Hi, I've been able to load the Android 2.3 image from the latest ISO available via the FTP site. The image boots up and runs fine on a mini6410 with the "N43" 4.3" LCD. I can use the pushbuttons for control, but the touchscreen doesn't work. Sometimes the console port shows messages like "mini6410-ts: touch event buffer full". If I run 'cat /dev/input/event1', some characters are printed whenever I touch the screen, so I suspect the hardware is OK. I know some of the older mini2440 android images had a calibration routine that ran at boot... I can't seem to find anything like that in this image. Could that have anything to do with it? Thanks, Andrew
mini6410 4.3" touchscreen not working with Android
OK... part of the problem was that my u-boot environment was set up wrong (init=/init instead of init=/linuxrc), thus bypassing the calibration routine. Will try again and report back. -Andrew
