I tried to find the gpio in /sys/class, but the folder doesn't exists. I haven't found it in /dev too. The manual doesn't have any example (I'm using the Qtopia image from DVD). How I can use it?
GPIO in mini6410
check out my website ipensive.com there's a tutorial for that You need to modify, mach-s3c2440.c file, and configure using "make menuconfig", then goto Device Driver->GPIO->/sys/class/gpio enable that. Good luck.
Hi my Friend Now I use tiny6410 Friendly ARM. I want to modify mach-mini6410.c on function "mini64210_machine_init(void)" gpio_request(S3C64XX_GPN(5), "LCD power"); gpio_request(S3C64XX_GPF(13), "LCD power"); gpio_request(S3C64XX_GPF(15), "LCD power"); gpio_direction_output(S3C64XX_GPM(5), 1); //my code for control gpio port gpio_direction_output(S3C64XX_GPM(4), 1); // my code for control gpio port .... .... I'm save and make image file successed. I'm burn image file to my Tiny6410 it's work. But I'm use command line echo 142 > export finish I not found export142 in /sys/class/gpio/ Advice me please T.T Fiat..
Hi guys I have been trying to use the GPM port. But my code shows an error on doing "make modules". It says that S3C64XX_GPMCON not declared before. But when I change it to S3C64XX_GPECON, it works perfectly fine. What can be the error? I have not used any macro (which I saw in some of the codes on the internet) like #define S3C64XX_GPMCON(some base value in hex + some offset value in hex).
not found help me please ---------- [root@FriendlyARM /]# cd sys [root@FriendlyARM /sys]# cd class [root@FriendlyARM class]# cd gpio -sh: cd: can't cd to gpio [root@FriendlyARM class]# ls bdi input mtd scsi_generic video4linux block leds net scsi_host vtconsole firmware mem rtc sound graphics misc scsi_device tty i2c-dev mmc_host scsi_disk vc [root@FriendlyARM class]# cd gpio -sh: cd: can't cd to gpio
Hi Elexal Reconfig you kernel with make menuconfig Device Drivers >> GPIO Support >> /sys/class/gpio/... (sysfs interface) Save
Hi I have the same problem like @Elexal . but when i wrote make menuconfig in my tiny6410 i see error. [root@FriendlyARM /]# make menuconfig -sh: make: not found (i wrote this command in my FriendlyARM terminal). how can i active menuconfig in tiny6410.
Hi. I say my answer: to reconfig the kernel you should do this: 1 - go to cd/dvd of your device (like the dvd A for tiny6410) 2 - select the OS folder you used (I use Linux) 3 - select the OS version ( in mine is linux-2.6.38 ) 4 - untar it and go to folder in terminal. 5 - ( in ubuntu befor go to menuconfig at first should install these library) sudo apt-get install git ncurses-dev make gcc-arm-linux-gnueabi then run this command: make menuconfig then you can edit config.
