hello friends, i m in trouble in my mini2440. first i have not any printer port to programme the nor flash so i bought the usb to parallel port and conected to it hjtag cable but unable to found any target when i have tested the port in port setting yhe message was"selected port dosn't work". i think thal i m entering the wrong port address. second,last time i have connected the port in my friends computer and loaded the simple led flashin programme made by me. but next time when i wanted to load supervivi in nor flash the message is coming that"can't load the driver" please any one tell me what should i do.
h-jtag big problem
A normal USB to LPT converter doesnt work with the parallel JTAG adapter. You need a device like this http://www-user.tu-chemnitz.de/~heha/bastelecke/Rund%20um%20den%20PC/USB... > but next time when i wanted to load supervivi in nor flash the message is > coming that"can't load the driver" Did you follow these steps? http://www.friendlyarm.net/dl.php?file=download.pdf
yes i follow these step and please read the problem briefly in No OS forum section.... named "can't load the driver at specified address"
good morning sir, I am using windows vista Operating system and Target board(EM 2440), while i am installing H-JTAG hard ware driver installation i faced problem in final stage. Is vista supported for H JTAG driver? please help me how to resolve that problem. i will waiting for your reply..bye
h-jtag big problem: Why are you reloading NOR? What happened to your Supervivi in NOR? Why would you ever erase it or replace it? It is your lifeline. For a start, I would RTFM. Shankar, I keep one old PC with a parallel port and XP just in case I brick a Mini or there is an update (it also has my old Protel99SE seat with a license, which is very popular in China and I can open all the schematic and layout I find on the web). I have never made USB to // adapters work with Wiggler style J-TAG.
Just a small note: you do not need an old PC with a parallel port. All you need is a PCI or PCIe parallel port adapter and 32-bit winxp (dual-boot if you need). PCI parallel port adapters are stupidly cheap: http://www.newegg.com/Product/Product.aspx?Item=N82E16815166006 That one is confirmed to work with the JTAG adapter for the mini2440, and even has 2 serial ports.
