Activate SPI on Mini6410 with mcp2515 CAN interface: not working
Pierp0l
Attachment: mini6410.spi.can.mods.txt (1.41 KB)
Hi all,
i want to setup a CAN bus communication between the Mini6410 and a device..
In the attached file there are the lines of code i added to the machine
code in the file kernel/arch/arm/mach-s3c64xx/mach-mini6410.c.
After booting there are SPI and CAN protocol devices in /sys/... but
nothing in /dev, also if i compile drivers as modules, after modules are
loaded, they are all not in use. There are no errors during kernel boot:
dmesg | grep spi
spi-bus: source is mout_epll (0), rate is 84666666
dmesg | grep SPI
Mini6410: SPI ID 0
Samsung SoC SPI Driver loaded for Bus SPI-0 with 1 Slaves attached
SPI Driver: IOmem=[0x7f00b0ff-0x7f00b000]       DMA=[Rx-13, Tx-12]
dmesg | grep can
can: controller area network core (rev 20090105 abi 8)
can: raw protocol (rev 20090105)
can: broadcast manager protocol (rev 20090105 t)
How register can0 device in /dev and let working all drivers together?
Anyone can help me?
sygi
According to these logs:
you are using "socketcan" kernel framework. As I know this framework does
not support can0 as char device. You only get network interface can0.
Try "cat /proc/net/dev", and should see can0 there. Then "ifconfig can0 up"
to bring up this interface. And again "ifconfig" to se if it's running.
Then use socket API to communicate. To get char device use can4linux
project.
Pierp0l
sygi thank you for the help...
it'ok for me having a net device, not a char device so i'm still working
hard because in /proc/net/dev there isn't a can0 device. the SPI seems to
work correctly, also the can driver, but it seems there is no probing of
the mcp chip, because when driver probe the mcp it also create the net dev
can0.
I get this output:
[root@FriendlyARM /]# modprobe mcp251x
[root@FriendlyARM /]# lsmod
mcp251x 8187 0 - Live 0xbf000000
[root@FriendlyARM /]# find /sys -name *can*
/sys/kernel/slab/can_receiver
/sys/module/scsi_mod/parameters/scan
/sys/module/can
[root@FriendlyARM /]# find /sys -name *mcp*
/sys/bus/spi/drivers/mcp251x
/sys/module/mcp251x
/sys/module/mcp251x/parameters/mcp251x_enable_dma
/sys/module/mcp251x/drivers/spi:mcp251x
[root@FriendlyARM /]# find /sys -name *spi*
/sys/devices/platform/s3c64xx-spi.0
/sys/devices/platform/s3c64xx-spi.0/spi_master
/sys/devices/platform/s3c64xx-spi.0/spi_master/spi0
/sys/bus/platform/devices/s3c64xx-spi.0
/sys/bus/platform/drivers/s3c64xx-spi
/sys/bus/platform/drivers/s3c64xx-spi/s3c64xx-spi.0
/sys/bus/spi
/sys/class/spi_master
/sys/class/spi_master/spi0
any suggestions or clues?
Pierp0l
I found the mistake: the driver mcp251x is not loaded and probed because
names of spi devices are different from the ones the mcp require:
files dev-spi.c and spi_s3c64xx.c must be edited and the name "s3c64xx-spi"
must be changed to "spi" in all occurrencies.
Now probing starts but fails for me, it's a problem with the CS line i
think, i'm working on it...
cyberhippy
Attachment: mach-mini6410.c.patch.txt (2.42 KB)
Hi All,
I have looked at this problem over all and managed to get the can MCP2515
to probe and create the interface can0. I followed most of Pierp0l mod’s in
the original attachment. This original mod exhibits a problem with the CS
function and the way it is implemented.
The Patch attachment fixes this through calling the added setup function
that initializes two pins, one for the CS and one for the external
interrupt (which was wrongly assigned in the patch above).
I have also moved the MCP connection to the SPI1 as this port was more
convenient.
However I cannot yet confirm that all this actually works as I am have not
managed to open the socket yet.
ifconfig can0 up
responds with:
mcp251x spi1.0: bit-timing not yet defined
mcp251x spi1.0: unable to set initial baud rate!
SIOCSIFFLAGS: Invalid argument
But this should work when opening the socket correctly.
Has anyone tried to do this using Python?
cyberhippy
Hi Folks,
a small update to the patch above, it seems to work for a short time but it
falls over after sending about 30 can messages from python.
I have not yet found a solution to the problem other than restarting the
interface.
ip link set can0 down
ip link set can0 up type can bitrate 250000
But for starters it works.
Enjoy
tushar
i am not able patch the file patch command (patch mach-mini6410.c -i
/usr/src/mach-mini6410.c.patch -o mach-4mini6410.c) returning error "Only
garbage was found in the patch input"
