Hi, I've connect my hardware serial output to the COM1 port of my Mini2440 device. the data are transferred at 115200 baud rate. Each packet of data is 6-bytes. When I use 300Hz(300*6 Byte/Sec) sampling the received samples are correct, but when I change the sampling rate to 600Hz, some bytes will be lost. It seems that the buffer of serial port is very low. I can not change the serial port buffer size by SetupComm() method in C++. When I use a USB to Sarial Interface to feed data through USB port of Mini2440 the problem will be solved and no data will be lost. Also, In C# program I see that the serial port reading has Memory Leakage!!! Would you please help me to solve these problems?
SerialPort Data Loss in C
3600 words/sec * 11 bits per word = 3900bps. The RX FIFO on the 2440 and 6410 has a depth of 64 bytes. The interrupt handler should be able to cope with that very easily. Are you sure the bug isnīt in your code? Are you polling the com port or are you handling events?
