Hello everyone, I need help, I bought an adapter with chipset VIA VT6656 usb wifi, but I can not install on my X35 MINI2440 FriendlyARM model, I'm using kernel zimage_X35, with rotfs_qtopia_qt4.img. when I plug the device comes this message: [root@FriendlyARM /www]# usb 1-1: new full speed USB device using s3c2410-ohci and address 2 usb 1-1: New USB device found, idVendor=160a, idProduct=3184 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-1: Product: VNT USB-802.11 Wireless LAN Adapter usb 1-1: Manufacturer: VIA Networking Technologies, Inc. usb 1-1: configuration #1 chosen from 1 choice ===================================================== [root@FriendlyARM /]# ifconfig wlan0 ifconfig: wlan0: error fetching interface information: Device not found [root@FriendlyARM /]# ifconfig wlan0 up ifconfig: SIOCGIFFLAGS: No such device ===================================================== [root@FriendlyARM /]# scan-wifi cfg80211: Calling CRDA to update world regulatory domain usbcore: registered new interface driver rt73usb usbcore: registered new interface driver ath9k_hif_usb ifconfig: SIOCGIFFLAGS: No such device 0 Access Point Found =================================== Can anyone help me please ?
VT6656 VIA wifi-usb adapter
I have got to install the VIA VT6656 driver on my micro2440 with Linux 2.6.32.2. There are perfect instructions to make it in this link. cse.yeditepe.edu.tr/~sgoren/spring2011/CSE326/lab4_new.pdf I am a begineer with linux so if I have made it, you will can too. Good luck.
Hi Jokin, Kindly let me know where can I download the VT6656_Linux_src_v1.20.03_x86.rar. Thanks, Speed
Hi speed, Maybe you can try via website : http://www.viaarena.com/Driver/VT6656_linux_src_v1.20.03_x86.rar Please, let us know Good luck
Hi all, I succesfully compiled the driver following jokin tutorial. I got vntwusb.ko driver. I tried to install it on 2.6.32.2 kernel (the original from FriendlyARM) using insmod vntwusb.ko command, but I don't get any eth1 interface when using ifconfig. I'm not an expert of drivers, perhaps I missed something? Can anyone help? Thanks!
Hi, I finally found my mistake: I used ifconfig instead of iwconfig to see eth1 interface. [root@FriendlyARM /]# modprobe vntwusb VIA Networking Wireless LAN USB Driver Ver. 1.20.03 VIA Networking Wireless LAN USB Driver Ver. 1.20.03 Copyright (c) 2004 VIA Networking Technologies, Inc. usb 1-1.4: reset full speed USB device using s3c2410-ohci and address 3 usbcore: registered new interface driver vntwusb [root@FriendlyARM /]# [root@FriendlyARM /]# iwconfig lo no wireless extensions. eth0 no wireless extensions. eth1 802.11-a/b/g ESSID:"" Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated Bit Rate:1 Mb/s Sensitivity=0/255 Retry min limit:8 RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality:0 Signal level:0 Noise level:0 Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 vntwpa no wireless extensions. [root@FriendlyARM /]# But I get an error when trying to set the ESSID : [root@FriendlyARM /]# iwconfig eth1 essid my_essid Error for wireless request "Set ESSID" (8B1A) : SET failed on device eth1 ; Invalid argument. [root@FriendlyARM /]# Does somebody have an idea?
Hi everybody, I managed to connect the mini with VIA VNT6656 wifi adapter successfully to my network with WEP encryption. In fact, when the driver is installed, nothing is reported by ifconfig. eth1 is mentionned by iwconfig only. It is necessary to do ifconfig eth1 up to get VNT6656 interface available for configuration with ifconfig. So for beginners like me with linux wifi, the correct initialization is: ifconfig eth0 down modprobe vntwusb ifconfig eth1 up iwconfig eth1 key YOUR_KEY iwconfig eth1 essid YOUR_NETWORK_NAME ifconfig eth1 192.168.1.230 netmask 255.255.255.0 route add default gw 192.168.1.1 echo "nameserver YOUR_DNS_IP" > /etc/resolv.conf then you should be able to connect ping and connect to your network. Now I have to manage to connect to WPA network with wpa_supplicant.
I'm also following the manual of http://cse.yeditepe.edu.tr/~sgoren/spring2011/CSE326/lab4_new.pdf but i get error linux kernel source not found ,when i do make C /path/to/source/of/linux2.6.32.2 M=`pwd`modules please guide me. i'm unable to get vntwusb.ko i use the same kernel as said in the manual. atleast please send me vntwusb.ko i need to test it on my mini2440 my email-id: yemailid123@rediffmail.com Thanks
When i did "make -C kernel_src M=$PWD modules" i got the following: make: Entering directory `/home/eswara/linux/linux-2.6.32.2' WARNING: Symbol version dump /home/eswara/linux/linux-2.6.32.2/Module.symvers is missing; modules will have no dependencies and modversions. Building modules, stage 2. MODPOST 0 modules make: Leaving directory `/home/eswara/linux/linux-2.6.32.2' Please can you help me with the above, especially getting 0 modules.
I don`t really get it! It seems to be quiet easy but when I type in the following: make -C /opt/FriendlyARM/mini2440/linux-2.6.32.2/ M=`pwd`modules ...I get this error: make: Entering directory `/opt/FriendlyARM/mini2440/linux-2.6.32.2' scripts/Makefile.build:44: /home/mo/Downloads/VT6656_linux_src_v1.20.03_x86/drivermodules/Makefile: No such file or directory make[1]: *** No rule to make target `/home/mo/Downloads/VT6656_linux_src_v1.20.03_x86/drivermodules/Makefile'. Stop. make: *** [_module_/home/mo/Downloads/VT6656_linux_src_v1.20.03_x86/drivermodules] Error 2 make: Leaving directory `/opt/FriendlyARM/mini2440/linux-2.6.32.2' It seems, that it needs a makefile...but there isn`t a folder drivermodules before....so there isn`t a makefile... I apologize, if this question is far too dumb... Thanks in advance!
Hi, i followed the manual, but when i install driver I got the following: make -C /home/adrian/friendlyarm/linux-2.6.32.2/ M=`pwd` modules make: se ingresa al directorio «/home/adrian/friendlyarm/linux-2.6.32.2» WARNING: Symbol version dump /home/adrian/friendlyarm/linux-2.6.32.2/Module.symvers is missing; modules will have no dependencies and modversions. /home/adrian/friendlyarm/VT6656_linux_src_v1.20.03_x86/driver/Makefile:116: *** Linux kernel source not configured - missing config.h. Alto. make: *** [_module_/home/adrian/friendlyarm/VT6656_linux_src_v1.20.03_x86/driver] Error 2 make: se sale del directorio «/home/adrian/friendlyarm/linux-2.6.32.2» Can somebody help me? Thank you
I've written detailed instructions on how to get this working (including WPA2) at link http://codepasta.com/site/micro/mini2440/wifi-driver.php
