Hi, I am working on Mini2440. I wrote some example qt4 application and tried to run it. When my application is started and i touch the screen, sometimes application in the background or desktop is activated. Is there a way to prevent the background apps from activating when running Qt application? Please let me know what could be the problem
background activated when qt4 app is running
Do You have Qtopia in background? If yes - You should kill that process. If You are running more then one QT4 app - the first one should be run with '-qws' parameter, and the other can work without it. best regards Tom
Hi, I have exactly the same bug. @Tom You are not the first to tell me to kill all Qtopia process. But how, that's the question. I try to click on éterminate server" just before to run my Qt app, but once the server is turn off, you don't have mouse or touch screen any more.
Had same problem as You when I was starting working with Mini2440. You should have console on Your PC screen. Then "ps | grep qtopia", and after that You can kill qtopia process using process ID. You should also turn it off somewhere in starting scripts (rcS?) - I can't remember where it whas because I'm using now distribution without qtopia (but I was running QT apps on also on original distribution - worked fine). good luck Tom
Ok, with a console on the PC, I agree but it's not a reliable solution. I tried to suspend qpe and qss process, then I ran my Qt app (works well) and then continue qpe and qss, but after that the screen is black and Qtopia is partially displayed when I touch the screen. After I run my Qt app, FriendlyARM's apps don't start anymore. An idea ? Thanks.
You can try the fluidlauncher demo in the embedded demos of QT4, there is background widget (laucher) and many application widget, but it works well :)
My steps are: Edit file qt4: vi /bin/qt4 Comment the lines: #cd /usr/local/trolltech... #./fluidlaunexec /bin/qt4 1>/dev/null 2>/dev/nullcher -qws Add lines: cd /home/plg ./MyQtApp -qws Edit file qtopia: vi /bin/qtopia Comment line: #exec $QPEDIR/bin/qpe 1>/dev/null 2>/dev/null Add line: exec /bin/qt4 1>/dev/null 2>/dev/null Reboot System: reboot
