hi, i compiled qte4.63-source and installed qtcreator.but when compiling qt-gui program qt says "arm-none-linux-gnueabi-g++ not found" in build issues.please help arm-none-linux-gnueabi-g++ is running on terminal. there is compile output: Running build steps for project hi... Configuration unchanged, skipping qmake step. Starting: "/usr/bin/make" -w make: `/home/henry/Belgeler/QT/hi-build-desktop' dizine giriliyor arm-none-linux-gnueabi-g++ -c -pipe -O0 -Wall -W -D_REENTRANT -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/local/Trolltech/QtEmbedded-4.6.3-arm/mkspecs/qws/linux-arm-g++ -I../hi -I/usr/local/Trolltech/QtEmbedded-4.6.3-arm/include/QtCore -I/usr/local/Trolltech/QtEmbedded-4.6.3-arm/include/QtNetwork -I/usr/local/Trolltech/QtEmbedded-4.6.3-arm/include/QtGui -I/usr/local/Trolltech/QtEmbedded-4.6.3-arm/include -I. -I. -I../hi -I. -o main.o ../hi/main.cpp make: arm-none-linux-gnueabi-g++: command not found make: *** [main.o] Hata 127 make: `/home/henry/Belgeler/QT/hi-build-desktop' dizininden çıkılıyor The process "/usr/bin/make" exited with code 2. Error while building project hi (target: Desktop) When executing build step 'Make'
qt says : arm-none-linux-gnueabi-g++ not found
->echo $PATH /usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/opt/bin:/opt/sun-j re/bin:/usr/local/arm/4.4.3/bin ->arm-linux-gcc -v Using built-in specs. Target: arm-none-linux-gnueabi Configured with: /opt/FriendlyARM/mini2440/build-toolschain/working/src/gcc-4.4.3/configure --build=i386-build_redhat-linux-gnu --host=i386-build_redhat-linux-gnu --target=arm-none-linux-gnueabi --prefix=/opt/FriendlyARM/toolschain/4.4.3 --with-sysroot=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sys-roo t --enable-languages=c,c++ --disable-multilib --with-arch=armv4t --with-cpu=arm920t --with-tune=arm920t --with-float=soft --with-pkgversion=ctng-1.6.1 --disable-sjlj-exceptions --enable-__cxa_atexit --with-gmp=/opt/FriendlyARM/toolschain/4.4.3 --with-mpfr=/opt/FriendlyARM/toolschain/4.4.3 --with-ppl=/opt/FriendlyARM/toolschain/4.4.3 --with-cloog=/opt/FriendlyARM/toolschain/4.4.3 --with-mpc=/opt/FriendlyARM/toolschain/4.4.3 --with-local-prefix=/opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi//sy s-root --disable-nls --enable-threads=posix --enable-symvers=gnu --enable-c99 --enable-long-long --enable-target-optspace Thread model: posix gcc version 4.4.3 (ctng-1.6.1) thanks
Sorry, run out of suggestions. Maybe, http://www.sereno-labs.com/ might offer suggestions. Good luck.
->arm-linux-gcc arm-none-linux-gnueabi-gcc : no input file ->sudo arm-linux-gcc arm-linux-gcc : command not found what is the wrong?
i compiled on terminal there is result: hamza@ham hi $ qmake -spec /usr/local/Trolltech/QtEmbedded-4.6.3-arm/mkspecs/qws/linux-arm-g++/ -o Makefile *.pro WARNING: /usr/local/Trolltech/QtEmbedded-4.6.3-arm/mkspecs/common/g++.conf:46: Variable QMAKE_RPATH is deprecated; use QMAKE_LFLAGS_RPATH instead. WARNING: /usr/local/Trolltech/QtEmbedded-4.6.3-arm/mkspecs/features/yacc.prf:27: Unescaped backslashes are deprecated. WARNING: /usr/local/Trolltech/QtEmbedded-4.6.3-arm/mkspecs/features/lex.prf:19: Unescaped backslashes are deprecated. hamza@ham hi $ make clean rm -f moc_mainwindow.cpp rm -f ui_mainwindow.h rm -f main.o mainwindow.o moc_mainwindow.o rm -f *~ core *.core hamza@ham hi $ make /usr/bin/uic mainwindow.ui -o ui_mainwindow.h arm-none-linux-gnueabi-g++ -c -pipe -O0 -Wall -W -D_REENTRANT -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -I/usr/local/Trolltech/QtEmbedded-4.6.3-arm/mkspecs/qws/linux-arm-g++ -I. -I/usr/include/QtCore -I/usr/include/QtNetwork -I/usr/include/QtGui -I/usr/include -I. -I. -o main.o main.cpp make: arm-none-linux-gnueabi-g++: Komut bulunamadı make: *** [main.o] Hata 127
Hello davef, i am facing the same problem. I am getting the following answer: which arm-linux-gcc /opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-gcc How do i switch to arm-none-linux-gnueabi-g+? Best regards, Markus
Think if you actually look at <arm-linux-gcc> you will see it is a script which calls <arm-none-linux-gnueabi> with march=armv4t. Try just doing <which arm-linux-g++> and see what that says. Good luck!
Hello, yesterday i have found the solution for my problem. Problem description: I have added the path to the crosscompiler into the PATH variable. After that i was able to compile qt-everywhere by editing qmake.conf. But then i faced the problem, that qt creator could not find the crosscompiler even though i configured the previously made qmake-file. Solution I have solved this problem by configuring the full path to compiler within qmake.conf: /opt/FriendlyARM/toolschain/4.5.1/bin/arm-none-linux-gnueabi-g++ etc. After compiling qmake again i was able to configure qmake within qtcreator and compile the program. Now i am facing the problem to deploy the compiled program to the eval board. But i guess, that's an other story :-) Best regards, Markus
Excellent. I am sure the solution will be helpful to others. Good luck with the next phase of the project.
hi i reinstalled everything on xubuntu 10.10 now qmake is ok in terminal.Now what is the next step for gui programming on qtcreator?
@ hdak.... You can follow this tutorial for making qui step. http://mini2440vietnam.blogspot.in/2011/05/programming-application-for-m... @ davef Can you assist me through this ? I am planning to use arm-linux-gcc 4.4.3 toolchain for this. I extracted it and set the path according to procedure. however when i type arm-linux-gcc --version command, it throws me an error as below : /opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-gcc: 15: exec: /opt/FriendlyARM/toolschain/4.4.3/bin/.arm-none-linux-gnueabi-gcc: not found Let me know if you have any solution to this program.
Dhruv, Yes, I'll try. Have you exported the path to your compiler in .profile or .bashrc? I write compile scripts as I got tired of re-typing the commands millions of times. For those you could place a echo statement to give you the result of your --version command. There is an old tutorial on the Wiki page that tries to outline the steps involved in doing things from scratch. Watch out for errors! I would also check that that is the correct syntax for the command. Last question, are you wanting to learn how to do stuff from scratch or more interested in writing applications?
Dave...! I am more interested in writing application. However, as my qt is stuck, i can not move further so experimenting with basics right now. What my goal is to design a gui using qt for mini2440.
I am not trying to discourage you from getting an understanding of the basics, because I am sure it is worthwhile in the long run and it will "keep you off the streets" for many many evenings. For example, do you need you have a good understanding of semiconductor physics to work with these microprocessors? The physical limitations are normally highlighted in the datasheet, you don't need to know why they are there. In other words . . . "hardware abstraction". After about 10 years working with 8bit uPs to the level of running webservers on them it took a good 2-3 years (10 to 20 hours a week) just to get a basic of understanding of running Linux on this board. I am not saying that there haven't been some problems, but running a BSP (Pengutronix) even for the Qt stuff has been much less painful. There is good support and people working with Qt, see here: http://wingston.workshopindia.com/wingz/embedded-programming-on-the-mini... (seems to be down at the moment). Did you get any further with your problem? Reading further up this thread: > Think if you actually look at <arm-linux-gcc> you will see it is a script > which calls <arm-none-linux-gnueabi> with march=armv4t. reminded me that this comment is only specific to the FriendlyArm toolchain.
Yeh...I surely agree to your point. Understanding basics is very necessary as to know how things are actually working @ hardware level. However due to my education, I have fair idea of 8 bit uP, 16 bit uP and arm 7 architectures. As far as, this problem is concerned. I believe i need to set up whole thing in my 32 bit old pc, it might be having problems with newer version of ubuntu or 64 host systems.
Dear all, I am following the instructions to compile QT app for Tiny6410 board. I could compile it successfully. Just a simele hello word QT application. But when i run in the board in terminal (./testQT -qws), it gives me following error: testQT: Error while loading shared libraries: libQtGui.so.4: cannot open shared object file: No such file or directory How do i proceed with resolving this error? Regards, Girish Thavai
Have you tried to find any libQt libraries on your target? find -name libQt* -print My guess is that none of them are there because that library is always or almost always needed!
Dear davef, yes the QT libraries are already installed in the target. I set some PATHs in target and created symbolic links. The application runs now. ;-)
Now, both you and the program can find them :) Everything has to be just right, but when it is you feel good. It can be a real challenge . . . most days!
Hi, Please help me!! I used CentOS,but when write 'arm-linux-gcc' command .. [root@ICICVM etc]# arm-linux-gcc -v readlink: invalid option -- m Try `readlink --help' for more information. /opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-gcc: line 15: /etc/.: is a directory /opt/FriendlyARM/toolschain/4.4.3/bin/arm-linux-gcc: line 15: exec: /etc/.: cannot execute: Success
What do you see when you run readlink --h http://unix.stackexchange.com/questions/15381/php-package-wont-install-c...
