Hi how can i get the coordinate when i tap on the screen ? I'm using Ucos and the touch feature not working . i want to get the coordinate of the screen when i tap on it . can anybody help me ?
get coordinate when tap on the lcd
You need a driver for your OS to handle the S3C2440's internal ADCs to do the job. Read the processor's manual and/or take a look into the Linux kernel sources: "drivers/input/touchscreen/s3c2410_ts.c"
It's easy to do: Example from STARTOS pacckage: ............................................. if(Pen_Buffer_Address[0]) // Was Pen pressed ? { Buzz(5000, 20); Pen_Buffer_Address[0]=0; // Clear Flag & wait next press x=Pen_Buffer_Address[1]; y=Pen_Buffer_Address[2]; Dec2Asc(x, (char *)txt); Set_Font(0,0xFFFF,0x5000); Print_Buffer(42, 10, (char *)txt); Dec2Asc(y, (char *)txt); Print_Buffer(110, 10, (char *)txt); } ............................................ NO Drivers needed!
Hello elenor! The example of 2440test Mini2440 provides a driver to identify the touch screen. However, the coordinates provided by the example are not compatible with the screen, thus requiring an algorithm to calibrate the screen, as well as the routine ts_calibrate for Linux. Did I make this adjustment without OS, following the example 2440test and using some parts of the algorithm ts_calibrate ts_lib library. If anybody is interested in the routine to calibrate the touch screen applications without OS, please send me an email I can provide the code to Keil or 4 Metrowerks CodeWarrior. SDI also have routines for reading and writing blocks of the SD card, but have not found a good FAT library to work, if someone can help me ... nilsao@gmail.com
hi Nilson, perhaps you could try my library for FAT32 driver but only for FAT32 file system and not FAT16/12, it support long filename if that's what you're looking for, i've tested it on my mini2440 and it works find for read/write, the file deletion still has problem though, be sure to backup your SD card content. tutorial: http://my.opera.com/kuriel/blog/2011/04/29/elvish-fat-library download: https://github.com/kuriel07/eFAT
