Hi all, So, now that I'm getting closer to working out the major bugs in the software, I'm beginning to think about how to apply some of the finishing touches. Two of these are: - Changing the tux boot logo to be something more appropriate. Is there a HOWTO anywhere on changing the boot logo under linux on the mini6410 ? I'll be using the 7" screens, so preferably want to make a new image, larger, and centered, if that's possible. - My 7" screen seems to have its calibration drift over time. To that end, I've included a way for the user to launch ts_calibrate from the UI and restart the app. Ideally I'd like to remove the friendlyArm advertising there (I've paid for the board. I don't see why I ought to showing adverts for FriendlyArm...). Is the source for ts_calibrate available anywhere ? I guess I could use a hex editor and replace the text with spaces, but that seems... inelegant. Thanks in advance for any help :) Simon
Productising the mini6410
I'm not sure, but i think you can find all the sources. I'm using buildroot to generate the images to my mini2440 and I have all the sorces inside the buildroot directory. Try use buildroot.
Source for ts_calibrate at: http://www.koders.com/c/fid48DBC8EDA08CA3C822F7CF53C3F595B0B2DA2C0A.aspx
