HowTo Compile my own kernel and make image?
mso
Is there anywhere a howto for download, which explains
compiling the kernel and making the image?
thanks a lot
Search for "Building Embedded Linux Systems.pdf"  Excellent book.
Killerwatt
Here you will also find a Quick Start.
http://www.andahammer.com/downloads
Vladimir Fonov
Unpack kernel from friendlyARM, install tools , setup environment
variables:
CROSS_COMPILE=arm-linux-
export CC=${CROSS_COMPILE}gcc;
export AR=${CROSS_COMPILE}ar;
export AS=${CROSS_COMPILE}as;
export LD=${CROSS_COMPILE}ld;
export NM=${CROSS_COMPILE}nm;
Then
cp config_mini2440_t35 .config
make oldconfig CROSS_COMPILE=arm-linux-
make zImage CROSS_COMPILE=arm-linux-
and you will have a new zImage.
rose
I want a kernel u-image to run with u-boot.Can i create that with the
source i got in the dvd?
mkimage –A
     arm –O linux -T kernel -C none –a
     0x30008000 –e 0x30008000 -d kernel-
     bin/arch/arm/boot/zImage output/uImage
cd to where ever you have mkinage
You will need to change to your path to kernel-bin/arch/arm/boot/zImage
output is just a directory to hold your uImage
rose
well thankx for the reply but i cant make out anything of it.
could you write the steps in order please!:)
dave
Have you got mkimage on your system?
1. mkdir output
2. cd to where ever you have mkimage on your system
3. then in the command line type in:
mkimage –A arm –O linux -T kernel -C none –a
0x30008000 –e 0x30008000 -d path/to/your/zImage path/to/output/uImage
If you study the script mini2440-bootstrap-v2.sh at
http://code.google.com/p/mini2440/downloads/list
that may help.
I believe my copy of mkimage appeared after following this script, ie after
doing a kernel compilation.  I haven't tried running mkimage by itself.
andromeda
the variable CXX must be exported too ?
export CXX=${CROSS_COMPILE}g++ ??
thanks.
rose
i did it thanks dave and all.
nw can anyone give me a kernel uImage??
tried downloading the git but i freezes after 16mb download
I am confused . . . you said "i did it", which I asume is generate a uImage
and now you want a uImage??
I will be posting a tutorial covering this topic on the Wiki this weekend
and if permitted I'll upload a uImage from 2.6.32.7 that has a fair bit of
stuff stripped out of it and my_rootfs.jffs2.
Have a crack at this tutorial first, it is a good starting point.
http://narnia.cs.ttu.edu/drupal/node/131
Dave
eduardo
To build your kernel:
Follow the steps described on chapter 5.4 user manual from micro2440 manual
(available on download area (only chinese)) to build your
development environment. Then go to linux-2.6.29 folder and type as root:
To change kernel options:
sudo make menuconfig
To build kernel:
sudo make zImage
After some minutes zImage will be available on ./arch/arm/boot.
Use usbpush (on linux) or dnw (on windows) and send it to your board.
:D
try out and tell us your result.
useful link:
http://www.friendlyarm.net/forum/topic/492?lang=en
rose
@dave.. :) i was happy i was able to convert zimage to uImage(the way u
told meh!).but that Uimage doesnt work with jffs2 .while kernel starts it
says loading yaffs.and i'm using U-boot.
Can u tell me how could i create a uImage with buildroot.?I tried seleting
both jffs2 and kernel in make menuconfig and when i make it says
"No U-Boot board name set.BR2_TARGET_UBOOT_BOARDNAME setting. stop.
@eduardo
thanks.but i need steps for creating uImage.
Haven't used buildroot.
Think you need state what you are trying to do.
- which kernel image
- which file system
- modules built-in or loadable
- building your own rootfs?
just for starters.
Send your email address to:
dave_festing at hotmail dot com
and I'll send you a draft tutorial that might help.
How did you get on with the tutorial at:
Dave
Raja sekhar
Hi
Can any one help me to sort out this problem..
I am getting this error while image building.
(i have already configured arm-linux-gcc path)
ubuntu@ubuntu:/home/practise/linux-2.6.32.2$ sudo make zImage
make: arm-linux-gcc: Command not found
scripts/kconfig/conf -s arch/arm/Kconfig
  CHK     include/linux/version.h
make[1]: `include/asm-arm/mach-types.h' is up to date.
  CHK     include/linux/utsrelease.h
  SYMLINK include/asm -> include/asm-arm
  CC      kernel/bounds.s
/bin/sh: arm-linux-gcc: not found
make[1]: *** [kernel/bounds.s] Error 127
make: *** [prepare0] Error 2
thanks in advance
raja sekhar
redeagle
1. don't use sudo - you don't need root-permissions to compile stuff
2. does the following command work?
arm-linux-gcc --version
If not:
 - check if your cross-compiler's name is really "arm-linux-*"
 - export the path you have your cross-compiler installed to $PATH
Eng Halim
Raja sekhar
check the cross compiler PATH
Raja Sekhar
hi
Yeah, i have checked cross compiler PATH, it is working fine for the
command : "arm-linux-gcc -v".
thanks in advance
raja sekhar
kaushal billore
mkimage is a dependent or independent tool to create the uImage out of
zImage?
I have copied the mkimage tool to linux2.6.24/ dir from some unknown source
linux2.6.24#make ARCH=arm CROSS_COMPILE=arm-linux- uImage
is not making the same uImage which I got from the vendor.
akshay
i have made kernel image and now i have my zimage inside boot folder.Now
what should i do to build it to mini2440.
You need to transfer the zImage to the mini2440 not build it.
Here is one tutorial:
http://mini2440vietnam.blogspot.co.nz/2011/01/install-linux-into-mini244...
Have you not got any of the standard mini2440 documentation, ie User manual
mini2440vietnam is a good site for tutorials
