Hi I am developing a project about stereo vision with my mini2440, use 2 USB webcams and OpenCV-2.0. I can successfully cross compile my program and my libraries and moved them on my board. I have a problem with my webcams. With one webcam (and a program using single camera) it works fine. But when I connect two webcams via hub this error appears : VIDIOC_STREAMON : No space left on device. VIDIOC_QBUF : Invalid argument. I searched a little about it and I found that it can be solved with PCI USB Host. My question is that is it possible to connect it to board or not? I mean we have to install its driver? thank you
I am also trying the same (but in a laptop, for opencv). I need 3 cameras to work simultaneously. I am using integrated webcam of laptop and 2 external cameras.I was able to get all 3 cameras working if I change the camera capture property resolution to 320 x 240, using cvSetCaptureProperty() api. But this resolution is not enough as I need minimum 640 x 480, which gives the error, libv4l2: error turning on stream: No space left on device VIDIOC_STREAMON: No space left on device output of dl -h is Filesystem Size Used Avail Use% Mounted on /dev/loop0 29G 16G 12G 57% / udev 1.9G 4.0K 1.9G 1% /dev tmpfs 765M 876K 765M 1% /run none 5.0M 0 5.0M 0% /run/lock none 1.9G 104K 1.9G 1% /run/shm /dev/sda3 457G 392G 65G 86% /host So how to get all 3 cameras working at more resolution? How to increase the space?
I believe in this context "No space left on device" means that there is insufficient USB bus bandwidth to stream from 3 cameras simultaneously, it isn't referring to disk space.
I am encountering the same problem, does anyone have a hardware or software solution for this? I'm working on a multi-camera input for my Cubieboard 2.0 ARM based board. Any recommendations would be welcome. Thanks.
I think imaging from three cameras will take a lot of data moving about. IS this real-time or still images? If you can sequence the reads from the cameras one at a time you can avoid the bottle neck. There is plenty of room in RAM even on a Mini2440. I use the standard kernel, Debian, Python, and X with tKinter and have 24 MBytes of RAM left for application space. You can use a Tiny210SDK with the USB hub chip on board and 3 USB host connectors. The 512M RAM and 1 GHZ might solve the problem. Plus there is video/image transcoding hardware that could be accessed with some custom routines. If not, the new Tiny4412 is a quad core 1.5 GHz. Basically a Samsung Series 3 Chromebook with two more cores. Other alternative that only costs time: Bare metal no OS C program. Or use the sample uC/OSII real-time OS. Small with very low overhead but they have some libs that could make reading the cameras a lot easier.
The restriction is the USB bus and its available bandwidth, *not* CPU power. Three USB HC would solve the problem (one HC per camera), but maybe not one USB HC with a HUB to attach three cameras to.
Hello Concern Person, Greetings!!! We are connecting usb web camera to linux centos 6.3 system but not connecting we are getting following error: libv4l2: error turning on stream: No space left on device Please let us know your feedbcak for same.
