good . I am a senior studnet in china , maybe my english is not so good, I hope you can get my main idea.
Awesomeness!!! barebox solved this problem. I can ping the host and load the kernel over nfs. Thanks Dave
bluescape, if you really need only one component from the BSP (like the kernel or the bootloader), you also can build only this one component instead of the whole BSP (which may takes very long). For example to build the Barebox bootloader only: $ ptxdist targetinstall barebox Or the kernel only $ ptxdist targetinstall kernel instead of the "ptxdist go". Hope it helps.
Thanks Juergen, I'll definitely keep that in mind. What would I use to compile the rootfs (ptx) only? Keep up the good work guys, this ptx/oselas distro is looking good and very promising. Juergen, may I ask what is your position at ptx/oselas? MC
bluscape, as the root filesystem is "everything" there is only the "ptxdist go" command. Nothing to short the build time here, sorry. I'm one of the developers at PTX.
I can boot my kernel over nfs but not my rootfs. If my /env/config settings is: # can be either 'jffs2' or 'ubifs' rootfs_type=jffs2 rootfsimage=root.${rootfs_type} nfsroot="${eth0.serverip}:/home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440/ platform-mini2440/images What is the bootloader trying to load for the rootfs, root.jffs2 or is it looking for a root directory with all the rootfs directories? Just remember, I can boot my kernel over nfs but not my rootfs. I export the following path on the server: /home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440/platform-mini2440/images The images directory contains: -barebox-image -linuximage -root.jffs2 -root.tgz I get the following error when trying to load the rootfs over nfs: VFS: Unable to mount root fs via NFS, trying floppy. VFS: Cannot open root device "nfs" or unknown-block(2,0) Please append a correct "root=" boot option; here are the available partitions: 1f00 512 mtdblock0 (driver?) 1f01 384 mtdblock1 (driver?) 1f02 2048 mtdblock2 (driver?) 1f03 128128 mtdblock3 (driver?) b300 1931264 mmcblk0 driver: mmcblk b301 72261 mmcblk0p1 00000000-0000-0000-0000-000000000000mmcblk0p1 b302 915705 mmcblk0p2 00000000-0000-0000-0000-000000000000mmcblk0p2 Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) Function entered at [<c002ab24>] from [<c02bbb4c>] Function entered at [<c02bbb4c>] from [<c0008e8c>] Function entered at [<c0008e8c>] from [<c0008f6c>] Function entered at [<c0008f6c>] from [<c00090a8>] Function entered at [<c00090a8>] from [<c0008ae8>] Function entered at [<c0008ae8>] from [<c0026a1c>]
bluscape. replace your "nfsroot="${eth0.serverip}:/home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440/ platform-mini2440/images" by "nfsroot="${eth0.serverip}:/home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440/ platform-mini2440/root" and you are done. The content of "images/" is intended to be written onto a SD card (root.tgz) or into the onboard NAND (root.jffs2)
What should the server export? "nfsroot="${eth0.serverip}:/home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440/ platform-mini2440/images" OR "nfsroot="${eth0.serverip}:/home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440/ platform-mini2440/root"
Just a minute here . . . on the server you need: in /etc/exports /home/jdoe/local/OSELAS.BSP-Pengutronix-Mini2440/platform-mini2440/root *(rw,no_root_squash,sync,no_subtree_check) For the * you can put in a statically assigned address of the mini2440, if you want. I attached the doc way up the list.
I've been following the doc but had no success with loading the rootfs over nfs. Only mistake in the doc thus far is you typed: /etc/export which should be /etc/exports
To be honest, I've not been able to boot anything using using the nfs-kernel-server. The only method with which I could at least boot the kernel was this: http://www.davidsudjiman.info/2006/03/27/installing-and-setting-tftpd-in...
export/exports, that's a hoot! Juergen said export I told him it should be exports and then I write export! If you do <netstat -uap> can you see the server running. I was a moderately painful process getting NFS running, but boy is it worth it. Which desktop distro are you running?
Ok, solved my problem. Used the method in this link: http://www.davidsudjiman.info/2006/03/27/installing-and-setting-tftpd-in... Then I did the following: 1. Go to Synaptic Package Manager (Ubuntu) 2. Search for atftp 3. uncheck (uninstall) tftpd and check atftpd and atftp 4. then click on Apply button to install 5. sudo /etc/init.d/xinetd stop 6. sudo /etc/init.d/xinetd start 7. sudo /etc/init.d/xinetd restart And its working!! Now I can load my rootfs over nfs.
Great, now re-write the HowTo based on your installation! Never read anything about atftp. The other option to nfs-kernel-server is nfs-user-server, but that wouldn't work for me. What size mini2440 have you got? Did you manage to get Arora working?
"Hang on a minute". I don't see any mention of NFS in atftp or do you mean you couldn't get tftp to work, not NFS. tftp loads the kernel and NFS loads the rootfs.
Exactly as you say. Didn't know the difference, but reading it makes sense. kernel -> tftp was working rootfs -> nfs was not working I guess I could have solved it quicker if I realized the differences earlier. Now I can just see the advantages of running the rootfs over nfs, update programs without having to reboot or having to copy them to some portable media such as a SD card. Yipppeee. Dave, my Qt is now working on ptx. I initially ticked the boxes for arora but after a few compiles I disabled it because it took to long having to compile all the webkit stuff which is not what I need right now. But I sure will try to compile arora at some stage. I even tried the qt transformed stuff which now enables me to run a Qt app in landscape orientation on the standard 3.5" portrait LCD (T35) from FriendlyARM.
I've got two 128M NAND, 3.5" display mini's, if that is what you are asking. One from FriendlyARM and another from Hiteg. I'll soon get a 1G mini. How is the SD card stuff going? You must tell me how you configure barebox to load the kernel from SD.
I have done it using u-boot, so it shouldn't be too much of a drama. I have a script that will partition the SD card, now all I need are the magic words in /env/config instead of <net> or <nand>. I'll tell you when I get it going. OK, you would probably have no problems running Arora on a 128M machine, if you ever wanted to. That will be a 1G mini6410? Dave
Just for my information, why not the 6410? Or do you see it as another potentially big learning curve. Trying to make up my own mind. Thanks, Dave You can email dave underscore festing at hotmail dot com if you prefer to discuss these off-forum.
Barebox is prepared to work with an SD card. Plug it in, power your system and enter "mci0.probe=1". This will detect the SD card and creates disk0.* devices (according to the partition table on this SD card) in "dev/" to have access to the data on it. You can now download a kernel (for example) to write it to the SD card (if not already done): "tftp my_own_kernel /dev/disk0.1". This will load the "my_own_kernel" from your defined TFTP server and store it into the _second_ partition of the SD card (if more than one partition exists on your card). After that you can start this kernel with "bootm /dev/disk0.1". The default Barebox's environment needs some adaptions to support automatic boot from SD card instead of the NAND. Maybe I will add this into one of the next BSP releases if I had time for it.
Hi, I am also facing same problem with my board(P3041DS). Since last two days it stopped pinging from my board to host. Anyone can help me. I have looked all environment variables, all are fine. Is there any new cause for ping fail. Thanks, Vijaya.
