hi, how can i read the cpu temperature under linux of the mini2440? i thought maybe with the 12c eeprom, but i dont see anything round there. any thoughts? thx james
Temperature CPU
HI sir. I want to know the temerature range of Mini 6410 and what is the minimum and maximum temperature and humidy percent? if that possible. thanks for regarding.
Hi, Are you sure there are embedded temperature sensors on S3C2440 and S3C6410 chips? I am not sure to have seen something like that somewhere. I don't think it's possible. Regards Screwface
Mohsen, Commercial -20 to +70 but I think you can push it to full Industrial range -40 to +85. They are being used in the Arctic and in equatorial deserts. Commercial range screening means it doesn't fail over the commercial range. It does not mean that it will fail if you get hotter or colder. If the Commercial grade parts are chosen from rejects from Industrial range screening, then you would be stuck, but I doubt that is a problem. These are originally cell phone chips and people expect cell phones to work anywhere anytime. The LCD will quit long before the processor. If there is a P-N junction on the chip where an A/D can read the voltage drop, you could get the temperature. Or glue an old NPN transistor to the S3C2440 and trickle some current though a resistor and the base-emitter junction and read with the A/D.
