Hi I have a problem with watchdog. I'm running watchdog test program in FriendlyArm Folder. After 15 seconds system rebooting. After boot process ;tcp/ip connection is not working. I tried it in wince5 and wince6. When i manually switch off and on ; tcp/ip is working ok. How can i solve this problem? Thanks Ergun
Watchdog problem
I get similar problem. I am running watchdog application which makes soft reset. After soft reset Ethernet controller is not working (I can not ping or access device through ethernet). After manuall manually switch off and on ethertnet is working ok. Please help!
Hi.... having the same problems here. Using Windows CE 6.0 BSP and after reboot (initiated from watchdog) the DM9000 network controller is not working anymore. I tried different modifications (OAL / init.c) doing a soft reset of the DM9000 on every boot but without any success. I upgraded the DM9000 driver to the newest Version 2.50 from Davicom - No success. Is there a solution available ? Or some hints how to solve the problem ? In my situation the watchdog is useless with a not working network controller after reboot. Thanks Carsten
hardware reset!but must run a program to check the network at init.if network not work,hardware reset.
Hi! I also had this problem but I found the solution. The main problem is that the watchdog reset is effect on CPU only. All other device on board does not know about any resetting state. All software drivers would be smart enough to handle this case in its own device (e.g. give software reset to hardware). The solution is resetting DM9000's internal PHY correctly using DM9_GPR register. You just have to insert 2 lines in dm9000.cpp at the beginning of function C_DM9000::EDeviceInitialize(): // reset member varialbes m_uLastAddressPort = (U32)-1; DeviceWritePort(DM9_GPR, 0x01); // Power down internal PHY... NdisStallExecution(500); // ...and wait before activate DeviceWritePort(0x1f, 0x00); NdisStallExecution(20); // software reset the device DeviceWritePort(DM9_NCR, 0x03); NdisStallExecution(20); Good luck, Peter
Hi Peter I inserted 2 lines to dm9000.cpp. I create new CE6 image. I test it with watchdog test program. But it is not working. Which windows did you test it; CE5 or CE6? Thanks Ergun Kucukkose
Hi i think i found a solution for me. Not very "beautiful" but working in my case. Please try the following: - Deactivate the DM9000 via Network Control Panel - Let the Watchdog restart the system - Activate the DM9000 via Network Control Panel Now the DM9000 should work. So in my case i will ensure (Registry Setting NDIS Power == 4) that the system will always startup with the DM9000 deactivated. Now i activate it via a small software using the same code the connmgr uses. Not fully tested but promising... Carsten
Hi, i have found and tested a similar workaround: 1) before soft reset unbind the lan adapter (see code on ndisconfig.c) or call programmatically "ndisconfig.exe adapter unbind DM9CE1" 2) wait 20 seconds 3) reset board (watchdog or CESetSystemPowerState) after reboot the lan adapter work properly
