Hi Does friendly ARM 2440 board have a unique identifier (like a serial number) that I can obtain programmatically (via C# code)? Thank you guys for your help.
MINI ARM 2440 Serial Number
There are some topics about this http://www.friendlyarm.net/forum/topic/1631 http://www.friendlyarm.net/forum/topic/2026
Hi, As we see some of the simple example of mini2440 which are there in cd. Also I saw some program executable files in usr/bin of above program which I run using ./file command it work properly. I had ubantu 10.10 ver linux os installed in pc. I took .c files of examples in cd and compile it in linux gcc compiler in my system, I got executable file in system. Then I transfer these files to usr/bin of kit using serial port. I check it in directory.Then I am trying to run these files using ./file command but it shows message Permission denied. Please suggest what I suppose to do?
