set linux system time from Qt
bao
How can I change the system time from a Qt application?
I can change that by hwclock from terminal, but I want to provide a GUI for
user.
Simon
I do it by calling
   sprintf(buf, "/bin/date -s %04d.%02d.%02d-%02d:%02d", year, month, day,
hour, min);
   system(buf);
   system("/sbin/hwclock -w");
... in my user-pressed-the-ok-button slot. Seems to work well enough :)
Ajiesh
If I execute the hwclock command I get the  error message as 'Only
superuser can change the system time' can you please give solution
Which machine are you running this on?  What kernel are you using?
Can you browse and edit files in root without putting in a password?
Juergen Beisert
Ajiesh,
sure. Only the root user can change system settings. Its a feature, not a
bug ;) -> "man sudo"
Ajiesh
How to become a root user........... I have to change the date and time for
phytec board AM335x...... it is possible to change by using qt
programming..........
foru
#ifndef SETTING_H
#define SETTING_H
#include"formula.h"
#include <QWidget>
#include"dialog.h"
#include<QLineEdit>
#include<QLabel>
class setting : public QDialog
public:
    setting();
    class formula *main_class;
    QLineEdit *offset;
    QLineEdit *multiplier;
    QLineEdit *timeinterval;
    QLabel *off;
    QLabel *mul;
    QLabel *time;
    QPushButton *Apply;
    QPushButton *close;
  public slots:
    void done_value();
#include "setting.h"
setting::setting()
main_class = new formula();
    offset = new QLineEdit;
    multiplier = new QLineEdit;
    timeinterval = new QLineEdit;
    off = new QLabel("OffSet       :");
    mul = new QLabel("Multiplier   :");
    time = new QLabel("TimeInterval:");
    QHBoxLayout *h1 = new QHBoxLayout;
    h1->addWidget(off);
    h1->addWidget(offset);
    QHBoxLayout *h2 = new QHBoxLayout;
    h2->addWidget(mul);
    h2->addWidget(multiplier);
    QHBoxLayout *h3 = new QHBoxLayout;
    h3->addWidget(time);
    h3->addWidget(timeinterval);
    Apply = new QPushButton("Apply");
    close = new QPushButton("Close");
    QHBoxLayout *but = new QHBoxLayout;
    but->addWidget(Apply);
    but->addWidget(close);
    QFont font ;
    font = off->font();
    font.setPointSize(30);
    off->setFont(font);
    font = off->font();
    mul->setFont(font);
    font = off->font();
    time->setFont(font);
    QVBoxLayout *final = new QVBoxLayout;
    final->addLayout(h1);
    final->addLayout(h2);
    final->addLayout(h3);
    final->addLayout(but);
    setLayout(final);
    QObject::connect(Apply,SIGNAL(clicked()),this,SLOT(done_value()));
    QObject::connect(close,SIGNAL(clicked()),this,SLOT(close()));
void setting::done_value(){
        float f;
        QString  line1 =offset->text();
        QTextCodec *codec =QTextCodec::codecForName("KOI8-R");
        QByteArray byte1 =codec->fromUnicode(line1);
        main_class->c = byte1.toFloat();
        QString  line2 =multiplier->text();
        QByteArray byte2 =codec->fromUnicode(line2);
        main_class->m = byte2.toFloat();
        QString  line3 =timeinterval->text();
        QByteArray byte3 =codec->fromUnicode(line3);
       main_class-> timeinterval = byte3.toFloat();
    this->hide();
Error:Object::connect: No such slot QDialog::done_value()
