Hello, When I bought a mini35 I received as a gift from FriendlyARM a USB to serial converter (Prolific 2303 chip). mini2440 doesn't seem to receive what the computer sends, but the computer receives everything OK from mini2440. I tried the converter in the desktop computer which serial port I've used previously to communicate (successfully) with mini2440, and the result is the same as with my notebook. I tried the converter both under Linux and under Windows with same results. Has anyone experienced something like that? What USB to serial converter should I buy? Regards, Esteban
hi most of the USB to serial converter has problem , change your converter in will be fine , i try 3 different converter to find the one has no problem now i use Dtech converter and it works fine good luck
This could be some other problem also, we faced similar issue with some u-boot code and when we changed the u-boot, it is fine. Please check this. Good luck.
Hi, i'm with the same problem. When I use my board with the serial to USB converter i just see what the PC sends to me. When I try to type something nothing happens. Elucches, did u solve your problem? Any kind of conversor that works? Att Davi
i am using brand BAFO.. and working fine.. follow link. http://www.bafo.com/products_bf-810_F.asp
This is a general problem with some of the older models of the Prolific processor chip inside the adapter. The more expensive adapters use a chip from FTDI which has better drivers and compatibility. I got mine here: http://www.usconverters.com/index.php?main_page=product_info&cPath=6... and it works fine.
