Is it possible to run an ssh server on the friendly ARM so that I don't have to use a COM port to communicate with it from my PC?
remote console using ssh
Hello, the easies thing is to use telnet - it is already setup, if you are using default ip just telnet 192.168.1.230 to get the console. Otherwise, if you really need to encrypt everything try to compile dropbear ssh server: http://matt.ucc.asn.au/dropbear/dropbear.html
If you need openssh 5.5 binaries here you can download. http://www.dengebt.com/ssh5.5_dengebt.com.tar prefix is by default /usr/local/bin
I'm running ubuntu and i simpled typed into the console. ssh 192.168.1.230 and i got.... ssh: connect to host 192.168.1.230 port 22: Connection refused I went into my router and forwarded port 22 for 192.168.1.230, but still nothing. What am i doing wrong?
For those can not figure out how to activate sshd : You need to have your sshd proper configuration file in /etc/ssh/sshd_config and have your ssh port configured in your linux. then get your sshd started when your OS started or manually when you need it.
Hi, I got it working you have to crosscompile the dropbear copy it to pc, generate keys as it written inside the readme of dropbear and copy them inside the /etc/dropbear directory. After this you should able use ssh without any problems. Also it's possible to use sftp by building and ssh and crypto library to use sftp together with ssh ;)
