Code:Blocks 8.02 using arm-linux-gcc-4.3.2 with EABI for the FriendlyArm Mini2440 on Kubuntu 9.4 1. download “arm-linux-gcc-4.3.2 with EABI” from www.friendlyarm.net/downloads 2. in Root sudo mkdir FriendlyArm and put arm-linux-gcc-4.3.2.tgz in it 3. cd FriendlyArm 4. either extract it or “tar –xvf arm-linux-gcc-4.3.2.tgz” 5. navigate to home/username and find .profile (View, Show hidden files) and click on .profile and in Kate add the line: export PATH=$PATH:/FriendlyArm/usr/local/arm/4.3.2 6. re-start the system 7. In Code::Blocks set up a new project, ie MyTest 8. go to Settings/Compiler and debugger and in Select compiler find GNU ARM GCC compiler, select it and Set as default or it reverts to GNU GCC Compiler everytime you start a new project 9. in the tab Toolchain executables (make sure this window is maximised or you don’t see this tab!) and Compiler’s installation directory put /FriendlyArm/usr/local/arm/4.3.2 (bin not necessary) 10. now in the Program Files window: C compiler arm-linux-gcc-4.3.2 C++ compiler arm-linux-g++ Linker for dynamic script arm-linux-g++ Linker for static libs arm-linux-ar Debugger arm-linux-gdb Now, click OK. Your own project: 1. File, New, Project . . . MyTest 2. File, New, File . . . add the adc-test.c example 3. Build, Compile, Build 4. the executable is called MyTest 5. place MyTest in the usr/bin directory where the other FriendlyArm apps are placed 6. in Terminal cd your way to this directory and type in MyTest and presto it runs. Credit to Mankin for the kickstart
Code:Blocks 8.02/arm-linux-gcc-4.3.2/Mini2440/Kubuntu9.4
According to other documentation a .gpz file should be uncompressed first, ie: “tar –zxvf arm-linux-gcc-4.3.2.tgz” Didn't seem to make any difference to me.
Thanks for this rundown, works great! If anyone knows how to get a development environment for Qtopia running, please post.
I am running ubuntu 9.04(x86_64 GNU/Linux) and getting this peculiar problem. I did exactly as it mentioned. /FriendlyArm/usr/local/arm/4.3.2/bin/arm-linux-g++: line 3: /FriendlyArm/usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-g++: No such file or directory /FriendlyArm/usr/local/arm/4.3.2/bin/arm-linux-g++: line 3: /FriendlyArm/usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-g++: Success
You are in luck! Had that one happen to me tonight as well. In Codeblocks you make an empty project. I also tried a D application (whatever that is) and it worked as well. Seems if you make a console project is goes looking for arm-none-linux-gnueabi. Don't ask me why, I don't even know the difference between these two versions! Sorry, I didn't mention that in the listing above. Good luck
I could not solve the file not found problem in ubuntu. But, I could easily cross-compile on SUSE and Red Hat and run it on mini. Maybe there is some issues with setting the path names in ubuntu. Even the code sourcery lite tools failed to work on ubuntu. So, I am changing my cross-compile host to SUSE. If anybody could get this done on ubuntu, please post onto this forum.
1. download “arm-linux-gcc-4.3.2 with EABI” from www.friendlyarm.net/downloads I can't find the gcc on this page. Where shuld I look?
Worked like a charm at first attempt on Ubuntu 10.4, thank you :) My Mini2440 is still on the way, I can't wait to get it :D
Hey, You can either plug the SD card into your computer and copy it over to the filesystem if its uncompressed, otherwise I setup ethernet on the mini2440 as follows: edit with vi /etc/network/interfaces Either setup the eth0 with dhcp or setup manually like this: auto eth0 iface eth0 inet static <tab>address 192.168.0.10 <tab>netmask 255.255.255.0 <tab>gateway 192.168.0.1 <tab>network 192.168.0.0 make sure you tab Restart the networking /etc/init.d/networking restart edit with vi /etc/resolv.conf Add your dns servers: nameserver xxx.xxx.xxx.xxx nameserver xxx.xxx.xxx.xxx Now you can access the mini2440 by using SFTP and 'root' as a login user. I use filezilla cos I'm lazy :) By the way, you don't need to setup the dns for the SFTP to work, but if you setup the dns you can use the opkg command much like you use apt-get in ubuntu. Enjoy!
hola estoy trabajando con ubuntu 12.04 y sale error line 3 cuando doy arm-linux-gcc -v diego@ubuntu:~$ arm-linux-gcc -v /usr/local/arm/4.3.2/bin/arm-linux-gcc: línea 3: /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-gcc: No existe el archivo o el directorio
hello I am working with ubuntu 12.04 and get error line 3 when I arm-linux-gcc-v diego@ubuntu:~$ arm-linux-gcc -v /usr/local/arm/4.3.2/bin/arm-linux-gcc: línea 3: /usr/local/arm/4.3.2/bin/arm-none-linux-gnueabi-gcc: No existe el archivo o el directorio
