Hi There, Im Trying to access the GPIO using c++ Whenever i try to set any register the programm fails droping the error "Segmentation fault" .. i use teh addresses.h i found in the kernel directory, does anybody have any idea how to access the GPIO? what im actually trying to do is to set the Register for the internet serial port for the RTS signals. Does anybody have any c/c++ examples how to access the GPIO/any other port on the mini 2440 using the arm linux Kindest regards Sepp
Access GPIO/PORTS in mini2440
Hi Sepp, I've wimped out with the GPIO ports and I'm using the /sys file system to handle communicating with this for me. I did a little set-up in the board's specific start-up code to put things in the right state, but after that, I've used what's available in /sys to handle this for me, because it's adequate for my application. Anyway, here's what I did: 1- get gpio information You can echo into /sys/class/gpio/export the GPIO number you want exported, but to do this, you'll need to know the GPIO bank's "base". Here's the cheap way of finding the "base" numbers for the G $ cd /sys/class/gpio $ for i in gpiochip* ; do echo `cat $i/label`: `cat $i/base` ; done GPIOA: 0 GPIOE: 128 GPIOF: 160 GPIOG: 192 GPIOH: 224 GPIOB: 32 GPIOC: 64 GPIOD: 96 2- Calc your gpio # If you want line 1 from GPIOE, you would add 1 to the base of GPIOE, in this case that would equal 129 3- Echo your gpio # into Then you echo the number into /sys/class/gpio/export $ echo 129 > /sys/class/gpio/export The kernel will create a directory /sys/class/gpio/gpio166 which contains files for the direction and value of the GPIO. Not all of the GPIO lines can be reached this way (I haven't investigated enough to know why...) You can then read and write to that file like any other file. You may need to do something more complex, but this is what worked for my application, where I could poll the file to get the state of the GPIO and write to it occasionally. Regards, gene
Hi gene.sally Would you please write the C program that dose what you say (changing a GPIO status). I've seen this: http://www.avrfreaks.net/wiki/index.php/Documentation:Linux/GPIO but it isn't for mini2440 and dose not work...
Hi ALL Please send me sample code to access GPIO's of MINI2440. how should i access them using system calls or by drivers ..please help me out thanks raghu
I am about to develope a opensource solution: https://sourceforge.net/projects/gpiolib i will be finish in a few weeks. But the driver must be installed with re-compilation of kernel greetings
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
FILE *fp;
int main(int argc, char** argv)
printf("\n**********************************\n"
"* Welcome to PIN Blink program *\n"
"**********************************\n");
//create a variable to store whether we are sending a '1' or a '0'
char set_value[20];
//Integer to keep track of whether we want on or off
int toggle = 0;
//Using sysfs we need to write "160" to /sys/class/gpio/export
//This will create the folder /sys/class/gpio/gpio160
if ((fp = fopen("/sys/class/gpio/export", "ab")) == NULL)
printf("Cannot open export file.\n");
exit(1);
//Set pointer to begining of the file
rewind(fp);
//Write our value of "160" to the file
strcpy(set_value,"160");
fwrite(&set_value, sizeof(char), 3, fp);
fclose(fp);
printf("...export file accessed, new pin now accessible\n");
//SET DIRECTION
//Open the LED's sysfs file in binary for reading and writing, store file
pointer in fp
if ((fp = fopen("/sys/class/gpio/gpio160/direction", "rb+")) == NULL)
printf("Cannot open direction file.\n");
exit(1);
rewind(fp);
//Write our value of "out" to the file
strcpy(set_value,"out");
fclose(fp);
printf("...direction set to output\n");
strcpy(set_value,"1");
int ch;
while(ch!=3)
printf("1:LED ON\n2:LED OFF\n3:exit");
printf("\nenter your choice\n");
scanf("%d",&ch);
switch(ch){
case 1:
{if ((fp = fopen("/sys/class/gpio/gpio160/value", "rb+")) == NULL)
printf("Cannot open value file.\n");
exit(1);
rewind(fp);
//Write our value of "1" to the file
fwrite(&set_value, sizeof(char), 1, fp);
fclose(fp);
printf("...value set to 1...\n");
} break;
case 2:
exit(1);
rewind(fp);
//Write our value of "0" to the file
strcpy(set_value,"0");
fclose(fp);
printf("...value set to 0...\n");
} break;
return 0;
Hey vinayak I tested this program I maunched in the mini 2440 I want know what pin of the board's GPIO do you test ? is it
http://www.avrfreaks.net/wiki/index.php/Documentation:Linux/GPIO See GPIO numbers
i want to use port G of GPIO as input in friendly arm mini2440. Please suggest how to do this.how can i access the control register of the GPIO ports programatically.
> how can i access the control register of the GPIO > ports programatically You can't if you run Linux. Use sysfs instead.
I tried to access the GPIOG0,GPIOG1 as input and GPIOF0-GPIOF3 as output in mini2440 .I follwed the method specified by Mr."Vinayak".On implementaion after compilation I got a message "can't open the direction file". Then I tried /sys/class/gpio/export echo "193" > /sys/class/gpio/gpio193/direction","in" etc... I can't configure GPIOF as "out" using similar commands how can do this?help me..
Can you set any ports on GPIOG as output? Got curious so had a look at mach-mini2440.c in Linux kernel 3.7 it is in the directory arch/arm/mach-s3c24xx and I see that GPIOG0, 3, 5, 6, 7 and 11 seemed to be setup for special purposes. Just a thought? Which kernel are you using?
and GPG4 as backlight and GPG8 for something to do with MMC/SD Linux kernel 3.4 is the same, haven't got any earlier ones.
sathiapr, read the Mini2440's schematic and find free or unused GPIOs. Almost all pins of the S3C2440 SoC can act as GPIO, but some have special meaning or are already in use. So, you can only use the remaining GPIOs.
Thank You Mr.Juergen.From the schematics,I found that GPIOB 0,1 are free in GPIO port with no other function.I set the direction of GPIOB0 as out and gave 0 followed by 1.I saw in all condition the pin is always HIGH.Also in the case of GPIOB1 I can't set direction.For my work I need at least 4 GPIO pin.How can get it?If anyone knows proper access please help me....
Mr. Vinayak, Am I supposed to compile the code on the computer or on the board? Because the file that you specified (sys/class/gpio) is present on the PC, but in the code you have mentioned entering a parameter to set the LED on or off, which means I should be connected to the board, right? Warm regards
