Hi there! I compiled a new system for mini2440 using Buildroot (I'm trying to use Qt). I used the kernel avaliable here in this site (2.6.32.2) and compiled it and the libs Ok. The screen is working (is a X35), and the system runs Ok. But, when I try to run a ts app (e.g. ts_calibrate), it returns 'ts_open: No such device'. The environment variables that I set are the following: export TSLIB_TSEVENTTYPE=INPUT export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_TSDEVICE=/dev/input/event1 export TSLIB_CALIBFILE=/etc/pointercal export QWS_MOUSE_PROTO=tslib:/dev/input/event1 I tried to change the 'event' with 0, 2 and 3, but the error is the same. Anyone can help me?
Error with the tslib
You can check that your TSLIB_DEVICE is really event1 by: cat /dev/input/event1 and moving the stylus around on the screen while logged in using minicom or similar. You should see garage on the minicom screen. Did you cross-compile your own tslib? I'd check that it really has been cross-compiled. Also, maybe have a look at: http://billforums.station51.net/viewtopic.php?f=8&t=15&start=130 Good luck! Dave
Hello! First, I can't open any of /dev/input/eventX. When I try to open it with cat, it return: cat: can't open '/dev/input/eventX': No such device About the cross-compilation, I compiled it with the Buildroot tool - it generated a complete system, with the selected libraries. I selected Qt -> Mouse support -> tslib. I also tried to run ts_finddev, but it returns nothing.
What entries do you have in /dev/input? There is also a place to look in /sys. Sorry, I am at work and the full path is at home. Something like /sys/proc/virtual/ .. ??
Try looking in: /sys/devices/virtual/input/input1 and seeing what is there and then: cat /sys/devices/virtual/input/input1/eventX and so forth. For event1 you might see something like: c 13:65 then the /dev/input entry for event1 should have the same: c 13:65 I have only observed this and have not tried playing around with these entries. I believe mdev or udev creates them.
In the /dev/input, I have the following: event0 event1 event2 event3 mice mouse0 mouse1 mouse2 mouse3 In the /sys/devices/virtual/input, I only have a folder called 'mice'.
Rafael, are you using persistent device nodes? Or do you run 'udev' on your system? If you are using persistent device nodes there is no correlation between the device nodes and the really existing devices in your kernel.
Ups, comment forgotten: When your /sys/devices/virtual/input is mostly empty, it means: a) there is no touchscreen device registered b) the touchscreen driver in the kernel is disabled (or not loaded in the case of a module) A solution for a) needs a kernel patch, a solution for b) needs some changes in the kernel configuration
here i am using capacitive touchscreen . i am not able to move the touch point on lcd . please suggest me where i am going wrong. #dmesg input: TSC2007 Touchscreen as /devices/virtual/input/input1 #cat /proc/bus/input/devices I: Bus=0019 Vendor=0001 Product=0001 Version=0003 N: Name="TWL4030 Keypad" P: Phys=twl4030_keypad/input0 S: Sysfs=/devices/platform/i2c_omap.1/i2c-1/1-004a/twl4030_keypad/input/input0 U: Uniq= H: Handlers=kbd event0 evbug B: EV=100013 B: KEY=400 0 0 0 0 0 0 0 0 0 80000000 0 800 8400 0 c011 13d08bfe B: MSC=10 I: Bus=0018 Vendor=0000 Product=0000 Version=0000 N: Name="TSC2007 Touchscreen" P: Phys=3-005c/input0 S: Sysfs=/devices/virtual/input/input1 U: Uniq= H: Handlers=mouse0 event1 evbug B: EV=b B: KEY=400 0 0 0 0 0 0 0 0 0 0 B: ABS=1000003 I: Bus=0003 Vendor=192f Product=0416 Version=0111 N: Name="USB Optical Mouse" P: Phys=usb-ehci-omap.0-2.4/input0 S: Sysfs=/devices/platform/ehci-omap.0/usb1/1-2/1-2.4/1-2.4:1.0/input/input2 U: Uniq= H: Handlers=mouse1 event2 evbug B: EV=17 B: KEY=70000 0 0 0 0 0 0 0 0 B: REL=143 B: MSC=10 using #evtest /dev/input/event1 home/root/evtest /dev/input/event1 Input driver version is 1.0.0[ 1152.566101] evdev.c(EVIOCGBIT): Suspicious buffer size 511, limiting output to 64 bytes. See http://userweb.kernel.org/~dtor/eviocgbitl Input device ID: bus 0x18 vendor 0x0 product 0x0 version 0x0 Input device name: "TSC2007 Touchscreen" Supported events: Event type 0 (Sync) Event type 1 (Key) Event code 330 (Touch) Event type 3 (Absolute) Event code 0 (X) Value 0 Min 0 Max 320 Fuzz 4 Flat 8 Event code 1 (Y) Value 0 Min 0 Max 480 Fuzz 4 Flat 8 Event code 24 (Pressure) Value 0 Min 0 Max 255 Testing ... (interrupt to exit) Event: time 1129.296752, type 3 (Absolute), code 0 (X), value 89 Event: time 1129.298858, type 3 (Absolute), code 1 (Y), value 384 Event: time 1129.299011, ------------ Report Sync ------- Event: time 1129.321746, type 3 (Absolute), code 0 (X), value 0 Event: time 1129.321990, type 3 (Absolute), code 1 (Y), value 0 Event: time 1129.322113, -------------- Report Sync ------------ Event: time 1129.372467, type 3 (Absolute), code 0 (X), value 89 Event: time 1129.372833, type 3 (Absolute), code 1 (Y), value 384 Event: time 1129.372955, -------------- Report Sync ------------ Event: time 1130.796813, type 3 (Absolute), code 0 (X), value 168 Event: time 1130.798919, -------------- Report Sync ------------ Event: time 1130.817749, type 3 (Absolute), code 0 (X), value 0 Event: time 1130.817993, type 3 (Absolute), code 1 (Y), value 0 Event: time 1130.818115, -------------- Report Sync ------------ Event: time 1130.890594, type 3 (Absolute), code 0 (X), value 168 Event: time 1130.892639, type 3 (Absolute), code 1 (Y), value 384 Event: time 1130.892822, -------------- Report Sync ------------
